Joined Feb 2010
I would like to see someone come up with a video on setting up a V400 for a low time pilot, and I thought RTF-Heli said they were looking into doing a series of set up videos. I would pay good money for that. Also, I think if you buy a heli from them, they will set it up for you to your specs or proficiency level, but don't quote me. SpadCat Edit: Here is the video:
kdean |
I want to take the "jerky", "all to sudden" movement of the elev and ailer control, or swash movement.
I think I need to play with the EXP, but there is also the Balance Delay on the rx. I guess its trial and error, though an error will cost me in spare parts after I crash. Im going to I turn up my gyro sensitivity, and I dont really want to use dual rates, I need to get used to flying with full swash extent. (just less sensitive) Before I start to mess with all these paramaters, I'm going to document the stock settings for a default setting, and when I find setting that works for me I will document them as well. (save/load) would be a nice feature.. Would a 2801 pro make this process easier? It would be nice to have one transmitter for all my V400's and their minor differences. |
Canada, ON, Ottawa
Joined Jun 2009
![]() On 2603, the tricky thing is that some of stuff are set by the knobs. And more than one knobs are activated under some menu and there is only one number display which tends to show us the value of the changing knob. It's really hard to figure out what it was set without changing anything. I guess we have to understand what we are doing after all. If someone has a good documented 2801 pro set up for V400D02, perhaps we may trying to set up the 2603 accordingly. D/R is fixed at 50% by flipping the switch on the 2603. We don't have to worry about configuring that. |
JD |
Also in the V400 handbook on page 7 it talks about the flight mode setting 6.3
under 1. adjust mode what is going on here is turning the gyro off so that you are not fighting it in this mode you can use the trim to level the swash once done you must adjust V1 tell red light is back on with the gyro on you can not use the trim or the gyro will fight it. So I did it by test flying with out going into the adj. mode hope this helps. JD |
Messing with settings
Today I hovered and trimed in my livingroom. I think I added some curve to my cyclic servos, not sure if i saved the setting. And put my gyro sensitivity to 100%. Alot more manageable in this close space. It is still a little 'twichy' but this came in handy when I had to pull some drastic manovers to avoid the side of the couch.
This heli is more forgiving on landings that I thought. Was able to land safely at strange angles. The landing skids really stick. I tried the dual rates and hated it. Both throttle and swash extent sucks the life out of the heli, and it feels strange haveing the throttle so high and no climbing action. Nothing broken = good flight..... Kdean |
Joined Jan 2011
Glad to see you got yours in a hover Kdean. Neither of my three have flown. I know its tempting to fly it in the living room, but this can end REALLY badly. Just touch a blade against something and your in for a repair job. ( Or worse)
I removed the zip ties on the ESC. Its taped with electrical tape right now, around the entire frame, until I figure something out. This clears the way in the battery cage. RTF-HELI zipped they're ESC to the skids I think, on the other side. Not pretty, but accomplishes the same thing. Clearance for the Batts. I make my own extensions for batts, since the ESC connection is so short, and I also make adapters now, since it seems that most batts, I think, are set up with Positive= female banana. Its clear that Walkera has made the V400 very much proprietary I think. 60 Something has helped me to understand alot, especially expo's, pitch/throttle curves, and alot more....read up on him here and in the other forum. Your doing good if you can hover it so close to the ground, like I said, I havent gotten off the ground. Keep up the good work. |
Thanx blayd,
Its only getting better...... Charged my only battery, until my shipments come in, and trimmed it out. I also, fixed th EXP on the transmitter, set it to 30%. I had to trim the rudder 39 degrees to the right. Tail just wanted to go that way all the time..... But now she is solid as a rock. ![]() I could not stop smiling. Hold hover at 1 meter up or even at 1 inch off the groung. One problem im haveing though, after a steep slide from either side or front to back the heli dips to the ground and will bounce off the skids. Is this normal? Is there a way I can tune that behavior out with the electronics? Or do I just have to get used to pumping the throttle during a bank slide? My FMS sim does not do this...LOL Charging, 2 hours Flight Time, Priceless kdean |
| Thread Tools | |
| Discussion Another new Walkera (V400D02)? | GetterDragun | Micro Helis | 130 | Apr 01, 2013 09:23 AM |
| Discussion Alternative canopies for Walkera V200D02, V400D02 | JumboA5 | Mini Helis | 2 | Mar 18, 2011 04:29 AM |
| Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 | JumboA5 | Electric Heli Talk | 2 | Dec 13, 2010 08:22 AM |
| Discussion Walkera new 3D flybarless V400D02 | Naev | 3D Electric Heli Flying | 2 | Oct 31, 2010 08:50 PM |
