Old Jan 17, 2011, 07:56 AM
emerge is offline
Find More Posts by emerge
Joined Oct 2010
bad turnigy battery?
Hi all, I own this turnigy 2200mAh 3S 40C battery with a strange cell. Look at the charging process:
starting with a lower voltage it gets full earlier, and it discharges faster than the other two cells, like having one 1000mAh cell and two 2200mAh cells.
Should I throw it or is there any way to get the full capacity?
I have another identical battery from the same order, it had a strange cell until the second charge, and now it's perfect.
thank you!
emerge is offline Find More Posts by emerge
Old Jan 17, 2011, 09:15 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps cycle it a few more times. Since you have already charged it it can not be returned.
Cycling LiPolys is a highly debated issue. Some say it is necessary and beneficial. some say it helps a little, some say it is a waste of time.
I like to do fairly easy cycles on my new LiPolys as over the past 5 years I have seen performance of quality cells improve during the firsdt 25 to 50 cycles if they are not abused from the get go.
everydayflyer is online now Find More Posts by everydayflyer
Old Jan 17, 2011, 09:22 AM
emerge is offline
Joined Oct 2010
thank you for your answer,
I don't stress my batteries, I use a charger with balancer (accucel 6) and I have very high cut-out voltages (I usually end flight with cell around 3,7v).
What voltage should I reach when discharging the pack?
I don't have nothing to loose (and I already ordered 3 other packs) so I can experiment a bit.
Old Jan 17, 2011, 02:25 PM
VROOMSTER is offline
Find More Posts by VROOMSTER
AMA #953123
VROOMSTER's Avatar
Eugene, ORYGUN
Joined Mar 2009
3.7 is a safe discharge level.
VROOMSTER is offline Find More Posts by VROOMSTER
Old Jan 17, 2011, 02:55 PM
emerge is offline
Joined Oct 2010
still cycling but the cell goes to 3.0v after about 1000mAh consumption.. it's strange cause this battery is exactly the same size of the other i bought.
anyone had luck with a similar battery? maybe being a 40C should I attach an huge load? this battery has already 3 flights with my 450 that I think consumes about 100w..
Old Jan 25, 2011, 08:00 AM
emerge is offline
Joined Oct 2010
guess what is the bad cell:
of course the external package was perfect.. I think this is gonna become a 2s 2200mAh battery
Old Jan 25, 2011, 08:52 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Technology saved you from a fire. Gotta love the new chargers.
Good find.
Rick
rampman is offline Find More Posts by rampman
Old Jan 25, 2011, 09:02 AM
emerge is offline
Joined Oct 2010
say hello to my new 2s battery:
I'll still buy from hobbyking, 1 broken cell is ininfluent compared to the savings I had with them!
Old Jan 25, 2011, 10:21 AM
TreeDiver is online now
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
hmmmm...hole in pack
I had it also...but because of small crash and bad meeting with bold
cell removed and pack ended into a 2s pack
TreeDiver is online now Find More Posts by TreeDiver
Discussion Received a bad battery and questionable support flyer2464 HobbyPartz.com 13 Oct 25, 2010 05:52 PM
Video My HZ SC with Turnigy 35-30 1100kv BL with 40A ESC Aerobatic STUNT GONE BAD!! t.korb Electric Plane Talk 4 Oct 24, 2010 01:42 AM
Question Bad battery ? Dennis Everett Batteries and Chargers 8 Sep 20, 2010 05:46 PM
Discussion Is a high C battery bad for your ESC? Tengler Batteries and Chargers 10 Sep 17, 2010 01:24 PM
Help! Bad Turnigy Motor or Bad E-Max ESC??? ty_horn Power Systems 24 Sep 11, 2009 08:11 AM
