Old Sep 26, 2012, 01:10 AM
rangerxp28 is offline
Find More Posts by rangerxp28
United States, AZ, Chandler
Joined Mar 2012
Its all comes down to if you are good at soldering and can program a esc? If your not go at it go with the RTF setup. There is not a big diff in the price of you doing it.
Originally Posted by weav01 View Post
I know this has been posted somewhere but the search list is long. I wanna upgrade my v400 to brushless main first, not tail (maybe later) I'm burning through too many brushed motors. Is the RTF setup the way to go or something different. Had someone message me and talk about Align 450 pro with ESC and/or signal converter? Which is the easiest to plug and play with? Or any other combination that has been attempted and accomplished out there? Thanks guys and appologize for beating the proverbial dead horse.
rangerxp28 is offline Find More Posts by rangerxp28
Old Sep 26, 2012, 12:18 PM
weav01 is offline
Find More Posts by weav01
Pittsburgh, PA
United States, PA, Mt Pleasant
Joined Jul 2012
I can solder but never programmed an ESC. Pulled the trigger on the RTF main brushless setup. I'm very excited. Thanks guys.
weav01 is offline Find More Posts by weav01
Old Sep 26, 2012, 03:10 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Took the superblue and the v400 out today, superblue flys great,but every time i try to turn it nose towards me it goes backwards or sideways big time ! The v400 with upgraded servos flys good and is extremely touchy,i also have to have rudder trim way to the right to keep tail stable ? still fun !!
fastfwd is offline Find More Posts by fastfwd
Old Sep 26, 2012, 03:51 PM
segdohbird is offline
Find More Posts by segdohbird
segdohbird's Avatar
San Jacinto, California
Joined Jan 2004
Sounds like somethings wrong in Hoosville. Unplug both motors - bind and go through your setup. Also I'm sure you have your xmitte set to one servo?
segdohbird is offline Find More Posts by segdohbird
Old Sep 26, 2012, 08:04 PM
Heli Biggie is offline
Find More Posts by Heli Biggie
They call me plan B
Heli Biggie's Avatar
United States, GA, Covington
Joined Mar 2011
Well i havnt had much time to fly lately. But today the v400 started off with a very tight fast wobble, then i snugged some things up and now has a slower bigger wobble. Hmmmmm, i wish this heli was made a little better , even with all the better parts on her , she is still very weak.
Heli Biggie is offline Find More Posts by Heli Biggie
Old Sep 26, 2012, 09:50 PM
segdohbird's Avatar
Joined Jan 2004
Three words......
HK
450
FRAME
Old Sep 27, 2012, 03:10 AM
djsmeegy is offline
Find More Posts by djsmeegy
Czech Republic
Joined Aug 2012
Hello,
I wasn't here for longer time, cause I'm still waiting for some parts to have full upgrade of my V400d02.
I have a few of questions.
1) I have got two (main) motors, one of them has 5000kV and the second one has 3800kV, so can you describe me some impacts if I choose one with higher or one with lover kV? Does anybody of you have some info about it? I want to decide or try the higer one, but Im not sure if it will be good, just let me know, and I will decide and then I'll let you know.
Ive tried to found some info about different impacts for helis, but I found nothing.
2) I suppose center of gravity should be on the main shaft, if I grab heli with two fingers aroung main shaft and under blades, then heli maight be balanced (see on picture - "v400d02-fingers" - red circles are two fingers) am I right?
Thank you, guys
djsmeegy is offline Find More Posts by djsmeegy
Old Sep 27, 2012, 05:54 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by djsmeegy View Post
Hello,
Thank you, guys
The 5000KV would be too fast. You would need a 9 or 10 tooth pinion to even try it. Depending on the shaft size, it might be hard to find a 9 tooth pinion.
BThirsk is offline Find More Posts by BThirsk
Old Sep 27, 2012, 08:37 AM
fastfwd is offline
Joined Mar 2012
LOL binding is not going to fix drifting,i think it is just me freaking out. I could do a bit of tuning as neither the brushless v400 or the other one will hover hands off,never has doubt they ever will. Also im using devo7 for the brushed v400 and a Walkera 2603 for the brush-less V400. Can i use the 2603 for both helis ? Guess not one is 2614v-d one is 2614v RX Second video is v400 with fusonic servos, had to stop and put quite a bit of right trim for rudder.
superblue 9 26 12 012 (2 min 21 sec)
v400 9 26 12 (5 min 6 sec)
Old Sep 27, 2012, 12:21 PM
They call me plan B
Joined Mar 2011
But i just put all the new stuff on,,,,grrrrrrrrrr. What servos did you use , i would love to use my hitec 5055 still.
Three words......
HK
450
FRAME
Old Sep 27, 2012, 12:57 PM
mdeutschman is offline
Find More Posts by mdeutschman
rubber heli skills
United States, OR, Seaside
Joined Nov 2009
I have the Hitec 5055's on my 450pro cf with the 2614RX double brushless heli and they are great.
mdeutschman is offline Find More Posts by mdeutschman
Old Sep 27, 2012, 01:55 PM
Joined Mar 2012
Picked up a new ESC for the V400 hobbymate 40a with BEC. Have a new Tali ESC on the way to.
Old Sep 27, 2012, 02:31 PM
segdohbird's Avatar
Joined Jan 2004
Ok every one using the delete stock esc. I picked up a new ESC hobbymate 40a bec 5v. I have the program card and my setting are brake OFF, batt type LI, cut off soft, cut off vol middle, start very soft, timing low, music li cell B, governor ON, But all its doing is beeping and not turning the motor? Do i need to put the stock ESC back on and plug the New ESC in to one of the servo port's and program it that way?
I'm assuming it's a brushless esc, right?
If so do you have your brushless conv plugged in?
Old Sep 27, 2012, 03:43 PM
Joined Mar 2012
Yes that what it was.
Old Sep 27, 2012, 04:03 PM
segdohbird's Avatar
Joined Jan 2004
We've all been there.
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 10:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 05:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 09:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 09:50 PM
