Old Jan 16, 2011, 01:00 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Welding sets for modelers..
Brad and I spent the entire day yesterday looking
for a small gas welding set suitable for modeling.
Welding supply houses, pawn shops, lumber
yards, parts stores, so on, so on...
It looked like no one had anything that was
what we needed or it was too $$. The big
welding supplier could fix us up for about $800.
Set, tanks, gas, rod, flux, goggles.
Today Brad went out riding his bike, nice
day, and checked a couple more pawn shops
we missed yesterday. On the way home he
stopped by Tractor Supply just on the slight
chance they might have something we could
use.
Well, he hit the jackpot.
Worthington WK5500 ox, complete set, tanks
torch, hose stand, regulators, striker, and
some rods, assorted..
And it is just what we needed to do the stuff
on the airboat he is working on. Welding 3/16th
steel tubing.
$54.95, regular price.
http://www.theezcatalog.com/index.as...e=1&sku=438669
Kimber is offline Find More Posts by Kimber
Old Jan 16, 2011, 01:40 AM
Umi_Ryuzuki is online now
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
And,... What are you going to build using that?
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old Jan 16, 2011, 02:00 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Brad is working on a scale, 1/6th, airboat.
He is welding up the guard for the prop and
all the motor mounts, seat mounts and stuff
like that.
It will look something like this:
Old Jan 16, 2011, 02:40 AM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Using that, he could weld up the hull too.
Old Jan 16, 2011, 07:00 AM
jjac is offline
Find More Posts by jjac
I'm tired.....
jjac's Avatar
Conway,Myrtle Beach SC
Joined Jul 2009
I have on of those sets, got it at Lowes. The oxy tanks do not last long at all, so turn it off when your not using it!
jjac is offline Find More Posts by jjac
Old Jan 16, 2011, 07:25 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Thanks, the book says about 30 minutes tops!
They are $8 at Lowes. The gas should last
a couple hours. You can use propane but it
is a little slower we are told. We will check
it out and let you know.
Considering the smallest bottle of O2 at the
welding shop was near $200, this seems to
be the way to go for what we are doing.
Old Jan 16, 2011, 08:34 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Have fun!
In those sizes, I'd go for brass and silver solder... but aluminum and TIG would sure be sweet!
patmat2350 is offline Find More Posts by patmat2350
Old Jan 16, 2011, 08:51 AM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
For what its worth..
Heres what Ive done..
I went to my shop foreman and got 100lb bottles..I pay for the gas there and return the bottles there..Because as a resident to get the big bottles of Gas ,oxy,acet,argon..it can run almost $300 deposit on the bottle..each bottle
smaller bottles can be had as well ,20-50lb'ers
..Ask a few friends,,even your regular mechanic..for what you'll be using it might be worth it ..
more coffee is offline Find More Posts by more coffee
Old Jan 16, 2011, 02:31 PM
GreenAmphibian is offline
Find More Posts by GreenAmphibian
Semper Fi
GreenAmphibian's Avatar
Northern Triaid North Carolina
Joined Jun 2008
You can work with aluminum solder on aluminum sheets and rods with Oxy/Acet units also. We did it in the USMC on small stuff, used Mig and Tig on the thicker stuff.
GreenAmphibian is offline Find More Posts by GreenAmphibian
Old Jan 16, 2011, 02:55 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I bought one of those sets years back and yes you go thru the oxygen quite fast and it's expensive. I would run out at the worst possible time. Another thing was the valves, one big piece of garbage. You couldn't get them down far enough to do small work and the flow rate would constantly keep changing. Instead I just got a #1 tip for my big torch setup and have been happy since.
You'd be better off getting one of those portabe tank setups and get a small welding tip. http://www.harborfreight.com/portabl...nks-65818.html
If you want something smaller then you can change the whole handle and tip to a micro one. http://www.harborfreight.com/micro-s...kit-95671.html
green-boat is offline Find More Posts by green-boat
Old Jan 16, 2011, 05:19 PM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
Gotta agree with green-boat, the little micro tipped torch is a fantastic little tool. Fully functional Oxy-Acetylene with pinpoint accuracy!!
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Jan 16, 2011, 05:27 PM
Cheif Bottlewasher
Joined Sep 2005
Only problem with that system green boat ,The Tanks have to be tested before they get filled,If the outlet even accepts them for testing. cant say for every where but if they do ,a quick exchange is out of the question.wont accept them..
Queried about that myself..still another 150 for testing,then filled..and at the dealers discretion they can be inspected and tested each time a guy brings them in
Old Jan 16, 2011, 05:50 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
GB, that would be fine if we were planning on doing
a lot, but this is for one project maybe.
Those two items are near $400. Then there is
still the matter of gas.
We have two old tanks and they quoted us about
$500 to test and fill them, if they passed the
test. They are over twenty years old and have
been sitting out for over ten. Brad has an old
welding set, same age as the tanks and has been
stored of over ten years, the hose is not safe
and the regulators are in question.
Brad bought a case of O2 for $84 and that
should last us a long time. He will still use the
propane for light stuff and aluminum welding.
He bought a bead blaster today, can't wait to
play with it. The neighbor is a stone mason
and he paid half and bought a wet grinder so
Brad can sharpen and clean his tools. Brad had
a coupon and the blaster was on sale so the
neighbor paid fifty and Brad paid ten...
Brad has done some test joints with the little
welder and it really works well on the very same
stuff. Real silver solder is about $140 a pound
so the brass, $11 a pound, will be fine for our
project.
If we were trying to do this to make money
and doing it everyday, we might have gone
a different direction, but this is just a hobby.
The blaster cabinet is really neat, like working
with nuke stuff...
Old Jan 16, 2011, 06:18 PM
Henry455 is offline
Find More Posts by Henry455
United States, TX, Houston
Joined Jun 2010
I have had one of these for over 25 years Microflame . Paid $19.95 for mine. Good for small projects.
Henry455 is offline Find More Posts by Henry455
Old Jan 16, 2011, 10:23 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
I made my cage out of aluminum using aluminum solder.
Air boats tend to get top heavy.
MILLERTIME is offline Find More Posts by MILLERTIME
For Sale 3 sets Airy Harden blades for coaxial and fixed pitch Fastleft Aircraft - Electric - Helis (FS/W) 1 Dec 21, 2010 11:02 AM
Question Welding-grade Helium for balloons? dimsumblimp Blimps 2 Nov 23, 2010 09:50 AM
Discussion New Rapid Fix welding glue perfect for model building Jack252 Hot Online Deals 7 Nov 11, 2010 06:22 PM
Wanted "Sailplanes! A Digest for Scale Modelers" book aero104 Aircraft - Sailplanes (FS/W) 5 Oct 30, 2010 01:42 PM
Discussion Welding Video - DIY Workbench experimentalrc Chit Chat 1 Oct 28, 2010 10:03 PM
