View Poll Results: Which motor?
2 Gram 2 20.00%
3.1 gram 6 60.00%
lower kv but more expensive 3.1 gram 2 20.00%
Voters: 10. You may not vote on this poll
This thread is privately moderated by AddictedToRC, who may elect to delete unwanted replies.
Old Jan 19, 2011, 09:01 PM
AddictedToRC is offline
Find More Posts by AddictedToRC
Airplane Dope
AddictedToRC's Avatar
USA, WI, Rio
Joined Nov 2009
Build Log
ParkZone UltraMicro T-28 Brushless Conversion
I'm going to convert my PZ UM T-28 to Brushless. I'm going to get the motor and ESC from HobbyKing. There are 3 motors that I'm considering: A cheap Hextronic 2gram motor; a kinda expensive 3 gram motor; and another even more expensive lower Kv 3 gram Motor(Both 3 grams are AP03's.). Maybe even the AP05? Any comments welcome.
EDIT: I don't have much money to use on it, so I kinda want to keep it cheap. What do I need: More torque or more speed? (lower or higher KV)
AddictedToRC is offline Find More Posts by AddictedToRC
Old Jan 30, 2011, 11:03 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
Lower KV = more torque but slower top end speed higher KV = less torque but faster top end speeds.
another really good source for cheap motors is WWW.RCTIMER.COM
RogueTitan is offline Find More Posts by RogueTitan
Old Jan 31, 2011, 09:42 AM
Airplane Dope
USA, WI, Rio
Joined Nov 2009
Thanks! So which one should I get?
Old Feb 06, 2011, 07:36 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
The 2 gram motor looks a bit small. I would go with the "AP05" or "AP03", along with the turnigy 3 gram BL ESC.
Most people use those for Ultra-Micro conversions, and have great results.
microflitedude is offline Find More Posts by microflitedude
Old Feb 06, 2011, 10:47 PM
Airplane Dope
USA, WI, Rio
Joined Nov 2009
Yeah, the AP03 is 3.1 grams, and that's what I'm thinking of. Should I get lower or higher KV?
Old May 31, 2011, 03:49 AM
Optic-Flare is offline
Find More Posts by Optic-Flare
Optic-Flare's Avatar
Australia, QLD
Joined Jan 2010
T-28 Brushless upgrade
I upgraded my T-28 for $38.37 and am very happy with it. The video has all the parts and pictures, & I just used the stock propeller.
Parkzone Ultra Micro T 28 brushless RC Plane conversion for $38.37 (3 min 4 sec)
Optic-Flare is offline Find More Posts by Optic-Flare
Old May 31, 2011, 08:47 AM
Airplane Dope
USA, WI, Rio
Joined Nov 2009
Originally Posted by Optic-Flare View Post
I upgraded my T-28 for $38.37 and am very happy with it. The video has all the parts and pictures, & I just used the stock propeller. http://www.youtube.com/watch?v=3ZvzvhjbTBY
Sweet! Right now I have a UM Scratchbuild because my Trojan quit working, so I used the guts. But my RX board isn't working, and a friend gave me some electronics so I bought an RX and battery and I am starting a Build Log here: http://www.rcgroups.com/forums/showthread.php?t=1448176
Old Apr 10, 2013, 09:38 PM
Nsmith89 is offline
Find More Posts by Nsmith89
Joined Apr 2013
brushless conversion um t28
I done the brushless conversion for um t-28. Every thing i used came form horizonhobby for around $65. Alot faster an still just as stable.
Part #s
BL 180 brushless outrunner 2500kv
EFLUM180BL2
Spinner
EFLU4851
Prop Adapter
EFLU4067
Eflight 5amp pro brushless ESC
EFLA1005
Motor mount/firewall came from umx beast3D that was crashed. Every thing turned out nice an cog was great. The motor mounted were stock motor was, I had to remove the front landing gear an mount for esc. Im still useing the ar6400 that came in my um t28 so i still have rudder an elavtor controls. I'll post pics shortley.
Nsmith89 is offline Find More Posts by Nsmith89
Old May 31, 2013, 05:32 AM
vondetour is offline
Find More Posts by vondetour
Germany, BY, A
Joined May 2013
total nube here,can you give me more details on the t28 brushless conversion.
vondetour is offline Find More Posts by vondetour
Old Jul 26, 2015, 03:09 PM
zewill is offline
Find More Posts by zewill
Canada, AB
Joined Dec 2014
Im getting into the conversion for my t28 um it seems the motor is stopping after 10seconds of flight and I lack a lot of power.
First off, what decides if we do 1s or 2s conversion? I guess advantages of2 s is more power? Disadvantage is I guess you need to buy 2 s batteries ??
I would be using my stock Trojan um and getting only a motor and an esc. I wanna keep it cheap so I was goin to get it all from aliexpress in china :
6 dollars for SKYI 6A 2S LiPo Battery Brushless Motor Electronic Speed Controller ESC With 5V/0.8A Linear Mode BEC for RC Fixed Wing Airplane
And 10 bucks for RC Hobby Motor 1811-2000 18-11 2000kv Micro Brushless Outrunner (10g)
Spec.
Model: 1811-2000
Kv: 2000rpm/v
Weight: 10g (With wires and mount)
Suggested Prop: 7x5
Suggested Power: 7.4v
No Load Current: .4a
Thrust: 130g / 5000rpm
7.4v no-load speed: 15000rpm
Peak Eff Current: 5.5A
Shaft: 2mm
Diameter: 18mm
Length: 30mm (including mount & shaft)
Does that seem like the plane will perform? Is the esc And Motor ok'? What batteries should I be getting?
Thanks guys!
zewill is offline Find More Posts by zewill
Sold Parkzone UltraMicro T-28 with Canopy Mod j5cub Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Oct 13, 2010 11:03 PM
Found Parkzone P-51 Brushless BNF or Parkzone T-28 Trojan CGReload Aircraft - Electric - Airplanes (FS/W) 3 Aug 10, 2009 09:55 PM
Sold Parkzone T-28 480 brushless 960kv motor PKZ4416 $25 shipped MJB9 Aircraft - Electric - Power Systems (FS/W) 2 Jan 14, 2009 07:31 AM
Sold New Parkzone T-28 480 brushless 960kv motor and Eflite 30amp ESC Gravity Dodger Aircraft - Electric - Power Systems (FS/W) 1 Dec 15, 2008 07:40 AM
Discussion ParkZone T-28 Brushless Outrunner Specs? Please help! Randy -- Power Systems 3 Aug 30, 2008 04:32 PM
