Old Feb 01, 2012, 08:47 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
It was Flying fine.
Just with the new CX3X1000 gyro it did not like the vibration from the tail rotor shaft being bent.
Its not a big deal as it has been kinda Sh#@y out.
it did bother me today as it was realy nice out all day.
I do still have My blade 120SR as a back up
I did order a bunch on new cnc parts this week trying to get rid of all the plastic and just about got it all now but the battery holder and the Tail Drive Gear Set witch I well get next week.
boom block
Stabilizer Mount
Anti Rotation bracket
carbon fiber Tail Boom Brace
Black_heart is offline Find More Posts by Black_heart
Old Feb 03, 2012, 08:39 AM
doc7592 is offline
Find More Posts by doc7592
United States, PA, St Marys
Joined Dec 2011
what is the latest version of RTF? and cost?
doc7592 is offline Find More Posts by doc7592
Old Feb 03, 2012, 08:47 AM
Texas NewB
Joined Dec 2011
HAUSLER 450 SE V2 RTF version2
http://www.cermark.com/products/HAUS...version2.html#
Old Feb 03, 2012, 06:36 PM
mehere is offline
Find More Posts by mehere
mehere's Avatar
United States, MN, Anoka
Joined Jan 2012
Did you get your vibration fiqured out?
mehere is offline Find More Posts by mehere
Old Feb 03, 2012, 07:03 PM
Texas NewB
Joined Dec 2011
Yes it was a bent tail rotor shaft.
The new one is due in any day now.
Old Feb 03, 2012, 10:21 PM
coomarlin is offline
Find More Posts by coomarlin
Joined Jul 2004
Well I have to admit having an actual heli is kinda frustrating. I'm afraid to get this bird off the ground. Something is not right with this heli. Other than checking bolt and screw tightness I haven't changed anything on the heli. When I throttle it up it wants to tip over to the right immediately. I apply full left trim and it still wants to tip right.
I installed the TX software but I'm not really sure what the settings are telling me. When I move the sticks I see multiple channels moving at one time which I did not expect. It's like several channels are bound together. I wish there was a more clear concise user guide to explain how to set this heli up properly. I can fly multirotors fine and I can fly 3d helis on simulators but I fee lost trying to set this heli up properly.
coomarlin is offline Find More Posts by coomarlin
Old Feb 03, 2012, 10:30 PM
Texas NewB
Joined Dec 2011
Is your swash plate level?
are you saying that if you move one stick one way more then one moves the same amount in the monitor screen?
the only one that well have more then one move at a time should be the throttle.
this is because it dose both throttle and collective pitch.
the others should only move one at a time you may see minor move ments in the ajassent due to minor movements in the sticks.
"move elevator up you may move a little aileron cause by not moving stick precisely straight up and down."
Old Feb 04, 2012, 06:22 AM
shurlock1 is offline
Find More Posts by shurlock1
Joined Jul 2005
When I got mine I had to tighten every screw with Loctite. Dont understand why this wasnt allready done befor they shipped it.
shurlock1 is offline Find More Posts by shurlock1
Old Feb 04, 2012, 08:30 AM
monkeyhanger is offline
Find More Posts by monkeyhanger
monkeyhanger's Avatar
Canada, ON
Joined Mar 2010
Totally normal. On a collective pitch heli, the 3 cyclic servos all work together. Moving the throttle up/down affect 4 channels (throttle and 3 cyclic servos).
Moving the right stick forward will make the 2 front servos go down, and the back one will go up. Moving the right stick back will move 2 cyclic servos up, and one down. Moving the stick right will make one servo go up, and another will go down...etc etc etc.
This is called CCPM mixing...and again, totally normal.
monkeyhanger is offline Find More Posts by monkeyhanger
Old Feb 04, 2012, 09:10 AM
Joined Jul 2004
I'm not sure if the swash plate is level or not. I'd assume not.
Here is what I did last night.
I took the both blades off, centered all sticks and trims. Pushed both switches back and set both dials to 12 o'clock. When I applied throttle the flybar did not rotate level. It rotated with the low end on the right side of the heli and the high end on the left side. Applying left aileron (I'm a plane guy) it barely made the flybar move. I put the aileron trim all the way to the left and it still wasn't enough to level out the flybar.
Is there a step by step checklist and startup proceedure thats available so I can walk through the troubleshooting step by step and zero in on what is wrong?
As for the mixed controls I'm glad to hear they are premixed and are supposed to work together. For a minute I thought it was completley jacked up.
Old Feb 04, 2012, 09:34 AM
Canada, ON
Joined Mar 2010
If you want to see the mixing in action, turn the head so that the blades are 90 degrees to the boom, and the flybar is parallel with the tail boom, and also level. Hold the flybar paddles stationary, and THEN move your right stick up and down (elevator). Your main blades should change pitch.
Move the right stick left/right (aileron) and you should feel the paddles moving.
Now, turn the head so that the blades are in line with the boom, and the paddles are 90 to the boom. When you move the stick up/down, the paddles will move, and left/right stick will change blade pitch.
In other words, nothing will make sense until you hold the flybar level. If you don't, there are too many mechanical interactions and the blades and paddles will not do what is expected.
Hope that helps. Here is a good guide on the radio and heli setup:
http://rabbitsvc.com/t6ConfigurationManual.pdf
Old Feb 04, 2012, 10:01 AM
Texas NewB
Joined Dec 2011
the right toggle switch is you engen cut the left toggle is your normal/stunt mode switch
your tight nob is your speed/head hold and gain for the gyro the left nob is you pitch adjust
when you push your left stick up the three servos on the swash plate should go up
when you push the left stick right/left the rudder servo well move
when you push the right stick up/down the back of the plate well rise lower
when you push the right stick left/right the two front servos counter each other(one goes up other goes down)
As for swash plate leveling you can check youtube for some videos like this
MSH Protos Swash Plate setup and leveling using TNN tool (5 min 50 sec)
as far as start up
step 1 turn on your radio
2 pull throttle stick all the way down and leave engine kill in on position.(motor can spool up)
3 Plug in the Heli
4 after the heli finish's boot up you can now set engine kill to the off position.(motor can't spool up)
set your heli where you want it set engine kill rase throttle slightly up allow heli to spool up and
after start flying.
there are allot of video's on youtube to show you way's to learn if you need them.
Old Feb 04, 2012, 11:56 AM
Texas NewB
Joined Dec 2011
I would still do it even if it was suppose to be done before they ship it
Just to be sure!
Old Feb 05, 2012, 09:02 AM
Joined Jul 2004
After reading that configuration guide I think I may have messed up my TX settings. Does anyone know what the default settings are for TX that came with the Hausler? I made changes without using the "Get User" button. Things are acting funky now. I hear buzzing noises like servos are binding.
Old Feb 05, 2012, 09:17 AM
Texas NewB
Joined Dec 2011
I have a setup I posted a few pages back
Mini-Review Cermark Hausler 450 SE V2 koppterX 3D Electric Heli Flying 395 Sep 06, 2014 02:27 PM
Sold hausler 450 rtf heli new in box dennishobbies Aircraft - Electric - Helis (FS/W) 22 Jun 02, 2012 03:12 PM
New Product hausler 450 rtf heli dennishobbies Hot Online Deals 8 Jan 30, 2011 07:48 PM
Sold FS: RTF Align Trex 450 V2, DX7 OCFly Aircraft - Electric - Helis (FS/W) 2 Jan 10, 2011 11:24 AM
Off Site Align T-Rex 450 SE V2 Complete RTF RC Helicopter Tom Z Aircraft - Electric - Helis (FS/W) 1 Sep 25, 2010 08:07 PM
