Old Jan 16, 2011, 05:15 PM
bmoney69 is offline
Find More Posts by bmoney69
bmoney69's Avatar
United States, DE, Wilmington
Joined May 2004
55.5" epp mx2
i'm building a big brother to my Fancy Foam based 34" epp MX2. love the way the small one flies and thought i'd try a 55.5" version. here are is a pic of the biuld. i'll post more with details when the UHU dries.
link to video:
55 mx2 md.wmv (3 min 18 sec)
bmoney69 is offline Find More Posts by bmoney69
Old Jan 16, 2011, 05:18 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
here are a few pics of the 34" version
Old Jan 17, 2011, 06:43 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
the plane is 10/11mm 1.9# EPP. i used a 2mmx10mm CF strip as a blade spar for the wing. .5mmx10mm CF reinforcing for ailerons and elevator. .4mmx10mm for fuse side brace. the cross bracing is 2mm at the wing and 1.8mm for the fuse and tail. prior to the x-bracing the fuse had good lateral rigidity, but bad in torque. hopefully the x-bracing will help with twisting. i have to mention i made a HUGE mistage that i'm %$#@* about!.......i was just not paying attention and attached the bottom fuse to the top of the wing! didn't realize it till it was dry and not a thing i could to about it then. soo the bevel for the control surfaces is on top....i know....well, i wouldn't think it will effect the flight characteristics, only the aesthetics. oh well....i'll just have to fly inverted all the time. servos will be HS-82mg all around. more to come.
Old Jan 17, 2011, 08:40 AM
nate540 is offline
Find More Posts by nate540
Joined Oct 2006
You must be awfully thirsty
nate540 is offline Find More Posts by nate540
Old Jan 17, 2011, 08:42 AM
nate540 is offline
Joined Oct 2006
If I made a mistake like that I would just throw it all away
Old Jan 17, 2011, 09:49 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
i know!.....couldn't believe it.....when i flipped it over and realized that was the top i wanted to!.....i thought about cutting the bottom off but then just said forget it, it's a prototype and it won't effect the way it flies.
Old Jan 17, 2011, 05:44 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Looking good!
hpapilot is offline Find More Posts by hpapilot
Old Jan 17, 2011, 06:19 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
Great work!
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Jan 17, 2011, 06:23 PM
Caish is offline
Find More Posts by Caish
USA, AR, Greenbrier
Joined Jan 2011
Ailerons that large with full throw would be like air brakes.
Not a bad looking design.
Caish is offline Find More Posts by Caish
Old Jan 17, 2011, 08:00 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
i know, and on separate servos could be interesting. soo here are some more photos i realized i need for scale. the AUW looks like it's going to be much less then i thought....i was shooting for 34 oz....looks more like 20-24. soo the cross bracing firmed it up really nice!....i checked it with just on one side and was pretty stiff and since my weight is going to good, i ran it down both sides. going to make the control horns next. i have them designed, just have select the plywood......stay tuned.
Old Jan 17, 2011, 09:56 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Nah, they tend to work pretty well actually!
Thanks.
I might just need one of these!
Old Jan 18, 2011, 05:54 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Thanks.
Praise from the designer . We'll probably see RJ with an 80" version now
Azarr
Azarr is offline Find More Posts by Azarr
Old Jan 18, 2011, 12:40 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
RJ,
one of these out of 6mm and 9mm depron would be perfect for you!.....i selected EPP more for transport then crashability. this size and weight it's not going to crash well no matter what it's made of. i started designing removable wings but it was going to be more complex, more expensive and more heavy! the epp will be more forgiving in and out of the house and car. you would very surprise how rigid it is. i have no idea what i was looking at when i stated my AUW but it's going to be 30-32. i selected a Turnigy TR 35-42D 1000kv and an APCe 12x6 or 13x4 with a 40 amp opti jeti ESC (because i have it). i know there are tons of better motors out there, but this should be fine.
Old Jan 18, 2011, 08:15 PM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
i'm keeping the airbrush work to a min.....won't be much more then this, just enough to tell top from bot.
Old Jan 20, 2011, 07:30 AM
bmoney69 is offline
bmoney69's Avatar
Joined May 2004
Airbrush work and structure is about 95% complete. on to the spades, motor mount, control horns and electronics
Discussion West Michigan Park Flyers EPP Yak-55 WMParkFlyer 3D Foamies 129 Dec 22, 2014 06:47 PM
Discussion Stuka JU-87 D-5 Scale 1/5,3 Engine DLE 55 Gicos Fuel Warbirds 177 Sep 03, 2013 01:31 AM
Sold EPP Yak 55 j2m2t2 Aircraft - Electric - Airplanes (FS/W) 9 Sep 25, 2010 11:53 AM
Question mx2 or multiplex acromaster and st model mx2: Unboxing vid? build vid? y info? jakerevs 3D Foamies 2 Mar 27, 2010 02:56 PM
Question MX2 von Hype and ST-model MX2? Thomas*rc Electric Plane Talk 4 Nov 17, 2009 02:42 AM
