Old Aug 26, 2012, 10:55 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by BThirsk View Post
I have a Devo 7 and don't like it. It takes 10 times more steps to program that a Devo 8. The batteries will go to low shut off after 10 to 15 minutes of programming. I only use with Phoenix SIM.
The Devo 8 has most of the features of far more expensive TXs. The only issue I have is the display outdoors, but it is really not a problem. I have all my models on the Devo 8. I updated it 10 the 100mw as well.
When I got the V400, it came with the old manual. I emailed Walkera and did get the correct Devo manual several Days ago.
I have a devo7 and i also really don't like it. I got it working ok with the v400,but its a pain !
fastfwd is offline Find More Posts by fastfwd
Old Aug 26, 2012, 11:10 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Originally Posted by Heli Biggie View Post
Well i made mine look the same lol, i had a brain glitch and down she came , tail heavy! I am rebuilding using my bros made up frames , plastic , i will test them and see whats up. They are strong with all the other parts. So this may work.
I will ahve to wait for tail motor , blades ,and other stuff to replace this crash stuff. But right beofre that i had the longest i verted hover. It was like i was on the sim, oh well ,i dont have video either , it makes me more calm,
Sorry to see that. The V400d is a very soft heli. Its funny because I was just thinking about getting another Tarot 450 sport with TT and switching over parts from V400. I think I would get the kit and be able to use the tail parts as spares on my other 450s
ending up with only the receiver and tail motor parts from v400. Just like a couple of guys over on the 450clone thread.
My V400d flies perfect now, but I was going to take it to work tomorrow to get the dust off it. I'm going to try not to crash but if I do, that's when I'll get another 450 sport kit.
barnstorm100 is offline Find More Posts by barnstorm100
Old Aug 27, 2012, 04:26 AM
dilberto is offline
Find More Posts by dilberto
Human Being
Joined Jun 2011
Originally Posted by jfranklyn View Post
Hello,
I adjusted the pitch setting as you suggested. I checked for binding of the servos by manually moving all 3 through there full motion. Then ran with the blades off to check for binding again. I still can't get any controllable hover. I'll attached a video of my flight testing as soon as I can shrink it down to size. The video shows the following:
spool up
moving the cyclic in all directions to show swash movement
50% collective
100%collective
full forward cyclic - no flight
full right cyclic - no flight
full back cyclic - we have lift-off
full left cyclic - we have liftoff
Hmm ill wait on your video cause that sounds strange and I'm not sure what u mean exactly. When u say liftoff do you mean that it takes full back or left cyclic for the heli to leave the ground? If so then something very strange is going on cause it should only take collective pitch with minimal cyclic input to keep it straight. Do you have your tx in mode 2?
For the video usually YouTube will convert it for you when u upload it. I think now we just need to see that.
One other thing, what d/r % are u using? And what tx do u have, I forgot if u already mentioned that.
dilberto is offline Find More Posts by dilberto
Old Aug 27, 2012, 11:37 AM
Heli Biggie is offline
Find More Posts by Heli Biggie
They call me plan B
Heli Biggie's Avatar
United States, GA, Covington
Joined Mar 2011
I guess i will rebuild one more time , then maybe later upgrade to a trex 450 frame, im not sure i want to change a grea heli, parts are coming! Sois the storms, the winds are bad now. Might be trucking it later. And sim!
Heli Biggie is offline Find More Posts by Heli Biggie
Old Aug 27, 2012, 11:51 AM
jfranklyn is offline
Find More Posts by jfranklyn
Joined Dec 2011
link to video:
http://www.rcgroups.com/forums/showa...6&d=1346086079
I'm using a 2603 transmitter.
jfranklyn is offline Find More Posts by jfranklyn
Old Aug 27, 2012, 04:56 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
link to video:
The sounds like what happen to me yesterday when I changed all the servos on my HK250. I mixed up the AIL and Pitch servos in the rx. Switched them and all was well.
BThirsk is offline Find More Posts by BThirsk
Old Aug 27, 2012, 05:35 PM
Joined Dec 2011
I'm using a walkera 2603 transmitter in TX mode 2
The v1 and v2 switchs are up/off, so I'm not using any throttle or pitch limits
I'm using the metal servos from rtf-heli.com fot the v400d02
Main and tail brushless motors from rtf-heli
Old Aug 27, 2012, 10:49 PM
eugenechong is offline
Find More Posts by eugenechong
Joined Jun 2011
just a question for using parts from v400 onto a 450 clone. is it still fine if the 450 clone tail is on a digital servo or does it have to have a tail motor like v400?
eugenechong is offline Find More Posts by eugenechong
Old Aug 28, 2012, 12:13 AM
kdean is online now
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
The 2614 rx does not support tail servos.
kdean is online now Find More Posts by kdean
Old Aug 28, 2012, 06:55 AM
Joined Dec 2011
Dilberto,
Here's all my replies in one post:
Link to the video:
Not sure what the dual rate% would be on the 2603. My settings are:
EXP=25
PIT PLT=35, 75
RUDMIX GYRO=75
ELE=NOR
ALIE=NOR
THRO=NOR
RUDD=REV
GEAR=NOR
PIT=NOR
AUX=ON
BUZZ=ON
EXP=OFF
PLTPIT=OFF
RUDMIX=NOR
RUDMIX GYRO=OFF
6CH=YES
STICK 2 MOD=YES
3 AXIS GYRO
EPA E on top
Any help would be greatly appreciated. Thanks
Old Aug 28, 2012, 10:16 AM
rangerxp28 is offline
Find More Posts by rangerxp28
United States, AZ, Chandler
Joined Mar 2012
The blades i have are from two different distributors. The one that says turnigy are from hobby king and the one that white is from rtf-heli.com its there xtreme blades. They balance out perfect that's why I'm using 2 different blades. Hobby king blades are not even close to being balance when you get them and the rtf-heli.com are balance. Thank the videos heli biggie puts up did the same for me. I got the v400d02 after seeing his videos on youtube!
Originally Posted by vyper2k1 View Post
Your vids motivate me to stick to this project. I really Like the look of your heli. Were can I find the blades you got on?
rangerxp28 is offline Find More Posts by rangerxp28
Old Aug 28, 2012, 10:52 AM
vyper2k1 is offline
Find More Posts by vyper2k1
vyper2k1's Avatar
United States, MA, Chelsea
Joined Jul 2012
Ok so i found 3 upgrades to replace my wk2603 transmitter. My questions to the group would be what is the best purchase?( i have 2 RX right now the 2614v and the 2614v-d).
1. Devo 7 for $50.00
2. Devo 8s for $160.00
3. Devo 10 for $140.00
vyper2k1 is offline Find More Posts by vyper2k1
Old Aug 28, 2012, 11:12 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Devo 7 and devo 10 are similar, both cluggy.
The Devo 8s, Devo 6, and Devo 12 are the touch screen with many more features.
The Devo 8s is definitely worth the extra money over the other 2.
Old Aug 28, 2012, 12:18 PM
Joined Mar 2012
I would get the Devo 8s but All your getting out of the devo8s is touch screen. The Devo 10 can do all that the Devo 8s can do, and the devo10 has the vibrating timer and i dont think the 8s comes with it. But for the 10 and 7 being the same not even close. All they have that is the same is the look. Go with the wowhobbies Devo 10 and it looks close to the 8s with out the touch screen. But one thing to that has me wanting the 10 move is less stuff that can go wrong with it over the touch screen with me having two kids under the age of 6
Old Aug 28, 2012, 01:43 PM
They call me plan B
Joined Mar 2011
Well i get my blades from xheli and heliheli. They are just cheaper!pro 3d carbon blades
Im going with align next to test how better they are, i know they will be better
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
