Old Jan 16, 2011, 10:30 PM
estarter is offline
Find More Posts by estarter
Berkeley, CA
Mini-Review
Hausler 450 v2 RTF
Hausler 450 v2 2.4g RTF Helicopter. I read about the Hausler 450 here and saw the display at AMA show last week.
Here is what is in the box, only need 8 AA alkaline battery to fly.
estarter is offline Find More Posts by estarter
Old Jan 16, 2011, 10:33 PM
estarter is offline
Berkeley, CA
The Hausler 450 v2 looks like a Trex 450 SA clone, the RTF Hausler 450 v2 equipped with cnc head and tail, metal frame, three 9g cyclic servos, Zd720 HH gyro, digital mini tail servo, Neodym 4000kv motor, Nao 40A esc, fiberglass main blades and canopy, a 2.4g 6 channel radio, lipo charger and a 3S Amped Up 20C 2200mah lipo pack. Here is the factory specs:
Old Jan 16, 2011, 10:34 PM
estarter is offline
Berkeley, CA
A closer look at the frame:
Old Jan 16, 2011, 10:36 PM
estarter is offline
Berkeley, CA
Factory installed electronics:
Old Jan 16, 2011, 10:37 PM
estarter is offline
Berkeley, CA
More pics:
estarter is offline
Berkeley, CA
Reserved 1 - review details
The picture at the right of post #1 shows all the stuff that comes with the RTF kit, no manual included. There is a bag of spare screws and nuts, fly bar weights, Velcro straps and wire ties.
The CD contains 2 files, USB cable driver for Windows XP and the T6 config program for PC.
The Neodym NEO-5011 lipo charger looks like a generic lipo charger from most RTF kit, it required a 12V DC source using the aliger clips, the charging rate is 1.2A.
The 2.4g 6ch radio looks like a generic 2.4g radio made by FlySky, with ccpm heli function, it is a computer programmable Tx and the programming is thru the USB cable and the software from the CD, the radio has no display and buttons for programming.
A quick pre-flight check up, all the electronics works properly, swash and fly bar are level with all the trims set at center in the Tx, the switch (SW.B) on the left is flight mode switch for Norm/Idleup, on the right (SW.A) is throttle kill. The knob (VR.B) on the left is to adjust the pitch position, I set it at 11o’clock with the idle up switch on for “zero” pitch, I get -10 to +10 pitch. The knob (VR.A) on the right is to adjust the gyro gain, 9 o’clock is 50%, 9-2 o’clock is HH mode, 4-9 o’clock is rate mode, I set it at 11 o’clock.
The ZD720 HH gyro looks and works like the 401b with the setup similar to the g401 gyro, paired with a digital mini servo (no brand label in the case) that holds the tail pretty solid, there is no servo creeping in the HH mode when test at the bench.
The esc is factory default with brakes off and soft start, the motor starts smoothly.
The red light in the Rx will turn solid red once is bind with the Tx.
Mechanical wise, the factory assembler did a good job in putting the heli together, the flybar paddle is equal distant, the swash is level at zero blade pitch, the only adjustment I did was to lower the short blade link to track the main blades. Both fibreglass blades are within 0.1 g, the belt tension is a little tight, the motor gear mesh is right on.
Old Jan 16, 2011, 10:38 PM
estarter is offline
Berkeley, CA
Reserved 2 - 2nd flight video (maiden video was off focus)
Stock RTF Hausler 450.wmv (3 min 21 sec)
Old Jan 17, 2011, 12:30 PM
Steven Chao is offline
Find More Posts by Steven Chao
CERMARK
Steven Chao's Avatar
United States, CA, Beverly Hills
Joined Apr 2004
We have recently noticed that we did not include the instructions + cd with many of the kits. We are very sorry. Please let us know so that we can send it to you. Our telephone (562) 906-0808.
Here are a few items that you can download immediately;
1. Parts list version 2
2. Quick Start version 2
3. Transmitter programming instruction version 2
4. Manual version 1 (small - lower resolution)
Peace,
Steven Chao,
CERMARK
Steven Chao is offline Find More Posts by Steven Chao
CERMARK
Joined Apr 2004
Hey, isn't that baylander field?
Peace,
Steven Chao,
CERMARK
Old Jan 18, 2011, 01:41 AM
estarter is offline
Berkeley, CA
Yes, it is Baylands. There're many EDF fast planes flying that day, I had to dodge some of them.
Old Jan 18, 2011, 02:06 AM
estarter is offline
Berkeley, CA
Change Mode 1 to Mode 2
The Tx from the RTF kit I got is a mode 1 radio, the right stick is throttle, left stick is elevator, mode 1 radio is popular in Asia.
I fly mode 2, it is easy to change mode in the T-6A radio.
1, unscrew 4 screws from the back cover of the Tx
2, swap the detent and the spring from the 2 gimball sticks
3, optional: put a shrink tubbing in the metal spring to take out the ratchet action of the throttle stick, adjust the stick tension
4, close the back cover
Old Jan 18, 2011, 02:07 AM
estarter is offline
Berkeley, CA
5, connect the Tx to PC with the USB adaptor, run the T6 config program, power on the Tx
6, click the "getUser" button to get the Tx settings
7, click the "Stick" button, a new window will pop out, select "Mode2"
8, click the "Save" button to save the Tx settings in PC, this is the factory default settings.
Old Jan 18, 2011, 08:12 AM
mrrocks42 is offline
Find More Posts by mrrocks42
Joined Jun 2010
is there any way i could buy it without the radio and reciever and put in my own to bind to my dx7
mrrocks42 is offline Find More Posts by mrrocks42
Old Jan 18, 2011, 12:06 PM
CERMARK
Joined Apr 2004
MRROCK42: Currently all of the RTF (ready to fly) come with radio & receiver... Where are you located? Is there a favorite local hobby store that you like working with? Let me talk to the local store to see if we can work something out for you.
ESTARTER: Sorry to learn that you got a Mode 1 instead of Mode2. All of the RTF kits that leaves here have been flown and tested in Mode 2. So obviously we screwed up... sorry. Let me know what we can do to correct the situation for ya.
Peace,
Steven Chao,
CERMARK
Old Jan 19, 2011, 11:11 AM
robnunin is offline
Find More Posts by robnunin
Joined Jan 2011
Hausler 450Se:
Hello
I'm a newby of the Heli RC world.
I've a question on main motor of Hausler 450Se rc model:
It's a brushless motor or not ?
Let me know, I've just purchased one and need more informations about.
Thanks for your support.
Regards
Roberto
robnunin is offline Find More Posts by robnunin
Mini-Review Cermark Hausler 450 SE V2 koppterX 3D Electric Heli Flying 395 Sep 06, 2014 02:27 PM
Sold hausler 450 rtf heli new in box dennishobbies Aircraft - Electric - Helis (FS/W) 22 Jun 02, 2012 03:12 PM
New Product hausler 450 rtf heli dennishobbies Hot Online Deals 8 Jan 30, 2011 07:48 PM
Sold FS: RTF Align Trex 450 V2, DX7 OCFly Aircraft - Electric - Helis (FS/W) 2 Jan 10, 2011 11:24 AM
Off Site Align T-Rex 450 SE V2 Complete RTF RC Helicopter Tom Z Aircraft - Electric - Helis (FS/W) 1 Sep 25, 2010 08:07 PM
