| Thread Tools |
| This thread is privately moderated by Arcteryxxx, who may elect to delete unwanted replies. |
I bought it at an Austrian HS. www.lindinger.at
Yes that tape creates a stronger attachment then the bolt.
The cooling hole is a good idea. Dont forget to get a larger hole in front of the motor, in place of the larger hole you can add one on both sides of the nose. Its best to do it before you mount the firewall so you can add a layer of glass and or carbon to reinforce the structure. |
![]() Looks like I'm limited to the airflow from the turbo spinner. Luckily I do have MPI heatsink on the motor... |
Wing is molded GF with CF reinforcement. I do see some wood in there but I'm not sure how much it is of that. Maybe just around the servo bays... |
Static testing 5S
Did my first static test on Zippy 5S3000 40C today.
Neu 1115/1Y, Kontronik 5,2:1, RFM 15*16 prop, Zippy 5S3000 40C. Peak 110Amp, 1860Watt. Volt minimum: 16,56. RPM: 8230 Think I could use a better lipo and get to 2kW... |
| Thread Tools | |
| Discussion Ikarus Enthusiast Thread, Eco 8, Eco 16, Royal | That can fly?!? | Large Electric Helis | 84 | Mar 08, 2012 03:03 PM |
| Help! 3CH V-Max TY901 Helicopter | presa1200 | Electric Heli Talk | 3 | Dec 04, 2010 06:34 PM |
| Wanted OS91 Max V Ducted Fan engine | SaltySteve | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Oct 24, 2010 02:13 AM |
| Discussion Helpppppp with V-Max / Falcon X :-( | xxjoshstarxx | Coaxial Helicopters | 22 | Oct 14, 2010 03:34 PM |
| Discussion Helpppppp with V-Max / Falcon X :-( | xxjoshstarxx | Micro Helis | 2 | Oct 14, 2010 12:56 AM |
