Old Jan 20, 2011, 06:33 AM
NeilMac is offline
Find More Posts by NeilMac
Somerset, UK
Joined Jan 2007
Midwest Seguin?
I have just bought a slightly damaged Seguin. It is an earlier model as it's plank on frame and it appears to have been a display model as there are no signs of it ever being fitted out with running gear.
I am going to install a steam plant, but can anyone tell me the weight of a Seguin ballasted to the water line?
It's 39" long, but not nearly as deep or beamy as any of my other tugs, so I'm not sure what plant will suit it.
Neil
NeilMac is offline Find More Posts by NeilMac
Old Jan 20, 2011, 02:51 PM
Shaun Hendricks is offline
Find More Posts by Shaun Hendricks
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
A small V or in-line twin should power that around nicely. Depends on your budget and how finished you need the motor to be.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Jan 20, 2011, 04:06 PM
NeilMac is offline
Somerset, UK
Joined Jan 2007
I was thinking about using one of my Cheddar Puffins, but the model is very lightly built and I think that it would be overpowered, that's why I was asking if anyone knew the ballasted weight.
Old Jan 20, 2011, 07:02 PM
Well, a V style would sit lower in the hull than an in-line, but a 39" model is going to have a LOT of displacement available. I don't know how much a Puffin weighs.
Old Jan 20, 2011, 07:12 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
The Seguin isn't that heavy... but it was designed for commercial model steam plants. Most anything that fits will be ok.
patmat2350 is offline Find More Posts by patmat2350
Old Mar 21, 2011, 06:54 AM
NeilMac is offline
Somerset, UK
Joined Jan 2007
Well the Maccsteam 3.5" boiler arrived today, perfect timing, as I have just finished varnishing the hull.
In the end, I decided to use my Gage TVR1A engine.
Old Mar 21, 2011, 10:41 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Ooooh, that looks nice in there! More photos of your TVR1A please?
Kmot is offline Find More Posts by Kmot
Old Mar 21, 2011, 10:53 AM
NeilMac is offline
Somerset, UK
Joined Jan 2007
Just tank (bath) tested her, and she just needs a little weight in the stern to get right onto the water line.
The engine is just a bog stock TVR1A finished in blue enamel. Not too pleased with the finish, as it has already chipped and is all but impossible to refinish neatly.
I have to make base plates for the engine and boiler and also work out where the gas tank will live. Not happy that the throttle valve I bought requires a 90 degree servo action, which will be difficult to achieve, so I might use an alternative valve that I made for an oscillator quite some time ago.
Trying to make it all neat and functional which is not always straightforward... at least not for me.
Neil
Old Mar 21, 2011, 10:43 PM
peconic steam is offline
Find More Posts by peconic steam
peconic steam's Avatar
Long Island, NY
Joined Dec 2007
Neil, You will have more than adequate power with the Maccsteam 3.5 and TVR1A set up you've provided. I think you'll need to be raising the waterline forward a little, though- Nice boat / steam plant combination!
peconic steam is offline Find More Posts by peconic steam
Old Mar 22, 2011, 12:40 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Nice looking boiler.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Mar 22, 2011, 02:09 AM
NeilMac is offline
Somerset, UK
Joined Jan 2007
I have just used the engine I had that would turn a nice big propeller; given how light the model is, I think it will have an excess of power.
The waterline does not look right to me, but it is as the original builder had it, and until after the first sailing trials I'll leave it alone. It would only be a matter of some weight in the bow (where there is plenty of space) and I could soon raise it.
Old Mar 22, 2011, 10:55 AM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Airplane servos normally come with +/- 45 deg action ( a little less than 90deg total swing). You can increase that with a computer radio such as the Spektrum, I do that all the time for my square riggers. If you want even more servo swing, a "servo doubler" can be purchased - this will give you 160-170deg total swing with no modification of Hitec HS-82MG or HS-225MG. Other servo brands likely do the same, I've not tested them.
Brooks is offline Find More Posts by Brooks
Old Mar 22, 2011, 01:25 PM
NeilMac is offline
Somerset, UK
Joined Jan 2007
Servo doubler sounds interesting. I'll look into that, thanks.
Neil
Old Mar 23, 2011, 05:24 AM
dunc2504 is offline
Find More Posts by dunc2504
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi.
What make of throttle valve did you go for , only I suspected I would need 90 deg on mine , but in practice I never needed fully open , as it was at full throttle long before that.
I only needed the first 30 to 40% of movement.
That was the valve on the Allison II and the same boiler / engine combo that you have .
Dunc2504
dunc2504 is offline Find More Posts by dunc2504
Old Mar 23, 2011, 05:41 AM
NeilMac is offline
Somerset, UK
Joined Jan 2007
I got this from RDG Tools, I think it's made by 21st Century Steam.
Sold Midwest Seguin Tugboat Kit Bob SF Boats (FS/W) 1 Nov 07, 2010 08:48 AM
Question Midwest Seguin Tugboat mrbassman Scale Boats 0 Sep 28, 2007 10:05 AM
Discussion Powering the Seguin Tug from Midwest Captain U-96 Scale Boats 0 Jun 29, 2007 04:11 AM
Question midwest seguin pedsdoc Scale Boats 3 Sep 27, 2006 06:10 PM
Seguin tugboat vett Boats (FS/W) 2 Mar 06, 2005 11:52 PM
