This thread is privately moderated by Arcteryxxx, who may elect to delete unwanted replies.
Old Mar 26, 2011, 02:52 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
I have programmed diff at +12/-6 as recommended.
I'll have it ready in a week or two for some more adrenaline rush. If the repair is unsuccessful I will order a new body...
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Mar 26, 2011, 03:42 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Ok, so that differential should help. Once you get it up again, I would take it up high and practice tip stalling. Make slow circles and see how the plane reacts. Remember you cannot bank these aircraft at slow speeds like the foamies. Feel it out up high and then you will be good to go.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 26, 2011, 04:26 PM
Arcteryxxx's Avatar
Joined Feb 2010
I will. Thanks for the tip. The nose needs a serious glassing job and that will help CG as well. The motor/esc seems a little too light to get the plane properly balanced with a 5S3000, so I guess my 5S2200 will be used next time.
Old Mar 26, 2011, 06:16 PM
You down with EPP?
Houston, Tx
Joined May 2009
Well tomorrow I will get to compare.
4S outrunner on a 13x6.5 folder
vs.
4S Inrunner(direct drive) on a 7x7
The watts on the inrunner setup are almost double that of the outrunner.
But I am eager to see the vertical performance of the ourtunner setup.
Gotboosted is repairing my Flash for me, I opted out of that kind of repair
It is nearing completion, I am eager to see it.
I don't know the first thing about fiberglass repair, carbon, ........
Old Mar 27, 2011, 12:10 PM
Arcteryxxx's Avatar
Joined Feb 2010
Looking forward to your report...
Old Mar 27, 2011, 12:19 PM
You down with EPP?
Houston, Tx
Joined May 2009
Some pics
I am pulling way too many amps for the Turnigy motor. Wish me luck!!!
I will keep throttle 3 second bursts
Static
90 amps
1318 watts
I am on my way out to the field. I will get a video.
Old Mar 27, 2011, 01:04 PM
Arcteryxxx's Avatar
Joined Feb 2010
Nice posing, Johnny!
Old Mar 27, 2011, 09:10 PM
You down with EPP?
Houston, Tx
Joined May 2009
Maiden didn't go well
I went for a straight vertical launch. 1.5 seconds in, the folder shot out of the front with motor shaft
I didn't have enough height or airspeed to recover, my elevator was useless.
Although, I hit full elevator and full left aileron to soften the fall which help prevent a lot of damage.
H-stab - not a scratch
Wing - not a scratch
fuse - not a blemish until you get to the goose neck right before the tail. SNAP!!!
Tail is cracked pretty good up towards the elevator.
Now is a good time to learn to glass. This will fly again and soon. I just need to make sure I do it the right way for strength.
I am going to start a help thread in the high performance section. I know a lot of dudes have snapped the fuse in the same place.
Old Mar 27, 2011, 11:32 PM
Arcteryxxx's Avatar
Joined Feb 2010
Very sorry to hear that, Johnny!
I'll be subscribing...!
Old Jun 26, 2011, 12:25 PM
Arcteryxxx's Avatar
Joined Feb 2010
Finally this one is flying like it should!
Balances right with a 5S2200 battery - anything bigger or longer it gets too tail heavy with the NEU1115 / KPG 25 combo.
Old Jun 26, 2011, 04:37 PM
You down with EPP?
Houston, Tx
Joined May 2009
Nice, good to see you are flying it.
I'll get some video of my "flash gone F5d"
How many amps are you pulling on that setup?
Old Jun 26, 2011, 04:53 PM
Arcteryxxx's Avatar
Joined Feb 2010
Static testing earlier showed appx 110Amps / 1850Watts. 8230rpm on the 15x16 RFM prop.
Old Jun 28, 2011, 05:26 PM
Arcteryxxx's Avatar
Joined Feb 2010
Better video. Some editing, nice music and no Norse blabbering....
V-max ECO Hotliner maiden (2 min 18 sec)
Old Jun 28, 2011, 10:14 PM
You down with EPP?
Houston, Tx
Joined May 2009
well..... the commentary is good.
Mega 16/40/1.5rc
graupner 5x5
Hyperion 5S 3300mah 45C
Flash II F5B flown with pylon setup (5 min 57 sec)
Old Jul 01, 2011, 12:26 AM
Arcteryxxx's Avatar
Joined Feb 2010
Mega 16/40/1.5rc
graupner 5x5
http://www.youtube.com/watch?v=sxLebPSSSZM
What do you think of your setup here? Enough speed and thrust?
Discussion Ikarus Enthusiast Thread, Eco 8, Eco 16, Royal That can fly?!? Large Electric Helis 93 Oct 22, 2014 06:23 AM
Help! 3CH V-Max TY901 Helicopter presa1200 Electric Heli Talk 3 Dec 04, 2010 06:34 PM
Wanted OS91 Max V Ducted Fan engine SaltySteve Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 24, 2010 02:13 AM
Discussion Helpppppp with V-Max / Falcon X :-( xxjoshstarxx Coaxial Helicopters 22 Oct 14, 2010 03:34 PM
Discussion Helpppppp with V-Max / Falcon X :-( xxjoshstarxx Micro Helis 2 Oct 14, 2010 12:56 AM
