Old Jan 20, 2011, 08:19 AM
MMAdams123 is offline
Find More Posts by MMAdams123
Joined Jan 2011
MSR main rotor blade issue...
i've had my MSR for about a week and last night after a good flight and then small crash i noticed when i take off it starts to automatically lean to the right or it will just go backwards at take off. after this happened i noticed on the heli that the main rotor blade was a little loose where the screw holds it in place. i tightened that this morning and i'm still having the same problem. any ideas?
maybe i need to tighten those screws all the way?
any help would be great.
-BA
MMAdams123 is offline Find More Posts by MMAdams123
Old Jan 20, 2011, 09:17 AM
vicovaludemero is offline
Find More Posts by vicovaludemero
vicovaludemero's Avatar
USA, NY, Cedarhurst
Joined Mar 2010
your swash separated... use the red tool to pop it back in place... Also, I bet the anti-rotation pin popped out of its 'goal post', pop it back in...
vicovaludemero is offline Find More Posts by vicovaludemero
Discussion Blade MSR Anhedral Main Rotor Mod Loggerhead Micro Helis 40 Feb 11, 2011 04:37 PM
Found MicroHeli MSR Main Rotor Hub And Anti-Rotation Collar nitrodude71 Aircraft - Electric - Helis (FS/W) 2 Oct 28, 2010 08:04 AM
Discussion Flying the MSR in very dark room using the rotor blade disc as reference EQMOD Micro Helis 18 Sep 14, 2010 02:48 AM
