Old Jan 18, 2011, 04:52 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Welders Glue
I am having problems finding Welders glue/adhesive locally. Where are you all finding it. I have been to two different Wal-marts and neither had it. I am getting ready to make an EPP order which has UHU por, is the UHU por basically the same (better or worse) or keep trying to locate the Welders?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Jan 18, 2011, 05:01 PM
JBrant is offline
Find More Posts by JBrant
Joined Jul 2005
Welders found at Lowes
The only place I can find it is at Lowes. Some have ordered direct from the maker Homax Products, Inc. Home Depo does NOT carry it.
Jim
JBrant is offline Find More Posts by JBrant
Old Jan 18, 2011, 05:08 PM
Dan5.0 is offline
Find More Posts by Dan5.0
Joined Dec 2008
http://www.lowes.com/pd_74526-1168-7...&storeId=10151
...also most EPP kits on the market offer Welders too.
Dan5.0 is offline Find More Posts by Dan5.0
Reply With Quote  (Disabled)
Old Jan 18, 2011, 05:10 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Lowes is the only place I can find it as well. I almost didn't find it... I looked at the display area for adhesives and found nothing UNTIL I happened to see an endcap that had about 15 double tube packs this endcap was about 10-15 feet from where the rest of the adhesives were displayed
Edit to add:
The tubes I picked up were RED not the white tubes pictured above.
shultz is offline Find More Posts by shultz
Old Jan 18, 2011, 05:22 PM
mode1 is offline
Find More Posts by mode1
mode1's Avatar
Southwest Missouri
Joined Oct 2002
Also found mine at Lowes.
mode1 is offline Find More Posts by mode1
Old Jan 18, 2011, 05:24 PM
Dan5.0 is offline
Joined Dec 2008
All the stuff is the same, they even have the extra large silver tubes.
edit: silver tubes
https://www.hardwareworld.com/4oz-We...e-pIRUCR1.aspx
its like 4 tubes in 1
Old Jan 18, 2011, 06:57 PM
On loan to Texas
Joined Oct 2005
Thanks for the info - off to Lowes when I have a break.
Old Jan 18, 2011, 09:25 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
Ohio,
I normally find it in the paint department. Ask someone to type Welders glue or Welders adhesive into their workstation computer and it will tell you if it's in their store inventory and where it's located in the store.
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Jan 23, 2011, 09:55 PM
The Garthok is offline
Find More Posts by The Garthok
Joined Jan 2011
If you can't find the Welder's or UhU Por, the glue that I've found works the very best with all types of EPP foam,and dries the fastest also, is Quick Grip by Beacon Adhesives, I find it at Michael's and at my local hardware store.
The Garthok is offline Find More Posts by The Garthok
Old Jan 24, 2011, 12:12 AM
wyo69cowboy is offline
Find More Posts by wyo69cowboy
USA, WY, Cody
I just picked up the 2 pack of Welder's at my local Lowes; did not find it at Home Depot on an earlier search. Anyone care to address the original question: is it the same/better/worse than UHU? I have both, just curious...
wyo69cowboy is offline Find More Posts by wyo69cowboy
Old Jan 24, 2011, 06:04 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I have both, they're very similar in use. I've used UHU on EPP and it worked well. However, Welders will destroy Depron, FanFold and just about any foam that's not EPP.
Home Depot doesn't carry the Homax product. For those who don't have a Lowes nearby, you can order direct from the Homax web site.
Azarr
Azarr is offline Find More Posts by Azarr
Old Jan 24, 2011, 01:23 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Azarr
so where can you purchase the uhu por glue?
aerolite
aerolite is offline Find More Posts by aerolite
Old Jan 24, 2011, 01:54 PM
Scarface26 is offline
Find More Posts by Scarface26
Colorado Springs, CO.
Joined Mar 2009
RC foam out of North Carolina. They sell UHU POR & Beacon's Foam Tac which looks to be as good and is a lot cheaper.
http://rcfoam.com/cart.php?target=ca...category_id=90
Scarface26 is offline Find More Posts by Scarface26
Old Jan 24, 2011, 02:03 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
thanks for the info
aerolite
Old Jan 24, 2011, 02:54 PM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
lowes, near the paint section with all the adhesives.
heligrom is offline Find More Posts by heligrom
Discussion Welders glue in cold weather karlpenney Foamies (Scratchbuilt) 0 Jan 02, 2011 03:52 PM
My new lathes, mills, welders... Bob Chiang The Builders Workshop 1 Dec 16, 2004 04:56 AM
