This thread is privately moderated by Arcteryxxx, who may elect to delete unwanted replies.
Old Jan 18, 2011, 04:27 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Build Log
V-max ECO
Well here we go again...
This years project will be my first molded Hotliner - The V-max ECO with a 67" span.
This airframe is also known as the Graupner Speed, Staufenbiel Hawk, Wilco, LanYu, F5B Tiger and is a well proven bird.
I will build mine using Dymond D60s in the wings and a Hyperion Atlas 11 AMB digital "MG-B" servo in the tail.
The rest of the planned setup:
NEU 1115/1Y (finally I've got good use of it!)
Kontronik KPG25 5.2:1 gearbox
Suppo200A ESC
CC bec
RFM turbo spinner
RFM 15*16 folding
Lipos: GensACE 5S2200 30/60C
Here are the two pics I downloaded from the website:
More fotos will follow when I go to work!!!!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jan 20, 2011, 03:13 AM
Arcteryxxx's Avatar
Joined Feb 2010
And here is a video of what's to come...
Hawk F5B Teil 2.AVI (2 min 56 sec)
Old Jan 21, 2011, 11:56 AM
Arcteryxxx's Avatar
Joined Feb 2010
Delivered by UPS today, only two days after shipment from Austria
Must be a world record!
Old Jan 21, 2011, 11:59 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Sweet, start loading the pics. What's the wing length? I am not sure if I am posting correctly. I thought I remembered 67"
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 21, 2011, 01:11 PM
Arcteryxxx's Avatar
Joined Feb 2010
Fuse is 36" and the wing is 66,5". If you count in the curved profile of the wing tips the span will be 67.
Old Jan 21, 2011, 01:18 PM
Arcteryxxx's Avatar
Joined Feb 2010
This was in the box
I'll let the pictures do the talking...
Only things missing:
Motor/Gearbox/ESC/battery
Pushrods/clevises
Spinner/prop
RX
PS: Servos were not included......
Should be a quick build
Old Jan 21, 2011, 02:03 PM
You down with EPP?
Houston, Tx
Joined May 2009
Beef up that firewall. Milled fiberglass with 30 minute epoxy.
You might want to double up that frame mount.
Old Jan 21, 2011, 02:10 PM
Arcteryxxx's Avatar
Joined Feb 2010
I've ordered this firewall: http://www.modellhobby.de/Accessorie...30&c=124&p=124
What do you mean by doubling the frame mount?
Old Jan 21, 2011, 02:35 PM
You down with EPP?
Houston, Tx
Joined May 2009
I meant either double up that firewall or get a better one. Looks like you already took care if it.
Interested to know if there is ply wood in place in the fuse to bolt on the rear of the wing?
In other words, can you drill out a hole and install a blind nut to secure the wing at the back?
Old Jan 21, 2011, 03:08 PM
Arcteryxxx's Avatar
Joined Feb 2010
There are 5 nuts molded into the fuse: the three for the wing bolts and two for the horizontal stabilizer. No wood in the fuz at all. It seems like there are nuts molded into the ailerons for the bronze horns as well...
This seems sooooo different compared to what I'm used to with my heavy Strykers. Cakewalk!!!!! (Combination of "Piece of cake" and "Walk in the park". I know it also is the name of an old South State dance, but right now it seems like an appropriate name for this hotliner)
Old Jan 21, 2011, 04:53 PM
You down with EPP?
Houston, Tx
Joined May 2009
Hmm, do you mind taking a few photos of the three wing bolt holes? Also the inside of fuse when you get a chance. Looks good from the initial pics.
Have you measured the inside of the fuse perimeter yet? I know you are thinking "how big a pack?"
Old Jan 22, 2011, 06:01 AM
Arcteryxxx's Avatar
Joined Feb 2010
I stumbled across this German build log with some photos and explanations in the language of "ze Germans"....
http://www.prop.at/testber/2009/v_max_eco.html
And here is an English translation: (Thanks Google)http://translate.google.com/translat...v_max_eco.html
Old Jan 22, 2011, 03:44 PM
You down with EPP?
Houston, Tx
Joined May 2009
Can you actually fit the 4S 3000mah without trimming?
I am about to buy a few of those exact batteries for my Funjet Ultra. 40C!!
I have some thin Rhino 4S 4900mah 25C that would probably fit it for sure.
I had a very hard time finding a 5S that would fit in my Flash that was big enough to handle the amps.
I finally found the perfect one, Hyperion 5S 3300mah 35C.
Old Jan 22, 2011, 04:16 PM
Arcteryxxx's Avatar
Joined Feb 2010
I slipped the 4S3000 40C in the original hole but in a standing position. With the trimming it will be an easy fit laying flat on the fly floor I've planned. Guess I'll be in the market for some really slim and high-C 5S3000 LiPos
Discussion Ikarus Enthusiast Thread, Eco 8, Eco 16, Royal That can fly?!? Large Electric Helis 93 Oct 22, 2014 06:23 AM
Help! 3CH V-Max TY901 Helicopter presa1200 Electric Heli Talk 3 Dec 04, 2010 06:34 PM
Wanted OS91 Max V Ducted Fan engine SaltySteve Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 24, 2010 02:13 AM
Discussion Helpppppp with V-Max / Falcon X :-( xxjoshstarxx Coaxial Helicopters 22 Oct 14, 2010 03:34 PM
Discussion Helpppppp with V-Max / Falcon X :-( xxjoshstarxx Micro Helis 2 Oct 14, 2010 12:56 AM
