Old May 09, 2011, 05:02 PM
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Originally Posted by vienquach View Post
The 2801 Rx does not work with the 2603. Could someone please confirm this?
Is there any Walkera Rx that we could purchase separately that work with 2603 radio?
Vien
the rx has to have the same or less channels as the tx for them to work. An 6ch tx can not control a 8ch rx, but an 8ch tx can control a 8ch - 6ch - 4ch rx
maybe not
Apparently, the 2806rx, that comes with the 1#A can bind with the 2603. Wow hobbies, parts for 1#A. $47
kdean is offline Find More Posts by kdean
Old May 09, 2011, 05:48 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Futaba 6EX could be used with the 8 channel Rx (working with CH1 - 6). Just an example.
I am looking for good receivers that work with the 2603 for ~$35.00 or less since my Hitec Aurora 9 could use Optima 6 receivers. They are $40.00 each and works really well.
Thank guys
Vien
vienquach is offline Find More Posts by vienquach
Old May 09, 2011, 09:26 PM
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Thank guys
Vien
yeah, just ignore that first part...
I looked into it and like i said, the 2806rx can work with the 2603tx.
Old May 09, 2011, 09:57 PM
Seattle, WA
Joined Feb 2011
Hey guys question for anyone replaced servos on my 400 because of crash i cant seem to get the arms adjusted the front arm bottoms out and hits the wires especialy in stunt mode and if i raise all the arms one notch the rears top out and change pitch at full forward and back especialy in stunt,no servo trim to adjust on 2603 im a newb anyideas would be apreciated THANX.Oh the servos are stock.
crashmaster324 is offline Find More Posts by crashmaster324
Old May 09, 2011, 10:11 PM
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
First off, get metal geared servos.
It sounds like you did not center your servos, with the gyro off, before putting your arms on.
Old May 09, 2011, 10:16 PM
Seattle, WA
Joined Feb 2011
How do you turn the gyro off.
Old May 09, 2011, 11:44 PM
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
I'll try to walk you through the whole process.
First, unplug your main and tail motor from the esc.
On the rx you will see the two little switches on the top. One is to reverse the pitch (leave that where it is), the other one is to turn on/off the gyro. Use that little black screwdriver looking thing that came with the heli to flip that switch to the off position. Both switches will then be in the off position.
Plug in the battery and bind with your tx.
Put your throttle stick to 50%, mid stick, half way up. Center your trims if you added any.
Your servo arms should be a bit below 90 degrees. Then flip you flight mode switch to the 1 or idel up position. Your arms should now move to a 90 degree angle. You have now centered your servos. Your blades should have 0 pitch.
If not, remove the servo arms and try to get them as close to 90 as you can. If you have to, its better to have them slightly down, and not up.
After you have your servo arms as close to 90 as you can, check to make sure yout swash is level. If not adjust the links between the servos and swash to get it level. If your using the stock servos, arms, and ball links, it should be level.
(the rest of this info is to properly set up your system, which may not have been done at the factory)
Getting your set up right is very important, yet offten overlooked by eager begginers, resulting in bad things...
You may have to adjust your PIT (pitch curve) and PLT (pitch travel) to get everything to line up. You should start this check with your pit at 0%, and your plt at 100%. Then using a pitch guage, set up your pitch curves for stunt and normal mode. (the stock blade pitch setting are in the manual)
When your servos are centered, the swash should be at the half way point between the stabalizer and the collar at top of the frame. The horizontal link on your stabalizer should be flat. You should then adjust your plt, making sure the servo arms do not travel too far up or down. Then take your blades off, and plug the main motor only in, too check if the swash and stabalizer arms are hitting at full throttle and full cyclic. I like to make sure i get good cyclic movement at both 0% and 100% throttle. If there is no binding, rubbing, or hitting, unplug your motor and then check and set your pitches again.
I know it sounds like alot of fun, but you will be able to fly knowing that your set up will not cause a fatal crash.
Old May 10, 2011, 12:06 AM
Seattle, WA
Joined Feb 2011
Thank you kdean
Old May 10, 2011, 12:33 PM
United States, CA, Rancho Santa Margarita
Joined May 2011
Thank you for this Kdean. Very helpful info.
mkalani is offline Find More Posts by mkalani
Old May 10, 2011, 05:59 PM
rustyh17's Avatar
USA, MO, Springfield
Joined Jan 2011
3D Flying -- Main Motor Power Question
I have the brushless RTF-HELI kit on this heli and I'm flying a lot of 3D. I am losing a lot of head speed on hard throttle moves (stunt mode, high rates). Is there any reason to believe the brushless motor in the kit is undersized for hard 3D flying? I am using stock blades, so I don't think it is "too much blade". I want to fly inverted and hover down near ground, but the head speed just drops off too much to make me comfortable. Any thoughts?
rustyh17 is offline Find More Posts by rustyh17
Old May 10, 2011, 06:07 PM
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
I had/have this problem with my rtf brushless system as well. After 86% throttle, the power drops. Wasp had the technical description of whats really happening. I just set 85% as my max throttle level on my tx. I think, using the rtf set up as a template, we need to try some bigger esc's and motors if you want real 3D head speed. Just remember to loctite.
Old May 10, 2011, 08:40 PM
Seattle, WA
Joined Feb 2011
Yeah thanks for trying but that sw on the rx switches between what they call normal flight or balance flight mode to turn the gyro off looks to be in the tx go to rudmix gyro in the tx and turn v1 knob to - until light on rx goes off if that is not correct sorry,but thats what i got out of the manual today after reading it 10 times.
Old May 11, 2011, 06:17 AM
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
"Normal" meaning no gyro - "Balance" meaning gyro on. or
"Adjust" meaning no gyro to make adjustments - "Work" meaning gyro working.
Turning the gyro off/on with the tx is the hard way, I was trying to keep it simple for you. Both ways will turn off gyro, just remember to turn it on after you've done your set-up. With the switch, you can see right away the status of your gyro and not have to flip through the tx settings. Alot of guys make the mistake of trying to fly after making adjustments and forget to turn the gyro back to the on or work position.
Good luck,
Old May 11, 2011, 09:46 AM
Seattle, WA
Joined Feb 2011
Good luck,
Thanx for explaining,has anyone tried flying on sw set to wk versus adj.
What do u think gyro should be set at?Can anyone tell me where a vid of adjusting blade pitch whould be or how to do it. THANX
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
