Old Jun 19, 2012, 01:25 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by trhodes View Post
Kdean,
Is there torque issues keeping my pitch curves where they are at? Or... should I adjust my travel adjustment? Again, my pitch curves are: L--0, 1--10, 2--20, M--30, 3--40, 4--50, and H--60. Would one lower the aile, elev, and pitch travel adjustment the same percentage?
DEVO-7
Walkera V400D02
Pitch Curve and Throttle curve settings
Traveladj...
Elev-Up-95%
Elev-Down-95%
Alie-L-95%
Alie-R-95%
thro-H-95%
Thro-L-100%
Rudd-L-100%
Rudd-R-100%
Gear+ 100%
Gear- 100%
Pitch-H-90%
Pitch-L-90%
Gyro+ 100%
Gyro- 100%
Subtrim---all at 0%
DREXP
Elev-POS-0--DR=95%....EXP=+20%
Alie-Pos-0--DR=95%...EXP=+20%
Rudd-pos-0--DR+100%...EXP=+5%
THCRV
srvhd=yes
Mode=Norm
EXP=on
point-P-L-output=0%
point-P-1-state-act-output=20%
point-P-2-state-act-output=35%
point-P-M-state-act-output=55%
point-P-3-state-act-output=65%
point-P-4-state-act-output=75%
point-P-H-output=95%
Gyro=Manual
switch=gear
Pos-0=75%
Pos-1=100%
Pos-2=100%
PTCRV
SrvHd=yes
Mode=Norm
EXP=on
Point-P-L-output=30%
Point-P-1-state-act-output=45%
Point-P-2-state-act-output=50%
Point-P-M-state-act-output=55%
Point-P-3-state-act-output=55%
Point-P-4-state-act-output=65%
Point-P-H-state-act-output=85%
This is where im at right now on settings, seems to be working good
fastfwd is offline Find More Posts by fastfwd
Old Jun 19, 2012, 01:35 PM
trhodes is offline
Find More Posts by trhodes
United States, NE, North Platte
Joined May 2012
Originally Posted by fastfwd View Post
DEVO-7
Walkera V400D02
Traveladj...
Elev-Up-95%
Elev-Down-95%
Alie-L-95%
Alie-R-95%
thro-H-95%
Thro-L-100%
Rudd-L-100%
Rudd-R-100%
Gear+ 100%
Gear- 100%
Pitch-H-90%
Pitch-L-90%
Gyro+ 100%
Gyro- 100%
Subtrim---all at 0%
DREXP
THCRV
srvhd=yes
Mode=Norm
EXP=on
point-P-L-output=0%
Gyro=Manual
switch=gear
Pos-0=75%
Pos-1=100%
Pos-2=100%
PTCRV
SrvHd=yes
Mode=Norm
EXP=on
If I use those pitch curves my pitch will be out of wack unless I adjust my servo travel.
trhodes is offline Find More Posts by trhodes
Old Jun 19, 2012, 02:33 PM
fastfwd is offline
Joined Mar 2012
yes indeed i had to adjust the servo rods to work with these settings,using a pitch gauge
Old Jun 19, 2012, 02:43 PM
trhodes is offline
Joined May 2012
I adjusted my pitch curves to -2 at low stick, +2 at mid-stick, and +6 at full-stick and guess what no tail wag. I had emailed Dane at rtf-heli and he thought my pitch had too wide of a range. I am still not sure on the throttle curves as I am keeping the percentage pretty low. In fact, my throttle curves are 0, 30, 40, 40, 40, 50, and 50. But, man it flies like a dream without that tail wag. Does anyone have a wobble when spooling down? I think this is due to the main gear warp.
Old Jun 19, 2012, 04:57 PM
dilberto is offline
Find More Posts by dilberto
Human Being
Joined Jun 2011
A wobble when spooling down happens sometimes, it seems like sometimes after repairing i get it and sometimes not. However you should be able to use a larger pitch range than that, plus if you are just hovering it shouldn't matter too much so that's kind of strange.
Is it wagging with both batteries or just that one still? Check your main blade tightness too since you have tail wag and a power down wobble, might be that, dunno. Also try turning your throttle up so you get higher head speed, if you still have the brushed main motor 40% is pretty low. Try 0, 40, 80, 80, 80, 80, 80
dilberto is offline Find More Posts by dilberto
Old Jun 19, 2012, 05:04 PM
navigator2011 is online now
Find More Posts by navigator2011
Folding Spacetime
navigator2011's Avatar
United States, CA, Fullerton
Joined Jul 2011
Blades being out of balance, of differing weight, and/or out of track can easily cause intermittent jittering motion and glitchiness in the air, as well as serious wobbling during spooling down. Another symptom of blade issues can be tail drifting, too. The balance of the main blades is way more of a big deal than any wobble due to the main gear being warped.
Now, if the main gear is warped such that the pinion mesh is varying in tightness, well then that is another problem, too.
navigator2011 is online now Find More Posts by navigator2011
Old Jun 19, 2012, 05:11 PM
trhodes is offline
Joined May 2012
I will try those curves. I am using the brushless motors. Should blades be loose or tight?
Old Jun 19, 2012, 05:14 PM
fastfwd is offline
Joined Mar 2012
I set my pitch real close to the manual, -4 at 0 throttle, +5 at middle throttle, and it is at +9 at full throttle.
Old Jun 19, 2012, 05:57 PM
fastfwd is offline
Joined Mar 2012
If you turn heli on side it should take a good shake for blades to fall.both should fall the same.
Old Jun 19, 2012, 09:05 PM
Heli Biggie is online now
Find More Posts by Heli Biggie
They call me plan B
Heli Biggie's Avatar
United States, GA, Covington
Joined Mar 2011
My 2nd charlotte nc fly went well. Had a bit of a low ground touch at end of 1st flight. But she flew like normal after . Please enjoy.
walkera v400d02 3d charlotte nc 1.MP4 (5 min 36 sec)
walkera v400d02 3d charlotte nc 2.MP4 (4 min 18 sec)
Heli Biggie is online now Find More Posts by Heli Biggie
Old Jun 19, 2012, 11:05 PM
Trelos05 is offline
Find More Posts by Trelos05
Trelos05's Avatar
Australia, NSW, Waterfall
Joined Jun 2011
Originally Posted by penz83 View Post
Yeah you would just need the tx and rx, the converter is on eBay and the tail esc can be found at rtf-heli.
The v400 is 150 new, and you going to need batteries and all the mods your looking at an additional 150...
Left a message for you bloke on your add Cheers
Trelos05 is offline Find More Posts by Trelos05
Old Jun 20, 2012, 11:34 AM
fastfwd is offline
Joined Mar 2012
Tail spin test
Looks like i got the devo7 settings back to normal again notice the ugly white thing in front of the tail ? thats my home made tail guard as the plastic tail breaks so easy,this will hit before tail and save it
bumblebee-v400.avi (2 min 13 sec)
Old Jun 20, 2012, 02:42 PM
CO2X is offline
Find More Posts by CO2X
CO2X's Avatar
United States, CA, Hayward
Joined Oct 2010
v400
http://www.youtube.com/watch?v=j4rwk...ature=youtu.be
Nice flying and very stable my friend ! Nextime fly w/o the trainer balls...I think you don't need 'em.
CO2X is offline Find More Posts by CO2X
Old Jun 20, 2012, 03:07 PM
dilberto is offline
Human Being
Joined Jun 2011
That's another good one. I've had it before where i set my mesh only to find that the other side of the gear was too tight, now i look for the tightest part of the gear and set it there.
Tr, you may want to double check all around the gear that there is no binding anywhere, you should always have a little bit of back and forth play.
Fastfwd, Looking good there and glad to see you got it back up flying. I'm with Coco, you probably don't need the training feet any more. I left those on longer than i needed to and was surprised how easy the heli would take off and land on its feet. Also without them your heli will fly much better. But as always, go at your own pace
Old Jun 20, 2012, 03:09 PM
Folding Spacetime
Joined Jul 2011
Yep, very stable and you appear to have the heli under control at all times. If I was you, I'd shelve the training gear and practice taking off and landing smoothly without hitting the tail. Then, you won't have to worry about the fragility of the tail anymore.
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 10:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 05:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 09:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 09:50 PM
