Thank goodness you don't have an IOM too.. guess next year if you do get one that could be a new challenge for you.. .. awesome performance.. and a well deserved set of awards (tho i bet some of the points standings were very close .. Good On-Ya!. And Good Luck Next year... tactics are critical but your boat is a lot faster than most.. and I'm eager to get some tuning tips 1st hand some time at your convenience. Please call the night before and I'll certainly try to be there .. Thanks Again Ken.. ![]() ![]() Regards, JimS |
[/QUOTE]tactics are critical but your boat is a lot faster than most.. and I'm eager to get some tuning tips 1st hand some time at your convenience. Please call the night before and I'll certainly try to be there .. Thanks Again Ken..
![]() ![]() Regards, JimS[/QUOTE] Jim, As a first step I suggest you build/acquire a mast head tell tail similar to mine... it's basically a streamer free to rotate. I consider it critical anytime you're off the wind (ie not close hauled). Not only does it give you wind direction, it also gives you an indication of wind strength. The wind vanes I see out there on many boats may give you wind direction, but provide no info re wind strength. And even if there is zero wind, they will still point in some direction. I use mine to tell me how to trim my sails... I consider it a critical item. Reaching and downwind doens't have to be a parade! regards, Ken |
![]() ![]() Regards, JimS[/QUOTE] Jim, As a first step I suggest you build/acquire a mast head tell tail similar to mine... it's basically a streamer free to rotate. I consider it critical anytime you're off the wind (ie not close hauled). Not only does it give you wind direction, it also gives you an indication of wind strength. The wind vanes I see out there on many boats may give you wind direction, but provide no info re wind strength. And even if there is zero wind, they will still point in some direction. I use mine to tell me how to trim my sails... I consider it a critical item. Reaching and downwind doens't have to be a parade! regards, Ken[/QUOTE] Ok.. not sure where to get one.. is Rich R still making em? I will ask him.. ![]()
![]() [/QUOTE]Jim - Yes, something like Rich has would work fine. They're easy to make if you need to do it yourself. And you have a pair of tell tales on your jib too, right? Something you can see across the pond... like VHS tape. Like I say in the videos it all starts with a clean air start (ie not in the back row) and being at speed. So when you go across the line you're at least even with everyone else. Then it's about having good (not necessarily the fastest) boat speed (that's where the jib tell tails come in) and playing the shifts. If you do that you will be in good shape at weather mark. The next decision point is at the offset mark... do you jibe or stay on stbd (that's what the mast head tell will help you with.) So when you're ready to go give me a call and we'll do a lesson at the pond. regards, Ken |
[QUOTE Jim - Yes, something like Rich has would work fine. They're easy to make if you need to do it yourself. And you have a pair of tell tales on your jib too, right? Something you can see across the pond... like VHS tape. Like I say in the videos it all starts with a clean air start (ie not in the back row) and being at speed. So when you go across the line you're at least even with everyone else. Then it's about having good (not necessarily the fastest) boat speed (that's where the jib tell tails come in) and playing the shifts. If you do that you will be in good shape at weather mark. The next decision point is at the offset mark... do you jibe or stay on stbd (that's what the mast head tell will help you with.) So when you're ready to go give me a call and we'll do a lesson at the pond.
regards, Ken[/QUOTE] Sounds good.. I'll hit up Rich.. then call.. Thanks Ken.. ![]() JimS------- Ken, I got a Masthead tell-tail from Rich R so am ready for that tuning session any time..
Joined Jan 2012
Educational Videos of RC sailboat racing
I found your videos on Youtube and found them very enjoyable and educational. I was researching how best to record a regatta I found your videos on Youtube and found them very enjoyable and educational. I sail an EC-12 in Jax FL with a great bunch of very proficient sailors. I was looking for a way to learn from my mistakes as well as show others theirs and to get another perspective on how best to have sailed the course. I would like to know what type of camers to are using....what is the resolution you shoot and how long your memory card and battery lasts etc.. Also how much playback time is allowed on youtube at the resolution you shoot..? How do you ensure the camera is set up correctly on your hat. Once again great job on the videos and it is obvious you have the skill to read the lifts and shifts as well as set up the sails for the conditions. Thank you, Martin Gray AMYA # 15914 |
Question about next week's points races. I've got some appointments on Saturday morning, and it's going to be tight getting to the pond on time (and the calendar shows ODOM first). If I miss the skipper meeting or even the first race...can I get in on the second and third races...? January was my first points race and I had a blast. I'm sure I won't make all the races this year, but I hate to completely miss this one.
Dale |
I am not 100 % sure of this, but if you want.. I can sign you up and pay the $3.00 for you and if you can't actually make it in time to sail the 1st race at around noon.. then it would be the same as having a dead battery or radio / boat equipment issue if you had to miss the 1st or second race... (I believe) so Yeah! common down! Very Glad you are going to try anyway! JimS ![]()
n:1 as you fine tune your sails.. I'm sure Bob likely have them set right but that is the best way to be sure.. and of course a bit of practice always helps too.. JimS
| Thread Tools | |
| Discussion Great F5B day in sunny San Diego | verticalflight | High Performance | 29 | Aug 05, 2009 04:11 AM |
| Discussion More pictures from the first day of MWE Spring Fling 2008 in sunny San Diego part 2 | Stelio | Electric Flight Events | 2 | May 17, 2008 11:31 PM |
| Discussion More pictures from the first day of MWE Spring Fling 2008 in sunny San Diego part 1 | Stelio | Electric Flight Events | 0 | May 17, 2008 12:31 AM |
