Espritmodel.com Heli Air
Old Mar 02, 2012, 08:26 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Originally Posted by AIR SALLY View Post
it's getting there ..one sugestion ...put a rounder nose on the airfoil..at our reynolds # it will hunt ....up and down ,a softer Le will fly smoother. dont ask how i know.
found that one out the hard way too. the results weren't pretty.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Mar 03, 2012, 07:29 AM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Looks fantastic Jeff!
If you guys have a pic of how to do nose gear doors with 1 servo to both doors I could use a visual.
I spent (wasted) a bunch of time trying to figure out how to do the doors on my Coug' with only one servo. Finally gave in and put a servo on each door. Glad I did. Cheap & easy to set up.
I'll try to get some pics up soon.
Don't know if you've seen this sequencer. Got one of these on the Cougar too, really cool.
Julian
Boogie_ is offline Find More Posts by Boogie_
Old Mar 06, 2012, 08:36 PM
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Thanks guys for the words of confidence,
Rodger, I hear you on the wings. I have a thick root at the fuse and Dan tapered it from there to fit the Tiger wing shape.
Julian, I see a lot of time in mine also but I have more room to work with than in your Panther. Any help would be appreciated.
Here is the start of the ducting. A little more shaping and it will be there.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Mar 06, 2012, 10:41 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
ducts look good ...are you doing a one piece duct ? or will you split them into a left and right side? ...one piece ducts are a bear to layup .and get off the plug .
AIR SALLY is offline Find More Posts by AIR SALLY
Old Mar 07, 2012, 08:59 AM
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
Nice!
Here's some shots of my gear doors and servos.
Julian
Old Mar 09, 2012, 07:22 AM
St. Peters MO.
Joined Nov 2007
Rodger,
I will split the ducts. They will also be used for the wing tube structure support. They are getting close with just a little more fit and final sanding needed. I should be coating them with spackle this weekend.
Julian,
Thanks, those are perfect pics and show them very well. Man the belly of your Panther look great.
Old Mar 15, 2012, 08:21 PM
St. Peters MO.
Joined Nov 2007
The weather here has been phenomenal all week, batts charged for the PZ Mustang, rocket Texan and HL Panther all needing a maiden then the thunderstorms popped and rain now. Maybe in a few days. It did give me a chance to finalize the spackle and get the ducts primed for final epoxy coat. I will have them glassed this weekend. The duct shape tucks over the wheels and retracts clean.
Old Mar 15, 2012, 10:25 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
real nice ....good looking well shaped ducts
Old Mar 17, 2012, 09:44 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Sweet, progress!
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Mar 17, 2012, 08:17 PM
turbonut's Avatar
upland CA
Joined Dec 2004
purrrdy parts man!!!!
Old Mar 18, 2012, 07:46 PM
St. Peters MO.
Joined Nov 2007
Thanks Guys,
Rodger and John your tips have always pointed me in the right directions when making these things. You would like these. I used 2 layers of 5.6oz Eglass.
Old Mar 19, 2012, 01:06 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
hey now those are sweet ...i have some comp. now i tought you too well ....seems i remember Earnhart saying that about Jeff Gordon after he beat Dale for his first win your builds are really cool .i got to get back to scratch building ......just dont have the time anymore.
Old Mar 19, 2012, 09:46 AM
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
So Jeff,
you about ready to cut some wings...
Dan Eaton
eatond is offline Find More Posts by eatond
Old Mar 20, 2012, 07:14 AM
St. Peters MO.
Joined Nov 2007
Dan,
I’m working on the gear door fitting right now along with finishing up the ducts. The ducts still need to be joined and the splitter plate added down the middle. I also have 2 wing spars to run through them. The wings foam cutting should be soon. Do you want to cut your F15 cores at the same time?
Old Mar 20, 2012, 03:00 PM
eatond's Avatar
Joined Nov 2002
Hi Jeff,
that'll work.
Dan Eaton
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
Discussion Anyone have a tracing of the bulkheads for the Berkeley Grumman F11F Tiger? byrocat Electric Ducted Fan Jet Talk 7 Jan 14, 2009 02:20 PM
Build Log Living Room Jet - F11F Tiger 1/48 metroidrc Indoor and Micro Models 60 Feb 17, 2008 08:56 PM
