Old Feb 15, 2011, 02:25 PM
markd02 is offline
Find More Posts by markd02
markd02's Avatar
London UK
Joined Oct 2008
Brilliant bit of foam bashing, I'm hooked, looking forward to the maiden vid
markd02 is offline Find More Posts by markd02
Old Feb 15, 2011, 08:35 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Originally Posted by kcaldwel View Post
Another possible technique with a special epoxy face coating, and then a hydrocal backing:
http://www.adtechplastics.com/ADTECH...221%20Tech.pdf
A thread here:
http://www.rcgroups.com/forums/showt...1381588&page=2
You still need a good finish on the plug.
Kevin
Originally Posted by AIR SALLY View Post
plus one for the face coat ...only way to go for plaster
Thanks for the info Kevin,
After reading up on face coating, I agree with you and Rodger, it will be the way to go. I will add it to the list to learn. I just got the clear canopy I ordered for it so I still haven’t finished the sanding the foam in the nose area yet. This was planned to be a slow project. It will give me more time to save up money for face coat I think it will be about 75.
Wow Mark, don’t hold your breath on that maiden vid,
I still have to figure out how to cast a mold, lay up fiber glass in a mold, get it to pop out in one piece, then design the internal structure, pick power parts, put it together ,so in a year or two finish it and then hope it will fly.
Dude your stressing me out.
Gee this is fun though!!!!
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Feb 15, 2011, 08:58 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
just make your mold into a few pieces, so you can pop each piece out easier, then put it all together and bond it and simply take it out of the mold in one piece. I have to figure out exactly how to do that with the Jaguar, but I'm lucky that the Jag is pretty boxy in design, so that shouldn't be a problem.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 15, 2011, 09:00 PM
Joined Jan 2009
if you want some good info on how to do molds and layups, got www.b1modelproject.com and watch some of Bob's videos. you'll learn more than you ever want to know. LOL.
Rich
Old Feb 16, 2011, 05:01 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i'll post a pic of a parting plane board that im doing a mold for a F-20 on . i think this is the way to make the halves,and have a nice seam ...more later when i post pic.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Feb 16, 2011, 11:36 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
You kiddin' me, a Tiger now?!
Watching impatiently for more progress! And if you happen to mold an extra... well you just let me know...
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Feb 17, 2011, 09:28 AM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2016, June 16-19th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
I stopped by Jeff's last night to drop off some Hydrocal and pick up some gear I had loaned him. Got a good look at the plug. The pictures don't do it justice and Jeff's done a great job. The plug reminds me a lot of John Morgan's work. Maybe Jeff better keep it under lock and key lest Mr. Morgan comes by and trys to put one of those spinny things on it's rear end.
Dan Eaton
eatond is offline Find More Posts by eatond
Old Feb 17, 2011, 09:58 AM
J Morgan is online now
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Hey! I heard that!!!!!
J
J Morgan is online now Find More Posts by J Morgan
Old Feb 17, 2011, 09:28 PM
St. Peters MO.
Joined Nov 2007
Hay Vic,
Greg is making it out your way in a couple of weeks so if you have any scratch –N-dent 100HV ESC’s send one home with him. Here I go again getting parts together before I even have a shell.
Thanks again Dan for making it over to discuss the methods you have learned. The plan is coming together.
John has for sure given me many pointers on the fuse shaping.
Dan; you brought up a good point about those double edged blades John uses and that they can be quit dangerous. I just happen to have received a spare funny looking multi prop device with a built in safety shield. Being concerned for our Senior RC guru’s safety it is of the utmost importance that John should immediately adapted the next J design jet to this safety measure.
I did get the 90mm Changsun fans today and they look good. The adaptor does need some work but I like the shape. I also got this huge 8 amp BEC for a separate 2s receiver and servo power but it’s a tank.
Old Feb 17, 2011, 09:29 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah lock it up ...john has'nt done a F-11 yet . he's only a few states away too
Old Feb 18, 2011, 05:45 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
The thing I got out of those pictures was the tiny little white foam dust on the the senior prop thingy. One of the drawbacks of working in foam, the dust is everywhere.
If the EPA ever stops to check my shop out, they would shut me down.
F-11........Hmmmmm????????
J
Old Feb 18, 2011, 12:02 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Old Feb 18, 2011, 12:16 PM
St. Peters MO.
Joined Nov 2007
You know Rodger the way John has been fabricating his Jets it could be done next week.
Old Feb 18, 2011, 01:30 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Please don't tempt me.
J
Old Feb 18, 2011, 01:35 PM
eatond is offline
eatond's Avatar
Joined Nov 2002
Hi John,
Jeff's in for a long haul to get his done. Hopefully he has it flying by E-Jets in September. When I was looking at the plug the other night I was kind of surprised you hadn't built one yet. It's right up your alley even if you are going to stick one of those spinny things on it's rump.
Dan Eaton
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
Discussion Anyone have a tracing of the bulkheads for the Berkeley Grumman F11F Tiger? byrocat Electric Ducted Fan Jet Talk 7 Jan 14, 2009 02:20 PM
Build Log Living Room Jet - F11F Tiger 1/48 metroidrc Scratchbuilt Indoor and Micro Models 60 Feb 17, 2008 08:56 PM
