United States, AZ, Chandler
Joined Mar 2012
Yes i have the Devo version. Ill take a pic today and put it up of what my FS looks like. |
United States, ID, Burley
Joined Mar 2012
Well, apparently Walkera doesn't want us buying align parts for the v400. They would rather gouge us for the price a whole new rotor head. Nice...
I'm not positive, but if you get the align thrust bearings, you may be able to go ahead and use the align featherimg shaft. I installed the Fusonics on my 450 Pro, and its a real challenge to fly, super responsive and jumpy. More often than not, I have thought of changing to a different brand. |
Latest blog entry: Using a plumb line pitch gauge on a...
Joined Mar 2012
United States, NE, North Platte
Joined May 2012
What about dialing a little more expo in? Do you think that would help the jumpiness? I added more headspeed and that has helped a bunch. My throttle curves are 0, 50, 60, 60, 60, 60 , 60. I am thinking about going to 70 with the last five curves. I also turned down the aile. and elev pot on the gyro. I might turn these down even more. It is flying pretty good now. I noticed when my batteries get to 3.7 on each cell my performance drops significantly. Is this normal? |
First, I want to make it that I don't know if the align thrust bearing trick will work. Maybe some one else here can be more assuring. As for expo, yep I'm using some, but its still jumpy on the cyclic. I've gotten better at flying it just by getting used to the twitchy behavior.
Joined Mar 2012
Joined May 2012
Can you be more specific? What exactly is it doing? Mine is fine in the hover. I get just a little tail wag, but I am going the process of eliminating that. When I punch the throttle the heli goes straight up and the tail holds real well. The tail will not wag until I get to the top of the punch and start to bring her down.
Joined Mar 2012
I think that adj/wk switch is supposed to be set to wk for "work" when you want the gyros to be functioning.
It might just be that the speed and travel rate of the fusonics are makeing the heli twitchy. The tgy90 servoed v400 feels smoother but has a slower response than the superV w/5055. I also had to lower the travel adjust for the tgy servos (as low as 45% for some). This will calm down the cyclic travel rate and tame it alot. Also, if you are used to the slower/less travel servos, you may just need to re-teach your thumbs how much input is needed to get the same results. And the gyro sens pots might need some tweeking as it will have the same issue your thumbs are haveing, over/under controling the cyclic.
I did my regular sunday session today with the superV. Its still the only heli flying right now in my fleet. Put 4 good packs through it and over 80% of my flights were spent inverted or getting inverted. I almost got the blades into the grass after doing a lower than normal transition, but my thumbs did what they were suposed to do and saved it without me even thinking about it. No more 'shakey thumbs' when i'm flying inverted circles or doing rolling transitions. Im now wanting to throw some tail action into my transition and start piroing stuff, but i'm very concious of the tail motor and its limitations. It may take some very slow babe steps to get confident knowing the tail wont blow out on me. Still no vids, but soon.
Joined Jun 2011
![]() It's been a while since you've posted one and i know you're getting a lot better. One thing i find neat about posting regular videos is that i can see my flight progression. I'm no where near doing inverted circles yet, but i'd like to see your new flight skills when you get a chance
| Thread Tools | |
| Discussion Another new Walkera (V400D02)? | GetterDragun | Micro Helis | 130 | Apr 01, 2013 09:23 AM |
| Discussion Alternative canopies for Walkera V200D02, V400D02 | JumboA5 | Mini Helis | 2 | Mar 18, 2011 04:29 AM |
| Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 | JumboA5 | Electric Heli Talk | 2 | Dec 13, 2010 08:22 AM |
| Discussion Walkera new 3D flybarless V400D02 | Naev | 3D Electric Heli Flying | 2 | Oct 31, 2010 08:50 PM |
