This thread is privately moderated by Arcteryxxx, who may elect to delete unwanted replies.
Old Feb 14, 2011, 04:22 AM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Problem solved
Thanks guys!
I cut the shrink, removed the servo and since the epoxy/talc had only cured for 10 hours I was able to remove it like old bubble gum from the sole of a shoe.
Fixed a new servo horn, new shrink wrap and glued it back in. Phew.....
Chipped a small part of the side of the servo bay recession but it will be hidden nicely by the servo cover.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Feb 14, 2011, 03:29 PM
Arcteryxxx's Avatar
Joined Feb 2010
Tonight was the final real building night - from now on there are just minor adjustments, mounting servo covers and then.......waiting for the snow to melt!
60cm of snow and -12C doesn't seem like spring
AUW weighed in at 1,621kg or 3p 9,1oz. Just a tad heavier than I expected.
CG on first try was at 75mm behind LE. Recommended CG is 70-75. Think I will try to move the ESC a little bit further fwd to get CG at 70 and to give more space for the wires. It is a Full House in there with the 5S3000!!!
I want to thank Gotboosted and JohnnyR for invaluable inputs! Much appreciated, Dudes!!!!
Here are some pictures of the result:
Old Feb 20, 2011, 12:19 AM
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Looking great Arctery!
Must admit I'm a little envious and am spending time on the Soaring USA website.......
Peter M is offline Find More Posts by Peter M
Old Feb 20, 2011, 01:07 AM
Arcteryxxx's Avatar
Joined Feb 2010
Thanks, Peter
Since you are looking at webshops outside Aus, you might want to check up on these sites as well:
www.lindinger.at
www.modellhobby.de
The mercury shows -20C this morning
Jeeez this winter is annoying!
Old Feb 20, 2011, 03:37 AM
Peter M's Avatar
Joined Sep 2007
Thanks for the links but the current $AUD to $US exchange rate is much more attractive than buying in Euros!
I've been looking at this for the last fortnight: http://www.soaringusa.com/products/p...ategory_id=262. Really I need to finish some builds and crash more before I buy another plane!
As for the weather, if we could just average your -20 with our 38, we both might be doing a lot more flying than we currently are.......
Old Feb 20, 2011, 04:43 AM
Arcteryxxx's Avatar
Joined Feb 2010
Yeah! The Enigma Rocks!!!!
With a NEU 1512 it goes like this:
Kevin flying the Enigma Hotliner at Kite Hill (8 min 13 sec)
Like I always do, I have already started looking for the next one (I really shouldn't - but can't help it)
No rush, but dreams are centered around Raketenwurm 2B and Surprise XIV and XVI....
Old Feb 20, 2011, 10:14 AM
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
did you get the speed control worked out?
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Feb 20, 2011, 10:32 AM
Arcteryxxx's Avatar
Joined Feb 2010
Not yet. Might try fixed throttle travel instead of auto detect. I hope to look into it tonight. Have you experienced the same with yours?
Old Feb 20, 2011, 11:41 AM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I have a Flash II Carbon which is the Enigma with a slightly shorter wing. Plenty of room for big cells in the fuse, and from what I hear one of the strongest wings out there in F5B.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Feb 20, 2011, 01:24 PM
Arcteryxxx's Avatar
Joined Feb 2010
Johnny: are you using a 36mm ARC in your Flash?
Old Feb 20, 2011, 01:29 PM
You down with EPP?
Houston, Tx
Joined May 2009
I was, yes.
Old Feb 20, 2011, 01:55 PM
Arcteryxxx's Avatar
Joined Feb 2010
What is your favorite setup so far?
Old Feb 20, 2011, 02:19 PM
You down with EPP?
Houston, Tx
Joined May 2009
Well you must remember that I went the cheap route and did not set it up like a "hotliner". My setup was direct drive, basically what you would run on a Stryker. 36mm inrunner, 7x7 prop. I started with 4S 4900mah packs and went to a 5S 3300mah pack.
When I increased the cells, I kept the same prop but went from a Phoenix 80 to an Ice 100 controller.
Speed was only around 125mph. I didn't have the thrust needed for speed. Plus the fact that I could not gain good momentum in a dive with a fixed prop.
None the less, it was still my favorite plane. Very fun to fly. The speed did amaze spectators when they saw the size of the prop.
Remember, we are talking about a 65" wing with a 7" prop. It was ridiculous, but a lot cheaper than a gear box, HV125, good 16x17 folder.....etc
Old Feb 20, 2011, 07:32 PM
zoom zoom
USA, NJ, Mt Laurel
Joined Oct 2007
No worries.. Should be done soon
When you gonna call? Tonight would be good for me..
Old Feb 20, 2011, 07:35 PM
You down with EPP?
Houston, Tx
Joined May 2009
I will try you tomorrow. I have no voice, I am on day two of the flu.
already called into work
Discussion Ikarus Enthusiast Thread, Eco 8, Eco 16, Royal That can fly?!? Large Electric Helis 84 Mar 08, 2012 03:03 PM
Help! 3CH V-Max TY901 Helicopter presa1200 Electric Heli Talk 3 Dec 04, 2010 06:34 PM
Wanted OS91 Max V Ducted Fan engine SaltySteve Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 24, 2010 02:13 AM
Discussion Helpppppp with V-Max / Falcon X :-( xxjoshstarxx Coaxial Helicopters 22 Oct 14, 2010 03:34 PM
Discussion Helpppppp with V-Max / Falcon X :-( xxjoshstarxx Micro Helis 2 Oct 14, 2010 12:56 AM
