Old Jan 15, 2011, 07:57 PM
DeXX is offline
Find More Posts by DeXX
DeXX's Avatar
Croatia
Joined Nov 2009
New Product
DeX Quad
Hello, my name is Denis and I would like to introduce DeX Quads
This entire models are from composite materials.... and they can float
all my models are connected wet on wet, I do not use a vacuum, everything is handmade
because it is the only way when the strength, looks and weight are perfect and the only way to get models in one piece (top and bottom connected without the possibility of cracking in half)
I do not use paint on surface, just pigment for resin
colors:
Red, Blue, Orange, Green, Yellow, Black, camouflage black/white, camouflage blue/white and full carbon version
cool and useful feature: Recovery from upside down position on water
DeX Quad Water Recovery (3 min 5 sec)
DeX Quad
main parts are:
body
engine holders
and tubes
body and engine holders are stronger than tubes so only the tube will splinter when a crash occurs,
it is very quick and easy to replace parts after a strong crash
tubes are not glued to body and holders
on body and holders is a layer of transparent duct tape
so that the tube goes extremely tight on the body and engine mounts
tubes can be different lengths from 10cm to 20cm
10cm tube gives 50cm (20 inch) Quad diameter
empty Quad with 10cm tubes has around 250g
The best thing is that everyone can fly 10cm tubes or 20cm tubes in just a few minutes of work to replace them on the field
strength of the hull is excellent
I hit the asphalt road a few times and nothing yet
DeX Quad (4 min 7 sec)
DeX Mini Quad
12'' 305mm from shaft to shaft
model is in one piece ready for water, swims from 300g to almost 1kg, but the best floating weight is from 400g to 800g
glass fibre is from 140 to 150g
carbon fibre is about 110g, 120g
DeX Mini Quad Crash Test (7 min 10 sec)
DeX Micro Quad
190mm from shaft to shaft,
model is in one piece ready for water, swims up to 350g perfectly
model weight is from 30g up... but.... the best strength is from 50g to 55g especially for full carbon model and that's my target weight
DeX Micro Quad and Water (3 min 21 sec)
some more on PM or dex@dexmodels.com
I'll give my best with responding
DeXX is offline Find More Posts by DeXX
Old Jan 15, 2011, 08:18 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Well done!
NaterPin is offline Find More Posts by NaterPin
Old Jan 15, 2011, 09:06 PM
3rdeyepro is offline
Find More Posts by 3rdeyepro
Hovership
3rdeyepro's Avatar
United States, CA, Cupertino
Joined Aug 2010
Dude, first time I have seen someone land a multirotor on water without "floaties" That frame rocks!
3rdeyepro is offline Find More Posts by 3rdeyepro
Old Jan 15, 2011, 11:26 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
looking really nice. I'm sure many of us fly over water often
thanhTran is offline Find More Posts by thanhTran
Old Jan 15, 2011, 11:48 PM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
nice job dex, can i buy the frame?
Quad_Addict is offline Find More Posts by Quad_Addict
Reply With Quote  (Disabled)
Old Jan 15, 2011, 11:58 PM
blindflight is offline
Find More Posts by blindflight
blindflight's Avatar
CA
Joined Dec 2003
Very nice compact design , looking forward to more info and intro prices.
blindflight is offline Find More Posts by blindflight
Old Jan 16, 2011, 07:48 AM
FacinatedFPV is offline
Find More Posts by FacinatedFPV
Facinated w/FPV & Multicopters
Germany, SN, Chemnitz
Joined Jan 2011
This is outstanding! Great video. Great product!
FacinatedFPV is offline Find More Posts by FacinatedFPV
Old Jan 16, 2011, 09:39 AM
QuadcoptersUk is offline
Find More Posts by QuadcoptersUk
Multi-Rotor Mad
QuadcoptersUk's Avatar
UK
Joined Jul 2010
Fantastic design and great idea Pm sent
QuadcoptersUk is offline Find More Posts by QuadcoptersUk
Old Jan 16, 2011, 09:45 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I need one of these! Very nice! How much and when/where to order?
lovegroove is offline Find More Posts by lovegroove
Old Jan 16, 2011, 01:33 PM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
wow, this is a very good response to the model
guys, thank you all for nice comments
I forgot to mention the full carbon version also...
production and sales will begin in approximately 10 days
I need to make a couple of DeX SAL models left behind and then I will be primarily dedicated to the Quad
I have a few ideas that would upgrade the Quad for FPV, but they are for now still only ideas
the same as "blindflight" mentioned to me.... I was thinking about making the interior,
but since I like to be very rough with models I really liked sponge as a simple solution....
I know that some will need "the interior" so this is first on the list....
and of course, do not be angry if I do not respond immediately to all your private messages....there are a "few" of them
Latest blog entry: FPV Bullseye
Old Jan 16, 2011, 01:40 PM
CA
Joined Dec 2003
Interior Idea?
"the same as "blindflight" mentioned to me.... I was thinking about making the interior,
but since I like to be very rough with models I really liked sponge as a simple solution...."
Or just a interior contour piece that we could glue in and use.
Old Jan 16, 2011, 01:53 PM
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
One tip for the fpv version don't make it out of carbon. Carbon blocks radio signals. Make it out of glassfiber.
hugy is offline Find More Posts by hugy
Old Jan 16, 2011, 03:44 PM
Malx is offline
Find More Posts by Malx
Joined Dec 2010
Would be nice to have one carrying a waterproof GoPro HD in a nice camera mount.
However I'm having a little concern about the cooling of the ESC:s.
Malx is offline Find More Posts by Malx
Old Jan 17, 2011, 05:31 PM
DavorVZ is offline
Find More Posts by DavorVZ
Croatia
Joined Jun 2010
cooling is not a problem, you can land it in water
DavorVZ is offline Find More Posts by DavorVZ
Old Jan 18, 2011, 07:48 AM
DeXX is offline
DeXX's Avatar
Croatia
Joined Nov 2009
you're right....
my setup is:
1x KKmulticopter Flight Controller v.6
4x 2205C 1400Kv Brushless motor
4x TURNIGY Plush 10amp Speed Controller
4x GWS Propeller DD-8040
Turnigy nano-tech 3S 2650mAh
my flight time is from 12 to 15 minutes with this setup....
I have 2 covers for body
one has 4 small holes(8mm diameter) on it and another does not
If I use one with holes I have no problem, but this cover is only for normal flight and soft landing on the water
cover without holes, and permanently rubber sealing strip on the edge of the cover give me the option of a strong impact on the water
model can splash and dive even for a second when it hits the water... without fear that the water enters
but then with my setup I have 8-10 minutes of flight before the speed controllers overheats
this is easy to recognize becouse the model has a sudden lack of power....
then I wait a few minutes(2-3min) and then I can continue to drain the battery until the end
solution to this would be to use stronger(18A) speed controllers
but again... I mostly use cover with holes on top and I'm carefull about landing on the water
mainly because of ball bearings in the motors because they would quickly become rusty
Discussion Quad brushless motors and quad ESC wiring whatala Power Systems 11 Dec 28, 2015 04:51 PM
Build Log STM8s Quad-copter "Quad-radic" Edftakeoff Multirotor Talk 4 May 17, 2010 04:09 AM
Discussion New Dex Blades in Stock Now johnIn2SonAZ Micro Helis 0 Jul 01, 2009 06:12 AM
Sold DEX Blades for Walkera 4G3, 4#3a/b Steve_C Aircraft - Electric - Helis (FS/W) 4 Feb 09, 2009 09:09 PM
quad cdr quad esc how many poly cells? captinnitro Power Systems 2 Apr 04, 2005 09:37 PM
