Old Feb 16, 2013, 09:45 AM
helliefan is offline
Find More Posts by helliefan
Joined Jul 2007
Hm, suddenly the swashplate went wrong on my heli. Can I adjust that on the tx?
When I connect the tx to the heli, the swashplate goes un-even and is not in level.
How do I get it in level. I don't dare to hover the heli now as it only fly backwards because og the swashplate.
helliefan is offline Find More Posts by helliefan
Old Feb 16, 2013, 11:27 AM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Are you using a Devo with Deviation and a 2801 receiver?
lasakro is offline Find More Posts by lasakro
Old Feb 16, 2013, 05:32 PM
Joined Jul 2007
The one rtf heli from HeliPal.
http://www.helipal.com/walkera-hm-v4...z-edition.html
It's Devo 7 tx
Old Feb 16, 2013, 05:40 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
It's Devo 7 tx
Well never mind about the transmitter then. Never heard of this suddenly happening between an Tx and Rx. All 3 servo's should center themselves after binding. Which one isn't? The one that isn't check travel. Does it move normally? Any grinding or skipping?
Old Feb 16, 2013, 05:50 PM
Joined Jul 2007
Theire not center themselfs after binding. The swashplate goes backwards after binding. Don't know which of the servos that is.
I can't fly with it like this.
Do the heli need to stand very right on the floor while binding?
This happend after I put a trainingkit on it, and the heli stands on that and may not be totally even.
Old Feb 16, 2013, 06:00 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
It should be level as you can get it. That is the elevator servo connected to the front of the swash. I ask again does it center itself, arm at 90? How does it operate?
Old Feb 16, 2013, 06:47 PM
Joined Jul 2007
No, it does not center itselfs when binding. Then swash goes backwards and stays there. Not right at all, so I'm gonna take off the trainingkit and see if that helps.
Old Feb 16, 2013, 06:54 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Does the servo operate smoothly?
Old Feb 16, 2013, 07:02 PM
Joined Jul 2007
Yes, when i move the stick it operates normal. Swash is just not balanced and I don't know how to get it balanced.
Old Feb 16, 2013, 07:08 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
If the arm always returns to the same position after binding I would just remove the arm from the servo and position it again at a 90 degree for zero pitch. You will need to readjust the linkage to lift straight on take off.
Old Feb 16, 2013, 09:54 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
For Sale
In an attempt to decrease my Walkera collection I have my V400D02 on eBay and new spare parts also.
Heli;
http://www.ebay.com/itm/Walkera-V400...item3a7e7f4b22
Parts:
http://www.ebay.com/itm/Walkera-V400...item3a7e7f5111
Old Feb 26, 2013, 02:14 AM
djsmeegy is offline
Find More Posts by djsmeegy
Czech Republic
Joined Aug 2012
Hi guys,
this week seems to be good weather forecast for 1st flihgt of my heli. I'll let you know, if I'll flight during end of this week.
Also I decided to buy DEVO 10 for T-REX 450, they are now on the way, so when I received them, I'll start to build my t-rex.
But I'll need help about setting up proper wirinig, 3gx with rx 1002 and proper settings for tx.
Will you please help me, when I'll start to work with it?
can I ask you here, when will be the time, or should I ask here - Walk-era and Beyond ?
Cause I know you here, you helped me so much ;-)
And also, does have anybody of you DEVO 10 users manual in pdf?
Thank you, heli bros ;-)
djsmeegy is offline Find More Posts by djsmeegy
Old Feb 26, 2013, 04:23 PM
dilberto is offline
Find More Posts by dilberto
Human Being
Joined Jun 2011
Originally Posted by djsmeegy View Post
Hi guys,
Hi, i'm sure here, or walkera and beyond, or the v450 walkera thread would all be good places to ask
At some point, and a few times since then, i've posted how i wired up my 450 3gx to the 2801 pro. I'm sure the devo will be similar enough, so i can dig that up for you again when you are about ready. Just give me a day or two advance cause i don't check this every day anymore, but i do keep up with it for the most part
I'm more than happy to make sure you get flying though, and i'm sure i'm not the only one here that can help, so one of us will definitely help get u in the air!!!
dilberto is offline Find More Posts by dilberto
Old Feb 26, 2013, 06:08 PM
chrisnc is offline
Find More Posts by chrisnc
chrisnc's Avatar
United States, NC, Whitsett
Joined Jun 2012
I'm actually running my Blade 450X with my Devo 10, using a 1002 rx and a Beastx MicroBeast. I know they are different FBL units, but I can also lend some assistance. I am also running the Deviation firmware on the Devo 10.
To keep this on topic, I'm now using my Devo 10 for my Blade 450X, my Master CP, and my V400d02. And of course, for the Phoenix sim.
Good luck with the 450 build.
chrisnc is offline Find More Posts by chrisnc
Old Feb 26, 2013, 08:46 PM
kdean is offline
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Here is another good deal for someone wanting to go devo.
http://www.helifreak.com/showthread.php?t=503142
I posted about a 8s w/deviation in the " walkera and beyond " thread eariler.
I almost bought it, but the wife got to amazon first.
kdean is offline Find More Posts by kdean
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
