Old Jan 15, 2011, 01:04 PM
lectroglide is online now
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
Question
What servos for hk 450 pro??
anyone here know what servos "or what the deminsions are" for the HK 450....Im looking for servos that will fit this model,,,,thanx
lectroglide is online now Find More Posts by lectroglide
Old Jan 16, 2011, 01:15 AM
TeeJayShelton is offline
Find More Posts by TeeJayShelton
Joined Sep 2010
lots of choices the from hobby king the 922's work well on cyclic, fast digital metal gear.... Personally I prefer Hitec 5065 mg's...
if you want the cheapest that will work well (wont handle a crash though) hxt900 (also available from HK..
search for gotek 9257 again at hobbyking for a tail servo for that bird....
first CP heli?
TeeJayShelton is offline Find More Posts by TeeJayShelton
Old Jan 16, 2011, 08:49 AM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
My cheapo setup is 3 HXT900's for Cyclic and an HS-81 on the tail. Pretty quick servos for sport flying... no match for 3D.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jan 19, 2011, 01:33 PM
gonepostal- is offline
Find More Posts by gonepostal-
california
Joined Feb 2010
if you are building that heli thread lock EVERYTHING!!!!! i had one come apart on me! it sucked, then i bought a copter x by far the best clone on the market!!!!
gonepostal- is offline Find More Posts by gonepostal-
Old Jan 19, 2011, 03:09 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I'm using Hextronik MG-14 in my 450Pros. Not expensive but center well unlike the HXT900 which I installed in a $9.99 HK450 frame.
ivanc is offline Find More Posts by ivanc
Old Jan 19, 2011, 03:17 PM
ZamBeZi is offline
Find More Posts by ZamBeZi
The Hague, Netherlands
Joined Nov 2006
HS-81 on the tail
at least a fast digital like the DS-480
ZamBeZi is offline Find More Posts by ZamBeZi
Old Jan 19, 2011, 09:36 PM
Joined Aug 2006
first CP heli?
am no stranger to helis by any means, and had a EXI 450 "not to mention many others"then sold it but just now got a HK 450 pro which Im very pleased with..anyway I have some questions about this model so need to pursue that
Old Jan 19, 2011, 09:40 PM
AMA 537620
Joined Oct 2008
Originally Posted by ZamBeZi View Post
HS-81 on the tail
It's a good cheap .11 second (on 4.8v) servo. It's just fine for sport flying and light aerobatics.
Old Jan 25, 2011, 12:10 PM
california
Joined Feb 2010
this is the best servo you can get for your cyclic and i found them real cheap! http://cgi.ebay.com/3x-Hitec-HS-65MG...item41476299c6
Old Jan 25, 2011, 09:50 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
On my beater: I use tp90mgs on cyclic and a kds ds480 on the tail, keeps goin and goin and goin!. Love it! Nothing lasts long if you prang them to often though!!. PB
prop bender is offline Find More Posts by prop bender
Old Jan 25, 2011, 10:29 PM
rangamatchstic is offline
Find More Posts by rangamatchstic
Mt helena western australia
Joined May 2009
im using hxt900 on cyclic in my hk450, also i found with mine it didnt need lock tight at all! all the screws were already lock tighted, and i bought mine a few weeks ago, the hxt900 are good strog smooth enough servos, and on tail i have a emax es9257 that i won in a competion, and it workes great!! 0.05 seconds at 6v, more then i need for basic sport fling, but will be excellent for 3D.
rangamatchstic is offline Find More Posts by rangamatchstic
Old Jan 26, 2011, 09:58 AM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
here is what I'm using (12 flights so far...pleased beginner!)
Alpha 400 (3500kv) Brushless Motor for 400/450 RC Helicopter
13T pinion
Emax 35A + 3A switch UBEC
9G EXI Digital Servo D113F x 3
TP MG16R Digital Metal Gear Micro Servo – tail
Detrum GY48V headklock gyro for 3D Helicopters
220mm align flybar , align tail servo boom mounts
Normal:
Pitch: -3 to +9 (0 at mid stick)
Throttle: 0 60 85 90 100
Idle Up:
Pitch: -9 to +9 (0 at mid stick)
Throttle: 100 90 85 90 100
Hold:
Throttle: 0 0 0 0 0
TexasClouds is offline Find More Posts by TexasClouds
Old Jan 31, 2011, 09:50 AM
Joined Aug 2006
yo...found some at hobbypartz T-PRO MG90S that fit like a glove and thier metal gear to boot, $7 ea. so far so good!
Old Jan 31, 2011, 09:52 AM
Joined Aug 2006
yep, all screws were tight on mine too.they must be reading our threads....oopss I was mistaken.....after a couple flights the the boom block screws were loose and the boom started to twist, easy fix
Old Feb 01, 2011, 05:05 AM
Joined May 2009
sweet
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
Wanted Just bought a 450 pro and need the electronics since I need electronics for a 450 pro nyesteban Aircraft - Electric - Helis (FS/W) 3 Oct 19, 2010 04:43 PM
Discussion HK 450 Pro Belt tail tomd27858 Mini Helis 3 Sep 17, 2010 06:45 PM
Discussion What is better HK-450 Pro or EXI-450 Pro??? JStory Mini Helis 14 Sep 02, 2010 07:58 PM
Discussion Where to find a feathering shaft for the HK-450 Pro? JStory Mini Helis 6 May 17, 2010 04:13 PM
