Joined Jun 2009
Yes, really
from looking at the graph the thrust-power relationship is nearly linear. You can estimate that top thrust would be around double the 100W value, that is around 3 lbs (1.5 kg). That times 8 and you get 24 lbs and 1.6 kW (110ish A).Of course that's just a rough estimate, so take it with an appropriately large grain of salt
Ironbridge (UK)
Joined Jan 2009
I have 4 of these motors spare (28-36 750kv) 5 minutes test use only £8 each UK |
Since HK just released some NTM motors that are perfect for quads, someone needs to test them out.
Slightly smaller than the RCTimer motors but I think the quality will be higher, as well as efficiency.http://www.hobbyking.com/hobbyking/s...uct=16229&pb=1 |
VA
Joined Nov 2009
I can't speak for someone elses setup but I get 992.2g thrust at 12.4V 18.2A with 2830 750kv motor spinning APC12x3.8 prop. It is not the same motor but usually a set rpm for a given prop produces close to same thrust not taking efficiency into account.
| Thread Tools | |
| Sold AXI gold 2212/34 + ESC + folding 11-8 Graupner prop for sale | Disciple4123 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 13, 2011 08:53 PM |
| Wanted Graupner Elektro Junior S | Ak Eagle | Aircraft - Sailplanes (FS/W) | 0 | Oct 12, 2010 02:30 PM |
| Discussion Radian PnP $159 vs Graupner Elektro Junior S $132 | boiko | Parkflyers | 16 | Aug 10, 2009 11:39 AM |
| For Sale Thrust 20 +30A Quantum ESC+ prop adapter + 2x 11x5.5 APCs - Price Reduced | Codehead | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 04, 2009 09:59 PM |
