Old Jan 24, 2013, 11:54 PM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
I see the Search is down. So...............
Has anyone solved the Hitech 5055/ Devo binding circus of unplugging the Elevator servo before binding or a battery change?
gapi is offline Find More Posts by gapi
Old Jan 25, 2013, 08:50 AM
rangerxp28 is offline
Find More Posts by rangerxp28
United States, AZ, Chandler
Joined Mar 2012
I dont think anyone has.
rangerxp28 is offline Find More Posts by rangerxp28
Old Jan 25, 2013, 09:56 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Made A Boo Boo.
Old Jan 25, 2013, 10:20 AM
navigator2011 is offline
Find More Posts by navigator2011
Folding Spacetime
navigator2011's Avatar
United States, CA, Fullerton
Joined Jul 2011
Maybe you could wire an ON/OFF switch into the ELEV servo wire? You could then bind the receiver and then flip on the elevator servo. It stinks, but I cannot think of any other way.
navigator2011 is offline Find More Posts by navigator2011
Old Jan 25, 2013, 10:28 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Thanks, I am polling the Deviation forum about it too. I am going to call Hitec also.
I ponder if one can disable the Aile in the TX so the Rx don't worry about it and bind. If so assign it to a Gear or Aux switch?
Old Jan 25, 2013, 10:40 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
FDR replied - "Usually on Walkera receivers the elevator servo plug has a double function to clear the fixed id too.
So if your servo has to little resistance, the rx can think it is a blind plug.
I think it cannot be solved in the tx fw... "
Old Jan 25, 2013, 11:03 AM
jfranklyn is offline
Find More Posts by jfranklyn
Joined Dec 2011
v400d02 need help with a brushless tail motor problems
Hello all,
I have a v400d02 with a brushless tail and main motor kits from rtf-heli.com. The tail motor stopped spinning on my last flight. Now when I go full left and right on the collective, the motor will vibrate but not spin. I tried a new motor and re-attached all the connectors on the wiring.
When I turn on the heli and transmitter all the servos work correctly. When I apply some collective, I hear the 3 beeps from the tail motor, so I think its initializing correctly?
Could I have blown the ESC or could it be something else? Any input would be greatly appreciated. Thanks
jfranklyn is offline Find More Posts by jfranklyn
Old Jan 25, 2013, 11:06 AM
Folding Spacetime
Joined Jul 2011
For starters, look for damaged wires going to the tail motor (through the boom, etc.). Double check if the tail ESC is getting unduly warm while the tail motor does that vibrating things. What you describe sounds a bit like a shorted wire somewhere.
Old Jan 25, 2013, 11:08 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Originally Posted by jfranklyn View Post
Hello all,
Make sure you don't have the converter attached (taped) to the converter. Separate them if they are not.
Old Jan 25, 2013, 11:12 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Just go off the phone with Hitec and they are telling me they never heard of the issue.
He also had no reply as to why. I guess I need to speak with another tech that is servo signal savvy.
He did listen and then asked me to put it in detail in a support email.
The Deviation responses are:
Bind plug is signal to ground.
I think it may help to add a resistor from servo signal wire to positive (+) wire, maybe 1-5 kOhm.
Any takers?
Old Jan 25, 2013, 11:17 AM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Hello all,
If it vibrates and doesn't turn the motor is only getting 2 of the 3 phases. Disconnect the motor and perform a continuity check on it. Phase to phase all 3 readings should be very low. If you get an open, bad motor. If the motor checks good bad ESC.
Edit- Bad ESC. Should have fully read the question....
lasakro is offline Find More Posts by lasakro
Old Jan 25, 2013, 11:18 AM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Old Jan 25, 2013, 01:00 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
He also said "Whats a Devo?"
The Deviation responces are:
Any takers?
Hummm.... Measure the resistance of a disconnected servo. Both signal and power to ground. Is the 5055 programmable?
Old Jan 25, 2013, 01:37 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Yes it is programmable, and I have a HPP-21 programmer and set of 5055's and a set of Walkera MG's in transit.
And I have a set of Tower pro MG90S (Analog) and a set of Fusonic MG-D- 9G (Digital) to compare with.
I'll be doing all that in a few days.
Old Jan 25, 2013, 11:17 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Just sitting by the fire with my Devo 10 looking through my settings, and I see the Tail curve looks like it has been tweaked but I don't remember doing it.So I looked at Models I have not used and they are different.
What I have in my current model is Flight Mode Normal& Stunt 1 = is -10 to + 100. Stunt 2 is -100 to +100.
In the unused models they are all @ -100 to +100, does changing pitch curve or Expo do that to the tail curve automatically? I do not remember ever changing anything in Tail Curve.
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
