This thread is privately moderated by cass3825, who may elect to delete unwanted replies.
Old Jan 15, 2011, 09:33 PM
cass3825 is offline
Find More Posts by cass3825
Joined Feb 2005
Processing GUI
testGUI
cass3825 is offline Find More Posts by cass3825
Old Jan 16, 2011, 12:19 AM
cass3825 is offline
Joined Feb 2005
rev 1
Old Jan 17, 2011, 09:59 PM
cass3825 is offline
Joined Feb 2005
belt driven cp quad idea
just a sketch... The motor pinion in the center will mesh with two opposing gears like this (top and bottom gears in the pic). The other gears (left and right) will mesh with the top and bottom gears, rotating in the opposite direction.
Old Feb 01, 2011, 05:07 PM
cass3825 is offline
Joined Feb 2005
'duino sketch...
for Jussi.
Old Feb 27, 2011, 02:00 AM
krial is offline
Find More Posts by krial
Joined Sep 2007
Its nice to see others also is pondering on the idea of a variable pitch multirotor. Your idea is very good, but I think it need a one way bearing somewhere, because if you use heli blades, their momentum will rip apart the gears when you cut throttle.
What if you put a 450 main gear with the clutch bearing in the middle and let this mesh with the four gears with the belt pulleys?
krial is offline Find More Posts by krial
Sold Fromeco "ion3 Cube" 3-port with GUI display (Li-ion) aero104 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 05, 2011 08:35 PM
