I did know walkera had made some changes in the production of some parts, but like i said before, i've never had to change a feathering shaft or blade grip on my v400's. I guess i'm lucky. I have 3 complete spare heads sitting in my parts box. I wanna try one on a 450pro cause i've been through many heads on that heli. It now has a dfc head but who knows how long that will last.
United States, SC, Irmo
Joined Sep 2011
Just saw Daver Herbert's video. Wow, nice for beginners. It really flies nice. I'm sure if I got one it would not fly like that, I have the worst luck with Helis. My last Walkera was a POS and the 3 axis gyro does not work correctly (V370D01). On Dave's video, he says it came with the DEVO 7 for $159. But I just see the dated WK series one for $159. What gives?
Oh, which video you talkin about? |
Joined Sep 2011
This one.
It says $159. Now they only have the Exceed version for $205. No thanks. Don't know why I am even looking. I have already given up on an Esky CPX, have a clone that I can't get the tail to work, and now having tail issues with a Hausler that I got because it was reported to fly well out of the box. I like the micros, they fly so nice, like the Nano and even my Solo Pro 100. I just want a collective pitch heli, but $200 is too much to risk, as most never fly with me. Plus I don't want to pay extra for Walkera's radio that they re just going to dump like they did the WK series. |
Czech Republic
Joined Aug 2012
Now Im just thinking about upgrade of tx+rx, cause setting of wk2603 is little bit heavier for me (everytime when going to setting is everything deleted) and also Im not sure about gyro in rx2614v cause last time when I've been hovering my heli suddenly flied weird and uncontrollably and crashed down. It was quite unstable. So I just wanna to know if anybody from you tested devo7 or devo8s with compatible rx (RX802). And which gyro should i use. Thanx. |
You mention that you are loosing changes made to your 2603. You need to follow the instructions verbatim when using the enter key. If not you will loose the changed setting. This link may help:
I would disconnect the main if you have your new ESC, or power the 2614 from the stock one, like I mentioned on the last page, and test the tail by hand. Let the gyro lock, change rudder position, move the heli and let it lock, etc. Disconnect the battery, rebind and repeat several times and see if you can get the gyro not to lock. If it doesn't lock get another 2614. It's you choice if you want to get another RX2614V to use with your 2603 or get the RX2614V-D and Devo Tx. Let us know how you make out. Many of us are using the 2614 w/o any problems. |
I ordered a heatsink and got two. I installed them today cutting one down to fit.
I had to shape them because after snapping them on I could see they were only touching the motor body at the tips of the ends and just barley at the center. Not a very good way to sink. Anyway. That's that.
If your saying better tape because of the rubber bands in the pic, those were just to hold the battery down while I tested and checked her balance and such. But if you are saying its a known issue please clarify? Those are the heat sinks are what I have seen suggested for the V400. If you have better please toss it at me. Thanks again |
Czech Republic
Joined Aug 2012
Ok. Thank you very much for info. I'll test it and I'll let you know.
And about tx 2603 I thought that i loss settings when i re-enter setup. I think know how to save and go thru it but it's a pity if i wanna to make small change (for example gyro sens from 80 to 90%) I'll have to go thru many settings with knobs v1 and v2. Will see if I'll stay with wk2603. I hope so. |
Looks like they are holding down the receiver. Actually Esky does make a HS for a 370 / 380 motor. Wonder why the center isn't in contact? I apply a thin coat of thermal grease on 180 but that only works if it correctly fits. Try bending it better to the contour of the case then slide it on the end instead of snapping it on the side. That causes it to get deformed. You will probably need to remove the motor because of the PCB on the top. |
| Thread Tools | |
| Discussion Another new Walkera (V400D02)? | GetterDragun | Micro Helis | 130 | Apr 01, 2013 09:23 AM |
| Discussion Alternative canopies for Walkera V200D02, V400D02 | JumboA5 | Mini Helis | 2 | Mar 18, 2011 04:29 AM |
| Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 | JumboA5 | Electric Heli Talk | 2 | Dec 13, 2010 08:22 AM |
| Discussion Walkera new 3D flybarless V400D02 | Naev | 3D Electric Heli Flying | 2 | Oct 31, 2010 08:50 PM |
