Old Jan 19, 2013, 08:49 PM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
Thanks. I may just ask $85.00 shipped for both.
Flew my learner/trainer/sacrificial lamb Master CP today. I have lots of simulator time with lots of time on helis I have no business flying but had to know, and the usual dual rotor hover around traing.
It paid off, my maiden flight lift off was good and I was corkscrewing around but if not for the simulator time I would have either nailed a tree head on at speed or drove it hard into the dirt
Yes I crashed, but knew enough to let off and the 2nd run I landed kinda hard. Broke the tail fin. It was hanging like it was hinged. Easy Epoxy fix.
I was ballsy with no training gear. Its on there now and +30 expo has been applied. Can't wait.
gapi is offline Find More Posts by gapi
Old Jan 19, 2013, 08:53 PM
lasakro is offline
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
Cool. Sounds like it was a small price to pay.
lasakro is offline Find More Posts by lasakro
Old Jan 19, 2013, 10:46 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
I have been eyeballing the brushed motor's cooling vents and how some heat sinks cover one of them. I put 1 and a half of another before realizing I left one hole open and the other covered. Not good?
Also I picked up one of these, the top just covers both vents.and am going to open up those areas. A swath with a 1/2 " end mill about 1/4" deep will do nicely I think.
Old Jan 20, 2013, 11:33 AM
helliefan is offline
Find More Posts by helliefan
Joined Jul 2007
Where can I buy one V400D02 BNF? Without a transmitter.
http://www.xheli.com/walkeraheli-v40...adytobind.html
This would be perfect to buy, but out of stock.
helliefan is offline Find More Posts by helliefan
Old Jan 20, 2013, 07:57 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
I know it may be a stock photo but the receiver shown in the pic is not a Devo receiver.
Call HeliRC Store. Get him on the phone, because even though its not listed on his site he may be able to provide if asked. Let us know.
Old Jan 21, 2013, 03:45 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Try here.
BThirsk is offline Find More Posts by BThirsk
Old Jan 22, 2013, 07:13 PM
ChopperJack is offline
Find More Posts by ChopperJack
Moving Parts
ChopperJack's Avatar
United States, AR, Texarkana
Joined May 2011
I hope someone got their package today.
ChopperJack is offline Find More Posts by ChopperJack
Old Jan 22, 2013, 07:28 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Yes I Did! Thanks. Its going to sit still for several days though. I did open and peek!
Old Jan 22, 2013, 07:43 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Got some Fusonic (MG-D-9G) today. At least thats what I ordered from Ehirobo. No labels or ID markings. Wow. The ziplocks looked used. No screw marks on the servos though.
Old Jan 22, 2013, 07:50 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Originally Posted by lasakro View Post
Looking around you seem low. Maybe more like 70 for the tx and 35 for the rx.
I got $88.00 for them on eBay in less than 24 hrs.
Old Jan 23, 2013, 03:31 PM
jfranklyn is offline
Find More Posts by jfranklyn
Joined Dec 2011
need help with devo7 settings and fusonic servos
Hello all,
I've installed the fusonic mg-d-9g servos on my v400d20 with a devo7 transmitter. I'm still using the stock motors and ESC.
It looks like the ALE, ELEV, RUDD, PITCH settings are now backwards. I've used the REVSW setting to set the ALE, ELEV, RUDD from normal to reverse. I set the PITCH setting to reverse but the pitch is still backwards. With positive collective the swash goes down, negative collective the swash goes up?
What settings do I need to use with the fusonic servos? Any help would be greatly appreciated. Thanks
jfranklyn is offline Find More Posts by jfranklyn
Old Jan 23, 2013, 03:54 PM
lasakro is offline
Seeking Control
lasakro's Avatar
Joined Dec 2012
Originally Posted by jfranklyn View Post
Hello all,
I'm not up on the Devo firmware and this may be a stupid question. Did you try the 3 servos negative but the pitch positive?
Old Jan 23, 2013, 04:34 PM
chrisnc is offline
Find More Posts by chrisnc
chrisnc's Avatar
United States, NC, Whitsett
Joined Jun 2012
jfranklyn,
You might also check to be sure that they are all moving the same direction individually. I installed some Fusonic servos recently, had some weird stuff going on with the movement once I programmed everything, and then decided to test them with my servo tester. Turned out that two of them were moving in the opposite direction from the third. I opened them up and they were all wired differently.
Two choices, fix them to move like stock by re-wiring, or fix them to move all in the same direction, but opposite of stock, then reverse in the tx, and flip around the receiver. Since I was fixing them anyway, I re-wired them to move the same as stock and everything worked great.
Oh, and don't reverse RUDD.
Hope that helps.
chrisnc is offline Find More Posts by chrisnc
Old Jan 23, 2013, 07:21 PM
Bnh105 is offline
Find More Posts by Bnh105
United States, IL, St Charles
Joined Jan 2013
Does anyone know if this heli will fit a scale fuselage such as the align md 500?
Bnh105 is offline Find More Posts by Bnh105
Old Jan 23, 2013, 07:53 PM
navigator2011 is offline
Find More Posts by navigator2011
Folding Spacetime
navigator2011's Avatar
United States, CA, Fullerton
Joined Jul 2011
I have not installed Fusonics with the 2614 receiver, but I did use them with the 2702. I know other members here have installed the Fusonics with the 2614 and Devo 7 tx--so it is possible once you know the proper settings.
You will just have to fiddle around with the Reverse settings and switching the positions of the servos in the receiver. That is to say, you may have to switch the PIT and AIL servos from what is shown in the manual. You should also be able to mount the ELEV servo on either side of the frame, should the need arise. I wish I could tell you exactly what to do, but I cannot. When I switched from Fusonics to Hitec servos, I had to repeat this whole process. But now it's all working great. You'll get there, too.
navigator2011 is offline Find More Posts by navigator2011
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
