If I am using a LIPO to power my tx, I like the alarm to go off around 10 volts, or about 3.3 volts/cell, well clear of the damage limit. If I am using regular ole Duracell batteries, then I go with the default setting of 8.0 volts.
Latest blog entry: Creating a plumb line pitch gauge
Possible Devo 10 Damage from 3S LiPo
I don't know who's seen this but a 3S LiPo may fry your Devo 10. It isn't designed to see voltage higher than 12 and most fully charged 3S's are 12.4- 12.5 volts. I made up a JST-M to JST-F adapter with a 1 amp rectifier diode in it which sits in the battery compartment. It drops the voltage by ~1 volt. See post #2055 and the bottom and go from there.
http://www.rcgroups.com/forums/showt...11471&page=137 |
I don't know about this . . . when I put in 8 brand new Duracells, the total voltage often reads 12.3 to 12.5 volts, at least for a little while.
I use 8 rechargable AA bats bought from xheli when i got my v400 two years ago (the green and gray ones, i think 2200mah). Fully charged the tx will read around 10.6 and i have the alarm set to go at 9.0
They say its not good to use the batteries in a tx when they get below 1.1v per cell. So my tx never gets down to 8.8v |
United States, AZ, Chandler
Joined Mar 2012
Very nice flying. Usually I get bored seeing all the inverted stuff, it seems sometimes that's all there is to do with these things but you did some moves other than just being inverted that were really nice. Those long reversed loops looked nice.
What battery were you using there. Seemd like a nice amount of flight time. How about the specs on that build? |
Joined Mar 2012
| Thread Tools | |
| Discussion Another new Walkera (V400D02)? | GetterDragun | Micro Helis | 130 | Apr 01, 2013 09:23 AM |
| Discussion Alternative canopies for Walkera V200D02, V400D02 | JumboA5 | Mini Helis | 2 | Mar 18, 2011 04:29 AM |
| Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 | JumboA5 | Electric Heli Talk | 2 | Dec 13, 2010 08:22 AM |
| Discussion Walkera new 3D flybarless V400D02 | Naev | 3D Electric Heli Flying | 2 | Oct 31, 2010 08:50 PM |
