Old Sep 26, 2011, 11:54 PM
sam1741 is offline
Find More Posts by sam1741
Malaysia, Pulau Pinang, Tanjong Bungah
Joined Mar 2011
Originally Posted by SteelHeadz View Post
I tried that this weekend on my spare V400 RX. It didnt do squat for me. Let me know what your results are.
that is coool.....
waiting to see your result..
sam1741 is offline Find More Posts by sam1741
Old Sep 27, 2011, 11:03 AM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Originally Posted by sam1741 View Post
thanks Wasp,
So we no need a separate regulator, since it added weight also (especially with heatsink)
The connector to throttle from ESC, have 3 pin,
So i assume it would be signal, +5v , GND right?
So i just split the +5v and GND and connect it to the battery check on Rx, theoretically it will work?
i going to use multimeter to test out how much voltage the plug to Battery check from the stock brush-ESC
Solder a resistor between +5V pin and the signal pin of the connector, a 1000 to 500 ohms will do. Don't need the GND wire, just cut and wrap it up. Plug it into the power check port. Viva.
Normally the RX is fed via the throttle port. The +5V and GND pins on all the ports of the RX are parallel. Once we connect the ESC and battery, we would have +5V on all the middle pins of the RX. We would get roughly 3 to 4V on the power check signal pin. The RX should be happy with anything above 2V.
Enjoy.
Wasp09 is offline Find More Posts by Wasp09
Old Sep 27, 2011, 11:50 AM
Heli Biggie is offline
Find More Posts by Heli Biggie
They call me plan B
Heli Biggie's Avatar
United States, GA, Covington
Joined Mar 2011
I was getting ready for my new servos and found my swashplate stabilizer not lined up correctly. This was something i didnt check after the 1st wreck , so it could have binded during my tests with the brushless tail mod. So if thats the case then my tail mod worked perfect and the wire broke on impact with shed. At least i found it before next test. And for anyone having trouble, just another thing to check.
Heli Biggie is offline Find More Posts by Heli Biggie
Old Sep 27, 2011, 11:56 AM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Hi Wasp, I have a question that I think you could answer. I have a 450 clone and I want to be sure the motor is getting 100% power. It has a Hobbywing 40a esc and I've set the throttle limits with a linear curve so it should be at 100%. Now, can I check the voltage comming out of the esc to motor to be sure? How much should it be at full throttle if my batt is at say12.5 volts?
barnstorm100 is offline Find More Posts by barnstorm100
Old Sep 27, 2011, 02:59 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
Sorry, the ESC should be using pulses to drive brushless motor. I haven't made an BL ESC on my own yet, as the parts are likely to cost more than the finished product. Hence I haven't looked into how exactly it works.
The pulses are digital in a sense, i.e. on or off. At higher throttle, it should spend more time at the on state. It cannot be DC though. The ESC has to switch to each phase in sequence to drive a brushless motor. The commonly used cycling frequency should be 8KHz or 16KHz.
It would be hard to say what you will get on your multimeter, which isn't really designed to handle pulses not at 60 or 50Hz.
An oscilloscope may have a better chance.
At full throttle, I guess, by symmetry, we may be seeing 33.3% duty cycle per phase or 66.7% duty cycle if the ESC can fire at 2 phases at the same time.
You probably should be able to read more about ESC's on the web.
BTW, most ESC can calibrate the maxi throttle with a non-zero throttle at power up. However we may need a simple RX to do that. My RX-2618V would not allow the non-zero throttle to go through on power up. I have to program/calibrate my ESC on another RX.
Old Sep 27, 2011, 04:21 PM
Joined Jan 2011
Thanks Wasp
Old Sep 27, 2011, 08:03 PM
SteelHeadz is offline
Find More Posts by SteelHeadz
United States, TX, Kerrville
Joined Aug 2011
Enjoy.
Okay, i went to my local radio shack and found a 680ohm resistor. Got home and tried this out with the 2614V RX . I got better results with this on the ESC beeps i've been getting before this resistor. I have not finished playing with it yet, my wife calls.
SteelHeadz is offline Find More Posts by SteelHeadz
Old Sep 27, 2011, 08:30 PM
sam1741 is offline
Joined Mar 2011
Enjoy.
hmm... so this means the batt check needs something less than 5v, hense the resistor comes in?
so ... throttle cable from ESC,
split the +5, one side back to throttle on rx,
another end goes to resistor than goes to batt-check on rx
is it correct?
and no need to worry about the ground cause inside the RX it is parallel?
Old Sep 27, 2011, 11:19 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
The resistor is just for protection, safer than connecting the input to 5V directly in case the RX input breaks down and draws too much current.
Old Sep 27, 2011, 11:24 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
is it correct?
Yes, you can do it that way too by using your existing 1 wire connector, but you have to split one of your +5 connection. The resistor is there for protection.
Old Sep 28, 2011, 12:43 AM
sam1741 is offline
Joined Mar 2011
thanks wasp
i going try it out soon
Old Sep 28, 2011, 12:50 AM
dilberto is offline
Find More Posts by dilberto
Human Being
Joined Jun 2011
thanks wasp
whenever you guys get this worked out, please post a schematic. Even a picture of a hand drawn one would work wonders. Also, just so i'm clear that i'm following the conversation correctly, you guys are talking about getting the brushless esc to work without going through the stock esc, right? that would be pretty nice to get that one figured out
dilberto is offline Find More Posts by dilberto
Old Sep 28, 2011, 08:22 AM
sam1741 is offline
Joined Mar 2011
sure thing.. if i get it working i will post a pic
now i going to find myself an ESC
a picture is worth a thousand words.
Old Sep 28, 2011, 11:20 AM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
If you don't want to split the 5V wire on every ESC that you are going to use and have to move it around, it would be better to put the resistor on its own connector.
Old Sep 28, 2011, 08:47 PM
sam1741 is offline
Joined Mar 2011
i going to buy those "servo extension cable" that have male-female connector
and split from there.. so no harm done on the ESC ...
Discussion Another new Walkera (V400D02)? GetterDragun Micro Helis 130 Apr 01, 2013 09:23 AM
Discussion Alternative canopies for Walkera V200D02, V400D02 JumboA5 Mini Helis 2 Mar 18, 2011 04:29 AM
Question Transport devices for 2x Walkera V400D02 & 2x Walkera V200D02 JumboA5 Electric Heli Talk 2 Dec 13, 2010 08:22 AM
Discussion Walkera new 3D flybarless V400D02 Naev 3D Electric Heli Flying 2 Oct 31, 2010 08:50 PM
