Old Mar 10, 2011, 01:26 AM
leopold1 is offline
Find More Posts by leopold1
Belgium
Joined Sep 2010
I just love this design. Just great. I would certainly try to integrate Ardupirate HW
Do you have ETA oninterior, landing gear and Gopro support?
Thx
leopold1 is offline Find More Posts by leopold1
Old Mar 10, 2011, 07:50 AM
DeXX is offline
Find More Posts by DeXX
DeXX's Avatar
Croatia
Joined Nov 2009
Thx
tnx, I am also waiting for ardu parts to try
landing gear (FPV box) molds will be completed in one month approx...
I could finish a lot faster, but orders are stopping me
Denis
DeXX is offline Find More Posts by DeXX
Latest blog entry: FPV Bullseye
Old Mar 10, 2011, 08:01 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
the quality of this frame is exactly as i hoped! also the hull is larger then i thought! also the separate piece arms make for good easy crash repair! top quality dex! here the pics when i received it.
Quad_Addict is offline Find More Posts by Quad_Addict
Reply With Quote  (Disabled)
Old Mar 10, 2011, 08:43 AM
leopold1 is offline
Belgium
Joined Sep 2010
Denis
Keep up the good work.
I'm looking forward to your new ideas!!
Old Mar 10, 2011, 10:59 PM
kx315 is offline
Find More Posts by kx315
FPV/Quad Copter Noob!!
kx315's Avatar
Perth Western Australia
Joined Aug 2007
Subscribed waiting eagerly for the FPV Go Pro version as this is exactly what I need to do this type of filming
SURF - Quadrocopter HD - Byron Bay - Australia (2 min 5 sec)
kx315 is offline Find More Posts by kx315
Old Mar 15, 2011, 08:50 AM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
Some Quad color combination....
Old Mar 25, 2011, 04:34 AM
leopold1 is offline
Belgium
Joined Sep 2010
Cool.
Any more news on the gopro mount, interior mount and landing gear?
Will it be possible to order spare arms?
Old Mar 26, 2011, 05:53 PM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
Cool.
Only a few more days and the FPV box will be ready for production
I broke my brain on that piece...
2 attempts were gone in the wrong direction, a lot of curves and hollows, 4 piece mold, etc.
I was not very satisfied
So the third time I made a simple and clean design and now I'm very pleased with the look and dimensions(2 liter box)
the prototype is finished, On Wednesday I will have the first cast,
will try it out on my FPV model immediately and I'll put a pictures on the forum
yes, it is possible to order all spare parts
Old Mar 26, 2011, 07:27 PM
kx315 is offline
kx315's Avatar
Joined Aug 2007
Way to go Dexx can't wait to see the pictures!! What will the bare weight of the unit be??
Old Mar 29, 2011, 10:04 AM
serbcccc3 is offline
Find More Posts by serbcccc3
USA, TX, Houston
Joined Jan 2011
Controller Mounting
Dex,
I have a question/concern.
Currently on my quad, my controller with all sensors is mounted at the CG, specifically for the acceleromater sensors which need to be as close to the CG as possible. Also, with the battery really needing to be close to the CG as well, im wondering how "do-able" that is inside the fuselage?
Would there be enough vertical clearance inside the frame to mount the controller below the battery, both in the center of the pod?
Another question, what are the arms/body made of? I went through the thread and I dont think I saw anything about what they are made of. My concern is replacing a broken arm, will I have to order from you replacement arms or is it something I can purchase locally?
Thanks!
M
Oh, and the frame looks awesome!
serbcccc3 is offline Find More Posts by serbcccc3
Old Mar 29, 2011, 09:23 PM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
I just pulled out from the oven first cast, 135g bare weight
here is very late, passed 4 hours in the morning and I worked 18 hours in piece
I'm barely watching the monitor
only briefly....
lid opening is 135mm diameter, quad pod diameter is 170mm,
200mm is diameter from the beginning of the tube to the beginning of opposite tube
inner height of pod( thickness from the bottom of the pod to the inner top of the
lid) is exactly 73mm
whole model is made from composite materials, 100% glass fiber and epoxy resin
tubes also, 4 piece tube set is 1/10 of the total model cost...
tube dimensions:
inner diameter 20,5mm
wall thickness 0,5mm
10cm tube has 6 grams
FPV box dimensions:
diameter 170mm
height 90mm, but overlaps with the pod, so it turns out 67mm inner height of the box...
when you cut the bottom of the pod, and glue the box on the pod It turns out exactly 140mm inner height
and total volume of about 3 liters
I'll put pictures as soon as I wake up and answer the rest of what I forgot
Old Mar 29, 2011, 09:35 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
How small do you think you can make one using the standard center pod? Wondering if you can make the arms short enough to just hold the motor mounts to the center.
Think you can get it down to 12" motor to motor? 10"?
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Mar 29, 2011, 09:45 PM
Joined Dec 2006
only briefly....
tube dimensions:
FPV box dimensions:
diameter 170mm
yes hurry, i need one!
Old Mar 30, 2011, 03:06 PM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
Here's pictures of my model made today...
I will photo the entire model build, with all Eagle Tree telemetry and mounting aluminum heatsink for ESC's and video link transmitter....
Old Mar 30, 2011, 04:25 PM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
if you go in the extreme cutting you could reduce to 30cm shaft to shaft without a problem...
I measured, less than that is not possible
Discussion Quad brushless motors and quad ESC wiring whatala Power Systems 11 Dec 28, 2015 03:51 PM
Build Log STM8s Quad-copter "Quad-radic" Edftakeoff Multirotor Talk 4 May 17, 2010 03:09 AM
Discussion New Dex Blades in Stock Now johnIn2SonAZ Micro Helis 0 Jul 01, 2009 05:12 AM
Sold DEX Blades for Walkera 4G3, 4#3a/b Steve_C Aircraft - Electric - Helis (FS/W) 4 Feb 09, 2009 08:09 PM
quad cdr quad esc how many poly cells? captinnitro Power Systems 2 Apr 04, 2005 08:37 PM
