Old Jul 29, 2003, 03:03 AM
MSN Hotmail
MSN Hotmail
Guest
n/a Posts
[RCSE] Re: V-Tail Movement
This is an auto-generated response designed to let you know that our system received your support inquiry and a Support Representative will review your question and respond to you soon. Please note that you will not receive a reply if you respond directly to this message.
IF YOU ARE NOT A HOTMAIL CUSTOMER AND ARE REPORTING SPAM FROM HOTMAIL:
Please note that we will need to see full message headers when you forward the offending mail to Hotmail. Full message headers are required for us to take any necessary action on the reported account. If you need help on how to view complete header information, please consult the Help associated with your e-mail program.
IF YOU ARE A HOTMAIL CUSTOMER:
While you are awaiting response from a Support Representative, here is some additional information about how you can help protect your account. We realize that this e-mail message is lengthy, but please read the entire message below because the answer to your question may be included.
Within this message is information on:
I. Limiting Junk E-mail ("spam")
II. Turning on the Junk Mail Filter
III. Reporting Unwanted, Abusive, or Fraudulent E-mail
We strictly enforce the MSN Website Terms of Use and Notices(TOU), which forbids e-mail abuse. We ask for your support to help Hotmail prevent unwanted, abusive, or fraudulent e-mail.
Hotmail employs the following methods to help protect you against spam:
- We limit the number of individual recipients for each e-mail message.
- We don't allow numeric characters at the beginning of an e-mail address. Any Hotmail sign-in name beginning with a numeric character is a forgery.
- We include "X-[Originating-IP]: [xxx.xxx.xxx.xxx]" in the header of each e-mail message that Hotmail delivers. Any e-mail message without this entry in its full header didn't come from Hotmail.
- We use industry standard security technologies to help block our relay hosts from those who send spam.
- We take legal action against senders of unsolicited bulk e-mail who forge Hotmail addresses.
List brokers and individuals who send spam use many tools and techniques to gather e-mail addresses wherever they appear online. Here are some suggestions to help you reduce the amount of spam that you receive.
Do:
- Remove yourself from any unprotected member directory.
- Open another e-mail account that you can use as an address for newsgroup and listserve publications or for posting on bulletin boards.
- Use the "Block Sender" option in Hotmail to block the delivery of e-mail from a specific sender.
- Use the Junk Mail Filter feature of Hotmail to filter spam into your Junk Mail folder.
Don't:
- Use your primary account to post to an online service or any Internet bulletin board.
- Use your primary account to post in a Usenet newsgroup or mailing list.
- Spend time in chat rooms or an online service that displays your address of your primary account.
- Include yourself in an unprotected member directory of an online service (the Hotmail Member Directory helps protect you from spam because we do not display member addresses).
- Reply to unsolicited e-mail messages with a "remove" request because this only validates to the sender that your address is current.
The Junk Mail folder uses innovative technologies to help protect you from unsolicited e-mail messages (also known as "spam"). Hotmail examines all incoming mail that you have not blocked or filtered. If it determines that the message is junk mail, Hotmail directs the message to the Junk Mail folder. You can specify how long messages remain in this folder before they are automatically deleted.
>>> To set the Junk Mail Filter
1. Click "Options" to the right of the "Contacts" tab. The "Options" page appears.
2. Under "Mail Handling", click the "Junk Mail Filter" link. The "Junk Mail Filter" page appears.
3. Select "Default", "Enhanced" or "Exclusive" to enable the filter. See below for descriptions of what happens with each filter level.
4. Click "Save Changes" to save your settings or "Cancel" to return to the "Options" page.
What is filtered at each level setting:
- Default vs. Enhanced. The Junk Mail Filter looks at a number of different clues in e-mail and tries to determine whether the message you received is junk mail. Setting the filter to "Enhanced" results in a stricter interpretation of what mail is valid than setting it to "Default". An "Enhanced" filter can result in more valid mail being filtered to the Junk Mail folder than you want, and you may need to check the folder from time to time to ensure that nothing you want has been defined as "junk". If you find valid mail in your Junk Mail folder, select the message and click the "This is not Junk" button.
- Exclusive: An "Exclusive" filter means that messages reach your Inbox only if they are from an address in your Contacts. This uses encryption to help protect against junk mail. By setting your Junk Mail Filter to "Exclusive", you accept only e-mail from your friends. This is e-mail equivalent of "donít talk to strangers".
Hotmail helps you to maintain your Contacts by offering to add e-mail addresses to your Contacts when you send out e-mail.
Note: If you want to accept mail from an address but donít want that address in your Contacts, you can add an address to your "Safe List" (You may want to use this for newsletters, for example).
IMPORTANT: Remember to check your Junk Mail folder at regular intervals to ensure that the filter catches only the messages that you want to delete. For example, mailing list mail and mail forwarded from another e-mail address may be filtered to the Junk Mail folder.†To ensure that these e-mail messages go to your Inbox, create Hotmail filters or add the sender's address to the Safe List.
>>> To add an address to your Safe List
2. Under "Mail Handling", click the "Safe List" link. The "Safe List" page appears.
3. In the box at the left of the page, type the address.
4. Click the "Add >>" button to add the address.
5. Click "OK" to save your settings or "Cancel" to return to the "Options" page.
>>> To change the status of a junk mail message
If you receive a message in the Junk Mail folder that you do not consider junk mail, do one of the following:
- In the Junk Mail folder, select the check boxes next to the messages that you do not consider junk mail and click the "This is not Junk" button. The selected messages are moved to your Inbox, and messages from these senders are not sent to the Junk Mail folder in the future.
- In the Junk Mail folder, select the check boxes next to messages and select a folder from the "Move to" drop-down list above the message list. This method moves the selected messages to that folder, but does not guarantee that messages from that sender are not sent to the Junk Mail folder in the future. Follow the direction above to ensure future mails from that sender arrive in your Inbox.
Note: Mailing list mail and mail forwarded from another e-mail address may be filtered to the Junk Mail folder.†To ensure that these e-mail messages go to your Inbox, create Hotmail filters or add the senders of these messages to your Safe List.
To report spam you will need to forward it with full headers.
>>> To report junk mail coming from an MSN Hotmail account
Not all junk mail you receive from an @hotmail.com address is from a legitimate Hotmail account. For Hotmail to assist you, please identify the true origin of the e-mail as follows:
1. On the "Options" page, click "Mail Display Settings" under "Additional Options".
2. Under "Message Headers", click "Full", and then click "OK".
3. Search for the following text in the message header: "X-originating-IP".
An example looks like this:
"Sat 02 June 2001 13:47:27 PST
X-Originating IP: [123.4.567.89] From: "Scarlett O' Hara"
Scarlett0gwtw@hotmail.com"
If you find an X-originating-IP line in the message header, forward a complete copy of the message, including the full message headers to abuse@hotmail.com.
If you cannot locate this line in the message header, the message has been forged and is not from a legitimate Hotmail account. Unfortunately, we are unable to take action against this account because it does not implicate a Hotmail member.
>>> To report junk mail coming from an account other than MSN Hotmail
1. Follow steps 1-2 above to display full header information.
2. In the header, look at the last "received" notation to locate the domain it came from (the e-mail service provider). It will look something like "username@ISPname.com".
3. Forward a complete copy of the message, including the full message header to abuse@ISPname.com or, if the ISP does not have an abuse address, send your complaint to Webmaster at the domain name.
>>> To view full headers in Microsoft Outlook Express or Microsoft Outlook
1. On the unopened mail, place your cursor over the mail, right-click, and click "Options".
2. Under "Internet headers", copy the contents of the full header.
3. Follow the steps outlined above in the section titled "Report junk mail coming from an MSN Hotmail account".
>>> To view full headers in MSN Explorer or MSN 8
1. Open the message, and then click "More" in the upper right corner.
2. Click "Message Source". The message opens in a new window with all of the header information visible.
You can keep up to date with the fight against spam at:
http://www.cauce.org/
Remember that MSN Hotmail also has comprehensive online help available--just click "Help" in the upper right corner.
AntiSpam UOL
AntiSpam UOL
Guest
n/a Posts
RE:[RCSE] Re: V-Tail Movement
<table border=3D0 cellpadding=3D1 cellspacing=3D0 width=3D580 height=3D240>
=09<tr bgcolor=3D#CE5212>
=09=09<td height=3D24 bgcolor=3D#990000 align=3Dleft valign=3Dbottom><a hre=
f=3D"http://antispam.uol.com.br"><img src=3D"http://mail.i.uol.com.br/antis=
pam_txt.gif" width=3D"124" height=3D"19"border=3D"0" hspace=3D5></a></td>
=09=09<td align=3Dleft width=3D66%><img src=3D"http://mail.i.uol.com.br/tir=
ateima_txt.gif" width=3D"90" height=3D"16" alt=3D"" border=3D"0" hspace=3D5=
></td>
=09=09<td align=3Dright ><a href=3D"http://www.uol.com.br"><img src=3D"http=
://mail.i.uol.com.br/logo_uol_pq.gif" width=3D"57" height=3D"20" alt=3D"" b=
order=3D"0" hspace=3D10></a></td>
=09</tr>
=09<tr>
=09=09<td colspan=3D3>
=09=09=09<table border=3D0 cellpadding=3D0 cellspacing=3D0>
=09=09=09=09<tr>
=09=09=09=09=09<td width=3D10 rowspan=3D2>&nbsp;</td>
=09=09=09=09=09<td><font size=3D1>&nbsp;</font><br>
=09=09=09=09=09=09<font size=3D2 face=3Dverdana>Ol=E1,<br><br>
=09=09=09=09=09=09Voc=EA enviou uma mensagem para <b>cesar_janotti@uol.com.=
br</b><br>
=09=09=09=09=09=09Para que sua mensagem seja encaminhada, por favor, <a hre=
f=3D"http://tira-teima.as.uol.com.br/challengeSender.html?data=3DQ1p21QkjrL=
tY2kau5lzf0Q2S4uK7xGRn6QRPF%2F7GzfyWacd8x01XOnewcQ sDTUcpI9P5EvO2CBoU%0AHuMv=
PJu8Sdrutw4WVg%2Bh60GBGkJxeaGcHtfaLMugcvr9mny%2FwU ste8jojmziVDiBqy6DTKwrLg%=
3D%3D" target=3D_blank><b>clique aqui</b></a><br><br>
=09=09=09=09=09=09</font>
=09=09=09=09=09</td>
=09=09=09=09</tr>
=09=09=09=09<tr>
=09=09=09=09=09<td>
=09=09=09=09=09=09<font size=3D2 face=3Dverdana>Esta confirma=E7=E3o =E9 ne=
cess=E1ria porque <b>cesar_janotti@uol.com.br</b> usa o Antispam UOL, um pr=
ograma que elimina mensagens enviadas por rob=F4s, como pornografia, propag=
anda e correntes.<br><br></font>
=09=09=09=09=09=09<font size=3D1 style=3Dfont-size:12px face=3Darial color=
=3D#9E0307><b>As pr=F3ximas mensagens enviadas para cesar_janotti@uol.com.b=
r n=E3o precisar=E3o ser confirmadas*.</b><br></font>
=09=09=09=09=09=09<font size=3D1 face=3Dtahoma,arial,verdana>*Caso voc=EA r=
eceba outro pedido de confirma=E7=E3o, por favor, pe=E7a para cesar_janotti=
@uol.com.br inclu=ED-lo em sua lista de autorizados.<br><br></font>
=09=09=09=09=09=09<table cellpadding=3D3 cellspacing=3D0 border=3D0 bgcolor=
=3Ddddddd width=3D100%><tr><td><font size=3D1 face=3Dverdana><b>Aten=E7=E3o=
!</b> Se voc=EA n=E3o conseguir clicar no atalho acima, acesse este endere=
=E7o:<br>
=09=09=09=09=09=09http://tira-teima.as.uol.com.br/challengeSender.html?data=
=3DQ1p21QkjrLtY2kau5lzf0Q2S4uK7xGRn6QRPF%2F7GzfyWa cd8x01XOnewcQsDTUcpI9P5Ev=
O2CBoU%0AHuMvPJu8Sdrutw4WVg%2Bh60GBGkJxeaGcHtfaLMu gcvr9mny%2FwUste8jojmziVD=
iBqy6DTKwrLg%3D%3D</td></tr></table>=09=09=09=09=09=09
=09=09=09=09=09=09</td>
=09=09=09=09</tr>
=09=09=09</table>
=09=09</td>
=09</tr>
=09<tr><td colspan=3D3 align=3Dcenter><hr width=3D"573" size=3D"1" noshade>=
</td></tr>
=09<tr>
=09=09=09=09<tr>
=09=09=09=09=09<td><font size=3D1 style=3Dfont-size:6px>&nbsp;</font><br>
=09=09=09=09=09=09<font size=3D2 face=3Dverdana>Hi,<br><br>
=09=09=09=09=09=09You=B4ve just sent a message to <b>cesar_janotti@uol.com.=
br</b><br>
=09=09=09=09=09=09In order to confirm the sent message, please <a href=3D"h=
ttp://tira-teima.as.uol.com.br/challengeSender.html?data=3DQ1p21QkjrLtY2kau=
5lzf0Q2S4uK7xGRn6QRPF%2F7GzfyWacd8x01XOnewcQsDTUcp I9P5EvO2CBoU%0AHuMvPJu8Sd=
rutw4WVg%2Bh60GBGkJxeaGcHtfaLMugcvr9mny%2FwUste8jo jmziVDiBqy6DTKwrLg%3D%3D"=
target=3D_blank><b>click here</b></a><br><br>
=09=09=09=09</tr>
=09=09=09=09<tr>
=09=09=09=09=09<td>
=09=09=09=09=09=09<font size=3D2 face=3Dverdana>This confirmation is necess=
ary because <b>cesar_janotti@uol.com.br</b> uses Antispam UOL, a service th=
at avoids unwanted messages like advertising, pornography, viruses, and spa=
ms.<br><br></font>
=3D#9E0307><b>Other messages sent to cesar_janotti@uol.com.br won't need to=
be confirmed*.</b></font><br>
=09=09=09=09=09=09<font size=3D1 face=3Dtahoma,arial,verdana>*If you receiv=
e another confirmation request, please ask cesar_janotti@uol.com.br to incl=
ude you in his/her authorized e-mail list.<br><br></font>
=3Ddddddd width=3D100%><tr><td><font size=3D1 face=3Dverdana><b>Warning!</b=
> If the link doesn=B4t work, please copy the address below and paste it on=
your browser:<br>
=09=09=09=09=09=09
=09=09=09=09</tr>
=09=09=09</table><br>
=09=09</td>
=09</tr>
=09<tr><td colspan=3D3 height=3D20 bgcolor=3D#990000 align=3Dcenter><font f=
ace=3Dverdana color=3Dffffff size=3D1>Use o <a href=3D"http://antispam.uol.=
com.br"><b><font color=3Dffffff size=3D1>AntiSpam UOL</font></b></a> e prot=
eja sua caixa postal</font></td></tr>
</table>
<table width=3D580 cellpadding=3D2 cellspacing=3D0 border=3D0>
<tr><td align=3Dcenter><font size=3D1 face=3Darial>
<font size=3D1 face=3Darial><SCRIPT>RdFhCfCggWeb =3D '1996-';</SCRIPT><SCRI=
PT src=3D"http://indice.uol.com.br/anouol.js"></SCRIPT></font></td>
</tr></table>
AntiSpam UOL
AntiSpam UOL
Guest
n/a Posts
RE:Re: [RCSE] Re: V-Tail Movement
></td>
=09</tr>
=09<tr>
=09=09=09=09<tr>
br</b><br>
tY2kau5lzf0YkMBhBpJs15bcWdna6FSd%2BWacd8x01XOnewcQ sDTUcpI9P5EvO2CBoU%0AHuMv=
PJu8Sc3X7NPHqD%2F9a1PjXzglH8bFVmDxC2U8fdyHkZiaKBEG JLpBphs7Placg%2FZWqUORXQ%=
=09=09=09=09</tr>
=09=09=09=09<tr>
=09=09=09=09=09<td>
=E7o:<br>
=3DQ1p21QkjrLtY2kau5lzf0YkMBhBpJs15bcWdna6FSd%2BWa cd8x01XOnewcQsDTUcpI9P5Ev=
O2CBoU%0AHuMvPJu8Sc3X7NPHqD%2F9a1PjXzglH8bFVmDxC2U 8fdyHkZiaKBEGJLpBphs7Plac=
g%2FZWqUORXQ%3D%3D</td></tr></table>=09=09=09=09=09=09
=09=09=09=09</tr>
=09=09=09</table>
=09=09</td>
=09</tr>
</td></tr>
=09<tr>
=09=09=09=09<tr>
br</b><br>
5lzf0YkMBhBpJs15bcWdna6FSd%2BWacd8x01XOnewcQsDTUcp I9P5EvO2CBoU%0AHuMvPJu8Sc=
3X7NPHqD%2F9a1PjXzglH8bFVmDxC2U8fdyHkZiaKBEGJLpBph s7Placg%2FZWqUORXQ%3D%3D"=
=09=09=09=09</tr>
=09=09=09=09<tr>
=09=09=09=09=09<td>
ms.<br><br></font>
your browser:<br>
=09=09=09=09=09=09
=09=09=09=09</tr>
=09=09</td>
=09</tr>
</table>
</tr></table>
AntiSpam UOL
AntiSpam UOL
Guest
n/a Posts
></td>
=09</tr>
=09<tr>
=09=09=09=09<tr>
br</b><br>
tY2kau5lzf0Qg%2F13OWmXFZseCqKj1XJISyWFaCa6BEcuc7Bf 1VNZz0I9P5EvO2CBoU%0AHuMv=
=09=09=09=09</tr>
=09=09=09=09<tr>
=09=09=09=09=09<td>
=E7o:<br>
=3DQ1p21QkjrLtY2kau5lzf0Qg%2F13OWmXFZseCqKj1XJISyW FaCa6BEcuc7Bf1VNZz0I9P5Ev=
=09=09=09=09</tr>
=09=09=09</table>
=09=09</td>
=09</tr>
</td></tr>
=09<tr>
=09=09=09=09<tr>
br</b><br>
5lzf0Qg%2F13OWmXFZseCqKj1XJISyWFaCa6BEcuc7Bf1VNZz0 I9P5EvO2CBoU%0AHuMvPJu8Sd=
=09=09=09=09</tr>
=09=09=09=09<tr>
=09=09=09=09=09<td>
ms.<br><br></font>
your browser:<br>
=09=09=09=09=09=09
=09=09=09=09</tr>
=09=09</td>
=09</tr>
</table>
</tr></table>
