Old Jan 23, 2011, 06:10 AM
cloaked is offline
Find More Posts by cloaked
Why did I sell them all.
cloaked's Avatar
Australia, NSW, Sutherland
Joined Dec 2010
First EDF - FMS Dassault/Dornier Alpha
hey Guys
I have been lurking around up in the beginner RC Electric Plane area for while now and want to make the Jump to EDF's. I have only flown the Super CUB LP up until now and wanted to ask for some experienced EDF opinions.
I have been doing alot of reading on the FMS Dassault/Dornier Alpha 70mm and a lot of places say it is a good First EDF (High Wing/Low Stall) some places go on as far as saying that it is a good place to start with Electric RC Planes PERIOD!
So in your humble opinions, Has anyone flown this plane? Can anyone comment on this plane? What do you think? Are there any tricks or tips pages/sights for this plane? Is FMS generally good quality? and final question is the one on Hobbycity.com tha same as the FMS one? (Does say in teh description what brand it is.)
Link: http://hobbycity.com/hobbyking/store...dProduct=14565
FYI sorry if this has been asked before I tried searching for FMS/FMS Alpha/FMS Dornier and it was not very helpful, I could only find a few related posts and there wasnt much info in them.
Appreciate any light anyone cane provide.
Cheers
Will
cloaked is offline Find More Posts by cloaked
Old Jan 23, 2011, 06:30 AM
Frenche is online now
Find More Posts by Frenche
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
Will,
I'm pretty sure there is 2 different FMS ALPHA jets, a 64mm one and a 70mm one. Also adding to the confusion, Starmax make a 64mm one and a 90mm one I think. The one you linked is the 70mm FMS version I think.
I wouldn't jump straight from a Cub to a EDF jet, try a low wing sports plane or warbird first, much easier to fly and more forgiving
Frenche is online now Find More Posts by Frenche
Old Jan 23, 2011, 10:17 PM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Thanks Frenche Im actually assembling the parts to do an Ailereon Mod and a motor upgrade for the SC LP.
Hopefully use that as an aileron trainer first.
Old Jan 24, 2011, 01:44 AM
ozgur is offline
Find More Posts by ozgur
ozgur's Avatar
Joined May 2009
cloaked,
Frenche is right, go for a mini pulse xt or mini super sportster... But I am sure you will going to buy an EDF so Dornier Alpha1 or T-45 can be a good planes to start...
Check Hobby King's T-45, much cheaper and glides when you kill the power.
Ozgur
ozgur is offline Find More Posts by ozgur
Old Jan 24, 2011, 03:04 AM
Toyota12ht is offline
Find More Posts by Toyota12ht
Toyota12ht's Avatar
Pakistan, Khyber Pakhtunkhwa, Abbottābad
Joined Jan 2011
cloaked,
if you can fly that HZ supercub with no ailerons, I think your ready to move on. I would forget about modifying the cub - and put the money toward a better aircraft.
I found the HZ supercub horrific to fly in anything above 5knots.
Honestly if you can fly a HZ supercub you will handle the Hobbyking T45, stock it glides and floats and can be flown very slowly, I much prefer it to the more expensive PZ T28D i have.
Good Luck in choosing a new aircraft.
Toyota12ht is offline Find More Posts by Toyota12ht
Old Jan 24, 2011, 04:59 AM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Thanks for the info guys.
I take it your referring to this T45..
https://www.hobbyking.com/hobbyking/...dProduct=16273
Are they any good? This will be my last plane purchase for a while so I hope I can have a bit of fun with it.
Are the Hobbyking TX and RX any good? I have a Spektrum DX5e I can use or I might pick up one of those Hobby King kits.
Sorry for all the newbie questions.
Old Jan 24, 2011, 07:15 AM
ooooh yeah
Frenche's Avatar
Joined May 2004
+1 for that T-45 as a 'beginner' edf, I hear they are great planes, might pick one up myself. Check out this thread http://www.rcgroups.com/forums/showthread.php?t=1319069 for all the tips, tricks and help regarding it.
I'm not sure about the HK radios, some are reporting major bugs and quality control issues. Have a look around for a used Spektrum DX7, that will serve you well for years to come and as a bonus the HK 'orange' receivers are great and only $10 a pop. That being said, a DX5e should be more than enough for that jet but if you want more features and functions, consider a higher end unit.
Old Jan 24, 2011, 02:31 PM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Thanks Guys, looking at theat T45 now.
Do those HK "Orange" receivers work with the DX5e with DSM2?
That would be sweet if they did.
Old Jan 24, 2011, 03:08 PM
Toyota12ht's Avatar
Joined Jan 2011
Cloaked, another option is to get a ar6200 rx from oomodel.com for $40.
I have a few from them with no problems so far.
Old Jan 24, 2011, 03:40 PM
ooooh yeah
Frenche's Avatar
Joined May 2004
Yep the 'orange' rx's should would with the DX5e as it is DSM2, if you get one of the 6ch cased rx's and satellite it's essentially the same as an ar6200, just cheaper, but you don't really need the satellite for the T-45.
Old Jan 24, 2011, 04:53 PM
jdlilfan is offline
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
I fly my FMS Alpha jet on a HK-7x v2. It is a great transmitter, especially for $60. I have 5 models on it and no problems with any yet. Range has not been an issue. The transmitter also has a 7 model memory, not 5 as advertised. Easy to bind and easy to program. Doesn't have expo though but does have programmable rates which is just fine for me.
jdlilfan is offline Find More Posts by jdlilfan
Old Jan 24, 2011, 06:26 PM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Sorry can anyone post a link to one of these "Orange" HK RX's to me they are all orange and I am getting confused.
Thanks for everyones help BTW.
Old Jan 24, 2011, 09:44 PM
ooooh yeah
Frenche's Avatar
Joined May 2004
Here are the 6ch ones I use http://www.hobbyking.com/hobbyking/s...dProduct=11965 they have a little port on the side to enable you to connect the satellite found here http://www.hobbyking.com/hobbyking/s...dProduct=13418
Old Jan 25, 2011, 04:41 AM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Thanks Frenche, damn thats cheap.
Only thing that sucks is there is none in the NSW warehouse so I will have to order everything in one from OS or split it into 2 orders.
Old Jan 25, 2011, 11:36 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Those little orange receivers are amazing....Ive got 5 going right now off of my DX6i and havent had a single glitch with any! Range has not been an issue. Highly recommended.
JGuilty13 is offline Find More Posts by JGuilty13
Question Dassault Alpha EDF jet from HobbyKing can-am flyer Electric Ducted Fan Jet Talk 31 Oct 10, 2015 09:42 PM
Careful! ... RNAF Banana Hobby 0 Oct 11, 2010 03:18 AM
Sold Nib simprop dornier 328 turbo prop/edf CARL SCHIMNOWSKI Aircraft - Electric - Airplanes (FS/W) 1 Oct 05, 2010 03:31 PM
For Sale 70MM EDF fan motor esc combo from FMS Alpha skigmata Aircraft - Electric - Jets (FS/W) 1 Aug 02, 2010 04:02 PM
Question Dassault-Dornier Alpha-Jet P-51 Mustang Scale Kit/Scratch Built 6 Sep 01, 2007 05:50 AM
