Old Jan 30, 2011, 12:17 AM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
very cool project. subscribed.
LuvEvolution7 is online now Find More Posts by LuvEvolution7
Old Jan 30, 2011, 07:18 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Awesome man!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 30, 2011, 03:12 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
plug looking great . plaster is so soft and takes days to dry out ,it gets hot too as it sets. and can set really fast . if you want low cost than i guess face coats are out . it cost some bucks . basicly face coat is brushed on to the finished plug that is waxed and pva'd. a thick coat @ 1/16" is brushed on allowed to cure to tack free then glassed over with fiber glass. you will need a face coat that works with plaster . we used "Hemp" to give the palster reinforcement. hemp is a straw like material .i bet half of a plaster mold would weigh 50-60 lbs. if the plug survives your casting ,i might be interested in making a glass mold of it watch the "draft" of the parts so the mold will come off if draft is positive it will lock the plug in the mold. an exsample would be the canopy ...they are larger dia in the middle and then curve in at the base,this shape requires that the parting plane be down the middle of the canopy .a l/h and r/h halfves. a top and bottom mold would not work. hope this makes since.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jan 30, 2011, 03:48 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
This is one of those airframes that is so rarely modeled that it would actually be worth it to make a good glass mold.
pdawg is offline Find More Posts by pdawg
Old Jan 30, 2011, 04:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Old Jan 30, 2011, 06:41 PM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
This is gonna get good.
J
Boogie_ is offline Find More Posts by Boogie_
Old Jan 30, 2011, 08:49 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
if you havnt seen this.....its worth watching!
The Blue Angels - F-11 Tiger (9 min 59 sec)
Old Jan 31, 2011, 06:27 AM
Arngeir Blakseth is online now
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I have it on my computer, it sure is a good one. Did you know that the Blue Angels actually flew the F11F-1 from 57-69, it must have been a good flying aircraft for them to keep on using it for so many years after it was decommissioned from carrier duty (in 61 or 62).
Arngeir Blakseth is online now Find More Posts by Arngeir Blakseth
Old Feb 01, 2011, 03:38 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Rodger,
Thanks for passing along the info and cool video, it sounds like it’s more than I want get involved in. I wish you weren’t on the other side of the country I would like to see that process. I will try the casting method out on some small parts first like Dan before moving on to the real deal. I’m thinking about making the duct inlets separate at about 3in’s back then I can add the gun details and work over the inside lead up to the duct easier. I’m thinking It will also allow me to cut the fuse plug at an angle for an eraser release. The fuse looks to be sanded into shape, I will keep picking at it till all of the cut-outs fit just right. I cut a piece of foam board for a test tail and I really like the look of this jet.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Feb 01, 2011, 04:30 PM
Senior Member
Molde, Norway
Joined Jan 2001
That's looking really good.
And I agree on the idea of cutting off the front part of the inlets and to mold them as separate pieces, that would also make it easy to incorporate the gap between the splitter plate and fuselage. Details like that really makes a plane like this look good.
Old Feb 01, 2011, 04:40 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah buddy that looks nice ...makes me want to have you send it to me to make some nice molds. and i agree do the inlets seperate ....then you can add the bountry layer airfoil behind the scoops .
Old Feb 01, 2011, 05:32 PM
St. Peters MO.
Joined Nov 2007
There you go again Rodger, talking that jet lingo.
I had the same thought Arngeir, it will give that area some great detail.
Rodg, I shipped 2 complete scratch built F-15 50in pushers in one box to Phoenix for a friend that just had to have them, it can be done. I hope my try wonít ruin them so it might be possible if needed. I made the foam laminated so it can split right down the middle to make it easy to get the halves. Snowed in and maybe no work tomorrow so the fuse should be ready for the next step soon.
Old Feb 01, 2011, 10:18 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
so what is your plan for the casting ...i picture a box that you supend the complete plug into to the split point ...or
Old Feb 02, 2011, 02:56 PM
St. Peters MO.
Joined Nov 2007
Rodger,
Yes, I will build a plywood box and maybe add some rebar along the sides so it wonít snap in half. I think either fill the box and sink the supported fuse half in to the plaster or add a foam bottom and silicone the fuse half down flat then flip the box and remove and hope the mold release does its job. I believe thatís how Dan has been making his parts.
I plan on painting the fuse to start and then spackle and sand. Then for the final coats add epoxy paint like you guided me on the duct plugs. Not sure what more would be needed than that to get it ready. The split it down the middle with finished halfs and just clean up the edges.
Old Feb 02, 2011, 03:14 PM
GGRN is offline
Find More Posts by GGRN
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Originally Posted by Jack Brewer View Post
50mm F-11 Tiger photos.
The big black blob is my helper, he watches everything I do on planes. He never hurts them.
You're doing a nice job on the Tiger... I like your helper, he's like my black Gollum !
GGRN is offline Find More Posts by GGRN
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
Discussion Anyone have a tracing of the bulkheads for the Berkeley Grumman F11F Tiger? byrocat Electric Ducted Fan Jet Talk 7 Jan 14, 2009 02:20 PM
Build Log Living Room Jet - F11F Tiger 1/48 metroidrc Scratchbuilt Indoor and Micro Models 60 Feb 17, 2008 08:56 PM
