Old Apr 03, 2011, 10:01 AM
twalace is offline
Find More Posts by twalace
twalace's Avatar
Joined Feb 2011
Finally got my 3.5mm banana plug yesterday! Looks like I will be doing just as Wasp09 stated to install on my Blue Lipo 1300mah pack today.
Had another great full charge hover flight with no incident so I am really looking forward to some FF flights soon.
twalace is offline Find More Posts by twalace
Old Apr 03, 2011, 10:48 AM
kdean is offline
Find More Posts by kdean
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Earl,
I'm no pro, Im a dedicated noobie like most of the guys here.
The blades I got from Hobbypartz.com. EXI Carbon Fiber 325mm PRO 3D. I also got the yellow and black cf 325, they are the same as the 3D pros, but match the canopy better.
I've been flying the foam laminant blades from RTF. They are slightly longer, and lighter than stock blades, and will save your head and swash in a crash, but I really miss the feel of the 325mm. I'm gunna have to look for that size in foam, then I can practise my hardcore 3D and not be to afraid to crash.
kdean
kdean is offline Find More Posts by kdean
Old Apr 03, 2011, 10:56 AM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
twalace,
where did you get the 3.5 bananas from.
I orderd some 4.0 connectors but have not arrived yet. I was going to change the connection on the esc, but discovered that the connections on the blue lipos are opposite to walkeras connections. So, if i have to change the battery connetions anyway i might as well switch to the 3.5s.
Old Apr 03, 2011, 05:55 PM
twalace is offline
twalace's Avatar
Joined Feb 2011
Here is where I got my connectors: http://www.ampmodel.com/rc-accessori...-c-39_178.html
And yes it's easier to replace just the connector on the battery pack than everything. Just finished installing on my Blue Lipo pack with no problems.
Old Apr 03, 2011, 09:44 PM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Things to do this week.
I'm going to try and get my #1 up to snuff this week. With the brushless system installed and tested this weekend, Its time to install the HG5055 Servos, Metal Tail Boom Support (removing the struts), changing the Tail Fin/Motor Holder (cracked), and the Main Gear (a few teeth shaved in crash). And then set it all up to work with the EXI cf 325mm black and yellow main blades. The only thing I will need is to get my bigger batteries up and running.
kdean
Old Apr 03, 2011, 10:25 PM
twalace is offline
twalace's Avatar
Joined Feb 2011
Just finished 1st flight with new Blue Lipo 1300mah battery with no issues, guess I got the new 3.5mm banana plugs soldered on ok...lol
Old Apr 03, 2011, 10:39 PM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
hey twalace,
I dont think I can wait for the connectors to get here from Hong Kong, I need to find a place in the US that has them, Thanks for the Link...
Do you wanna sell two of yours?
kdean
Old Apr 04, 2011, 08:44 AM
ccowboyearl is offline
Find More Posts by ccowboyearl
ccowboyearl's Avatar
kentucky
Joined May 2009
kdean
On the foam blades your talking about, is that RTF heli?
Earl
ccowboyearl is offline Find More Posts by ccowboyearl
Old Apr 04, 2011, 11:27 AM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Earl
yes, thats the ones.
Old Apr 04, 2011, 11:33 AM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
So far so good
Got up this morning and was able to get the HS 5055s' in the servo brackets and ready to install. i took pics of the process and will post later. It was easier than I thought.
I also drilled the holes in my RTF metal boom support to fit, i got some from the "bad batch". No biggy.
Next, swap out the main gear, and put it all back together again.
Kdean
Old Apr 05, 2011, 08:20 AM
kentucky
Joined May 2009
kdean
I can't find the blades on their site. They don't have a search function. Tell me what i need to look under on their site to find them. Show us some good pics of your new servo nad how difficult they were to install. Also, do i need the brushless motor to handle the 325 blades or is the brushed strong enough?
Earl
Old Apr 05, 2011, 10:33 AM
kentucky
Joined May 2009
v400 D02 in stock
I just looked at xheli's site. Looks like the 400 is in stock. I can't find any 1300 mah blue lipos any where. Suggestions on other batteries or where i can get the blue lipos.
Old Apr 05, 2011, 12:18 PM
kdean is offline
BahamaHeli
kdean's Avatar
The Bahamas
Joined Dec 2010
Earl
Here is the link to the page,
http://www.rtf-heli.com/WALKERA_V400D02_SPAREPARTS.html
Here are another type of foam blades for the V400
http://www.wowhobbies.com/hm-1a-z-01...kera-1a-1.aspx
I will post a blog about the instalation of the Hitec servos. I ended up doing a little extra moding to get them right. They are not the "drop in replacements" I was hopeing they would be. But, they are a little eaiser to install than the Turnigys.
kdean
Old Apr 05, 2011, 01:47 PM
kentucky
Joined May 2009
Thanks, kdean
Thanks, for the info. Now if i can find some 1300 mah batteries I'm good to go.
Old Apr 05, 2011, 09:03 PM
SpadCat2000 is offline
Find More Posts by SpadCat2000
United States, AZ, Lake Havasu City
Joined Feb 2010
HobbyPartz has 1500mas and also 2200mas in stock. I use the 2200s all the time and unless you are doing 3D, they work fine for normal flight and the flight time is awesome. Price for both Lips are very reasonable, however, they come with 4mm connectors.
SpadCat
http://www.hobbypartz.com/bluelipo3s20c.html
SpadCat2000 is offline Find More Posts by SpadCat2000
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
