Old Feb 11, 2011, 12:50 AM
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Nice Day at the pond.. No Marks but ..
Well here's what it was like over Lunch and later this eve after work today.. No one in sight then..
I plan to try to hit DeAnza Cove in the afternoon after lunch tomorrow..
it's another PowerBoat Friday at the pond..
Cheers.. JimS
jims123 is offline Find More Posts by jims123
Old Feb 11, 2011, 04:52 PM
Joined Oct 2010
I was there later in the day sailing my new S/B....
Krowbar69 is offline Find More Posts by Krowbar69
Old Feb 12, 2011, 01:34 AM
jims123's Avatar
Joined Oct 2007
Neat.. Louis and I were over at DeAnza rippin the reaches round a boat upwind and a buoy downwind .. had a blast.. JimS
Old Feb 12, 2011, 04:11 PM
jpparisy's Avatar
France, Ile-de-France, Plaisir
Joined Sep 2010
Originally Posted by jims123 View Post
jpparisy
Thanks for the help.. I guess I'd need Google Translate to figure out how to get a login and passwd to see this info tho.. Regards jimS
I don't thought that a login was required to see pictures.
The buoys are made from "noodles" (or "frieds") as said Rich, Glass Fiber rods, and the counterweights are made from five to ten nuts of 8 to 12 mm.
These pictures are from "Guillaume FRA72":
"Sardine" means picket, "bouee" means buoy, and "plomb" means lead.
Note that you need a cord in Nylon (polyamid), and not polypropylene which has a density less than water (it floats!).
The description of the RC boat used to anchor the buoys can be found in my Web site.
Look also at this other solution proposed by our Swiss Friend Yves Walter.
jpparisy is offline Find More Posts by jpparisy
Old Feb 12, 2011, 05:26 PM
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
Jim
Very good stuff. I am going to start working on some of these. Thanks for sharing.
Boomer
Boomer1 is online now Find More Posts by Boomer1
Old Feb 13, 2011, 08:08 AM
jims123's Avatar
Joined Oct 2007
Originally Posted by Boomer1 View Post
Jim
Boomer
Hey Boomer ..
you are most welcome but all the credit here should go to our French friend jpparisy who kindly posted it, and "Guillaume FRA72" (William) who built them,.. not me. These are pretty fancy.. but I think I do need to go pool-noodle shopping. I just went to his site http://jpparisy.free.fr/le_lac/
and Google Chrome is all set up to translate it.. talk about how to build a better mouse trap.. that buoy launch utility boat is totally amazing! did you see that gizmo?
Regards
jimS
Last edited by jims123; Feb 13, 2011 at 08:19 AM. Reason: http://jpparisy.free.fr/le_lac/
Old Feb 13, 2011, 08:41 AM
jims123's Avatar
Joined Oct 2007
1st Race Today
I'm kinda anxious about it too.. the prediction at 10am for the Start is there's going to be only zero to 2 mph of wind.. (and i hate super light conditions like that).. and something odd occurred yesterday that has me baffled.. especially cause it "healed itself" and could come back at any time I suppose..
Friday Louis and i sailed DeAnza cove and as I was rigging the helmet cam. the freeking neck strap clip failed yet again.. and the Tx fell 4feet to the asphalt.. this is after I was simply working hands free for 10 minutes getting the camcorder set up.. aargh.. that Turnigy strap thing's got to go.. but is what i THINK?? might have caused this new issue below!
Sailed for a couple hrs yesterday (Saturday) and then noticed I lost Main/Jib control for 15 seconds.. and it came back.. then another 10 minutes later it happened again.. the Rudder was rock solid.. no issues at all with it (and by the way it's got the new servo in it and is working flawlessly).. However, the Main was totally dead.. got the boat out of the water , cycled the Receiver and the Tx power several times and was still dead.. Got Home, was still dead, tapped on the transmitter case a lot more.. (thinking the prob is a loose contact and only in Servo Chan 3 Throttle stick control) but no change.. the receiver and all connectors looked perfectly dry, voltage indicator was maxed at over 6.0vdc, Rx green, but no Mainsheet servo control.. Shut down yet again.. recharged the boat's RX 2300mah 10C surge battery.. which was fine and only drew 340mah's to recharge, and put it back in having changed NOTHING else.. but then found that the main started working just fine again.. and try as i might.. I can't make it fail.. So, i suppose the problem will come back while I'm racing today.. but I want to see if it really is in the Transmitter as i suspect.. or the Rx/ servo battery in the Receiver.. Guess we'll see.. More to follow.. JimS
Old Feb 13, 2011, 09:02 AM
Toronto Canada
Joined Apr 2007
If you are using a 2.4 set up try re binding the transmitter and receiver--that should eliminate the problem or you have transmitter problems re the drop--Cheers Bill.
5353billboat is offline Find More Posts by 5353billboat
Old Feb 13, 2011, 09:29 AM
jims123's Avatar
Joined Oct 2007
Bill,
I fail to see how rebinding will help anything.. the Rx is bound and re-syncing up to the Tx every time I turn it ON .. Rx and Rudder Chan is 100% reliable.. no I don't plan to re-drop it either.. But thanks for the tips.. JimS
Old Feb 13, 2011, 11:18 PM
rsgault's Avatar
USA, CA, Riverside
Joined Oct 2010
Jim,
How did your first experience racing today go? Did you have any breeze?
Rich
rsgault is offline Find More Posts by rsgault
Old Feb 14, 2011, 12:31 AM
jims123's Avatar
Joined Oct 2007
Originally Posted by rsgault View Post
Jim,
Rich
Rich,
It was awesome.. they delayed the start an hour for the wind to pick up. to 2 to 4mph, still can't believe i came in second on my 1st ever race for points. was incredibly lucky all the way around the course on that 1st one..
Did Ok on the second of three heats, but was over early at the line.. and on 3-of-3 I got myself into a big problem when I tried to pass in front of another guy who was on starboard and my wind faded, so.. and so, didn't quite make it ahead of him.. we collided and i got stuck in irons.. losing a lot of time and came in second to last (of about 20 ODOMs I think) but aside from that, it was very educational and I had a ball.. The radio issue with the main/jib sheet CH3 never reoccurred.. I'm expecting that will pop up again but I'll be ready to isolate it next time..
I'm just very thankful it was such a great experience today.. Hope my friends Chris Lon and Rich all did well racing later in their boats too.. Met a Lot of new guys I didn't know before .. their new to me at least.. but most i think have been sailing there 10+ years.. I got some video and hope to edit and post some of it later.. Twas Nice to be the rookie of the Day today..
Regards, JimS
Old Feb 14, 2011, 12:36 AM
jims123's Avatar
Joined Oct 2007
Jim,
Rich
Rich,
Regards, JimS
Old Feb 15, 2011, 08:58 AM
jims123's Avatar
Joined Oct 2007
Had a nice lunch racing round makebelieve marks today
Ok here's how it works..
If you're in the lead, you get to Pick an imaginary spot in the far end, center of the pond. Whomever's 1st gets to turn and head back, and the others do the same, once there, the others behind follow turning at the same spot..
in theory this is great.. but in practice it leaves a lot to be desired.. so I ordered a pool noodle from Amazon.com and will get some marks made..
problem is they take a while to set and retrieve.. and I'd rather be sailing ... of course.. Oh well.. i wish marks were my only problem..
Fun Stuff, JimS
Old Feb 17, 2011, 01:27 PM
jims123's Avatar
Joined Oct 2007
Wolfram Alpha and the IOM regatta
Did you know that if you simply type "windspeed" into http://www.wolfram.com/ .. it'll figure out where you are and give you a current and past weather plot?
Am looking forward to watching some of the IOM Regatta here in SD this weekend. Should be wild as it'll be pretty strong winds in occasionally rainy sonditions.. have already met Fred who's come down early and understand Jess Atkinson our ODOM Class Secretary and many other seasoned pros will be here. I'm sure i could learn a lot watching the IOM races this weekend..
By the way I'm hoping my buddy Rich H has his servo jitter issues now resolved.. it was tough to hear his frustration constantly re-correcting course as his Red ODOM 396? would swing to and fro on it's own. I know he got Louis' help putting in a new servo to resolve it yesterday. Hope that helped..
Regards, jimS
Old Feb 17, 2011, 02:58 PM
jpparisy's Avatar
Joined Sep 2010
Yes, it works!
Discussion Great F5B day in sunny San Diego verticalflight High Performance 29 Aug 05, 2009 04:11 AM
Discussion More pictures from the first day of MWE Spring Fling 2008 in sunny San Diego part 2 Stelio Electric Flight Events 2 May 17, 2008 11:31 PM
Discussion More pictures from the first day of MWE Spring Fling 2008 in sunny San Diego part 1 Stelio Electric Flight Events 0 May 17, 2008 12:31 AM
