Old Sep 23, 2011, 12:31 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
most guys add a layer where the fan,tail bulk heads are (use 2" wide fiberglass tape ) you'll need some beef where the gear mounts are ,i would have the gear mount pick up the fan mounting rails ,and you'll need some kind of plywood spar carry through former, if you use foam you'll need to glass both sides of the foam like i did in my draken build.the mid wing planes are a bit of a pain when it comes to carring the loads through the fuse .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Sep 23, 2011, 06:31 PM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Comin' right along Jeff.
BTW - Have y'all got any more flights on the 105?
I'm up to 16 flights on mine. ...then burnt the motor.
Julian
Boogie_ is offline Find More Posts by Boogie_
Old Sep 26, 2011, 07:25 AM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Julian
Julian,
With that many flights on your 105 I bet you had it running perfect. I donít remember what motor you were running but I have a 4s HET with maybe a dozen flights just sitting around attached to a sweet Air Power fan up for grabs. Greg and I have adjusted the CG and its ready but we have not flown it again. We also added a ballast pack for when we run the tanks because they are behind the CG. Giving it more flights should be soon. We are switching out weekly fly night from Tuesdays to Sundays. That should give us options for better light.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Oct 06, 2011, 09:24 PM
St. Peters MO.
Joined Nov 2007
The steps I have been working on are the bulkhead placement. I need enough of them to have the carbon rods supporting the interior components. The Battery tray, nose gear up front and fan and tail sections in back. The plan is to have a full moving elevator with a single servo control. The gear also made it in today and should mate up to the electric retracts well.
Old Oct 07, 2011, 05:13 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looks great Jeff!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 07, 2011, 07:06 AM
mrshea is online now
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
outstanding. Phil
mrshea is online now Find More Posts by mrshea
Old Oct 07, 2011, 09:12 PM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2017, June 15-18th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Jeff,
she's coming along nicely. What are you planing to do for wings? Foam cores or build up?
Dan Eaton
eatond is offline Find More Posts by eatond
Old Oct 09, 2011, 09:22 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looking good ...thats a lot of bulkheads ...but if there depron it wont add much weight.it's all down hill now,the hard part is over.
Old Oct 09, 2011, 10:28 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Looking great Jeff!
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: AJ-2 Savage
Old Oct 10, 2011, 10:30 AM
St. Peters MO.
Joined Nov 2007
Originally Posted by eatond View Post
Hi Jeff,
Dan Eaton
Dan,
The plan is to make the wings a foam core balsa skin and light glass. With no gear mounted in them the structure should not be to bad. That method will also be a first time for me but after the fuse mold and glass pull, confidence is high.
Old Oct 10, 2011, 12:08 PM
St. Peters MO.
Joined Nov 2007
Hay Rodger/ John,
Yah, I’m going to start duct layout next and squarer those bulkheads on the carbon rods. I have the bulkheads laid out on the drawing so it will allow me to get the spacing correct and look at structure points for gear and fan. I know Brent recommended just strengthen the glass fuse but its thin and flexible so foam bulkheads was my best option.
Old Oct 10, 2011, 06:27 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
if you glass both sides of the foam bulkheads it will get real strong ...and not add much weight.i did that on gear,spar,and fan bulkheads in the draken.
Old Oct 18, 2011, 07:13 PM
FLYBOYRC40 is offline
Find More Posts by FLYBOYRC40
Go Electrics
FLYBOYRC40's Avatar
St. Peters, MO
Jeff, great looking build. You are going to make a wire cutter for the wings?
FLYBOYRC40 is offline Find More Posts by FLYBOYRC40
Old Oct 22, 2011, 11:44 AM
St. Peters MO.
Joined Nov 2007
Rodger,
I will plan on glassing to reinforce those areas. Thanks
Greg,
Not sure how I will get the wings shaped. One good thing they are not a complicated shape but they are very thin.
Right now I am looking at gear placement so I have an idea for ducting room. The gear is looking OK and I have clearances.
Old Oct 22, 2011, 02:07 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Just been studying how to mount gear on my build( he162)Looks to have similar setup.Are those alu.rails on the mains? I was thinking about lt ply plate,your set up look neat.Looks easy to adjust before fixing.
Thanks Stuart
Stuart A is offline Find More Posts by Stuart A
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
Discussion Anyone have a tracing of the bulkheads for the Berkeley Grumman F11F Tiger? byrocat Electric Ducted Fan Jet Talk 7 Jan 14, 2009 02:20 PM
Build Log Living Room Jet - F11F Tiger 1/48 metroidrc Scratchbuilt Indoor and Micro Models 60 Feb 17, 2008 08:56 PM
