Old Jan 16, 2011, 03:02 PM
Javis is offline
Find More Posts by Javis
Joined Dec 2004
Help!
How to make a magnetic actuator
Hi All,
I am trying to find plans or instructions to make a micro magnetic actuator. Can some one help me please? I know that these can be bought, but I want to make one myself.
Javis is offline Find More Posts by Javis
Old Jan 16, 2011, 03:19 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
An actuator is just a coil with a magnet centred in the coil.
Making them has been discussed often in the Indoor and Micro forum though less so recently. E.g.
http://www.rcgroups.com/forums/showthread.php?t=1121822
http://www.rcgroups.com/forums/showthread.php?t=894580
Steve
slipstick is offline Find More Posts by slipstick
Old Jan 17, 2011, 11:04 PM
Javis is offline
Joined Dec 2004
Steve
Thank you for the information. I really appreciate it.
Old Jan 19, 2011, 04:36 AM
MGeo is offline
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
This old thread also has much how-to info in it: http://www.rcgroups.com/forums/showt...light=actuator
MGeo is offline Find More Posts by MGeo
Old Jan 22, 2011, 03:20 PM
nickwasp is offline
Find More Posts by nickwasp
Joined Jan 2011
check this video out this is how i learnd... SUPER EASY!!
Actuator Servo Home-built video (very Cheap) (6 min 31 sec)
nickwasp is offline Find More Posts by nickwasp
Old Feb 16, 2011, 06:01 AM
Schermvlieger is offline
Find More Posts by Schermvlieger
I love HAM
Joined Nov 2005
Hi all,
I am trying to make a 25 Ohm coil and found some wire inside an old brushed motor. There were three windings in it; took one off and ended up with a 1.75m (5.8') piece of wire that looks to be about 0.2mm thick (including insulation)
The resistance of this length stretched out is ~3 Ohm. I then wound it up in a coil and measured resistance again, and it is still 3 Ohm. I never was very good in physics class (too busy chasing the girls) but I thought the resistance would be higher when the wire is wound up in a coil?
Will I be needing 14.5m (48') of wire to achieve my desired resistance of 25 Ohm? I was hoping to make something very small to put on one of those X-Twin planes but with such a big coil I wonder if it's going to be able to take off at all
Please help out this electronically challenged old fart; I promise I'll pay attention this time
Schermvlieger is offline Find More Posts by Schermvlieger
Old Feb 16, 2011, 06:23 AM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
The resistance will not change due to winding a coil. What changes is the inductance! This is very important for a coil. It causes the current to ramp
up, and be limited as long as the core is not saturated. With no core,
you have an air core inductor. Not sure about the dynamics of a magnet core, but there is more than resistance at play here. The L of your coil will cause it to draw less current than the straight wire. The magnetic force on the magnet is proportional to the current.
jglenn is offline Find More Posts by jglenn
Old Feb 16, 2011, 07:23 AM
I love HAM
Joined Nov 2005
Thanks jglenn!
Does that mean that - using this wire I mentioned - I would really need about 48' to reach the desired resistance? It seems like an awful lot to me. Do I need to use thinner wire for the application that I have in mind?
Old Feb 16, 2011, 07:25 AM
Staffs, UK
Joined Nov 2003
Resistance is basically defined by the length (and size) of wire. Winding into a coil has no effect at all on the resistance.
So yes, you either need much thinner wire or a much greater length.
Steve
Old Feb 16, 2011, 07:29 AM
I love HAM
Joined Nov 2005
Thanks Steve!
Old Feb 16, 2011, 05:45 PM
jglenn is offline
Ohio
Joined Nov 2003
Scherm:
I don't know where you got your specs from. There are a lot of tradeoffs between wire gauge, R, current, field intensity, etc. That much wire will
take a huge bobbin, unless as fine as hair. That fine is hard to strip,
taking the enamel off the ends. They have polythermaleze wire that you
just solder, and it goes thru. Here are some links to help:
http://www.tpub.com/neets/book2/1b.htm
http://www.pa.msu.edu/courses/2000fa.../solenoid.html
http://hyperphysics.phy-astr.gsu.edu.../solenoid.html
THis last one has a calculator spreadsheet thing.
Help! how do u make esc waterproof tekin rx8 combo etc and more sytem to make waterproof stampede vxl Off-road Cars 7 Dec 24, 2010 09:32 PM
How to make an actuator ( step by step ) Paul Penney Scratchbuilt Indoor and Micro Models 209 Apr 20, 2009 03:42 PM
Question How connect "magnetic actuator" to receiver ueliisa Scratchbuilt Indoor and Micro Models 3 Nov 17, 2006 12:53 PM
Hello, new to the forum. How do you make a coil actuator flap? FlipperSail Ornithopters 13 Aug 06, 2004 07:31 AM
Alert how to make actuator coils for micro models youth must fly Scratchbuilt Indoor and Micro Models 3 Jun 14, 2004 01:19 PM
