Old Jan 14, 2011, 11:26 PM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
Build Log
RC Aerodyne (scaleflying.com) Beechcraft Baron G58 Composite ARF
RC Aerodyne Beechcraft Baron G58 Composite ARF (2 min 10 sec)
Special tooling
has been developed to make the fuselage as light as possible.
Pressurized tooling allow for an extremely light weight epoxy fuselage
with carbon fiber re-enforcement's. The model also has working doors
produced from the lightest fiberglass and epoxy available. This not
only adds to the realism of the model but allows for a very attractive
display model showing an accurate replication of the real aircraft's
interiors.
Wing 3pc
wing design. Allows for easy wing removal and maintenance. Lightweight
fully sheeted balsa wing. Printed panel lines and rivet detail
accurately positioned just like the real aircraft. All control surfaces
are hidden in the wing including flaps and ailerons. The 75" wingspan
allows for very predictable and gentle flight characteristics.
Landing Gear ( sold separately )
Special
landing gear has been developed for the Baron 58. The design allows for
a very scale like landing but also prevents the aircraft from bouncing
back into the air. When on the ground, the 1" of travel is 90%
compressed, and when on approach it is fully uncompressed, ready to
absorb unfavorable surface conditions and also help the pilot in
situations that are unexpected before touch down.
CNC machined aluminum scale landing gear system. 5mm hole for mounting to most retracts.
Scale Detail
Special
attention has been given to the actual aircraft panel lines details.
With all the scale features molded directly into the fuselage, it saves
hours of time for the scale enthusiast. The information from hawker
beechcraft plans and photos, the positioning of these items and details
are extremely accurate to the real aircraft.
LED lighting system ( sold separately )
A scale lighting system is also available . Included are the correct
lights, motherboard, and 2 switches for system control. NAV lights (
red , green, flashing red, white strobes, and 2 landing lights ).
Electric or Gas
The firewall has been specially designed to allow for both use of Gas or
Electric motors. Appropriate angled thrust lines have been developed
to ensure safe and coordinated flight characteristics.
Power recommendations: .32 - .46 glow or electric equivalent.
Our flight tests with electric show a very short takeoff distance. Using
Eflite 32's gave the baron plenty of power for take off and sport
flying.
For electric users, the removable nose cone and easy slide
in / out battery tray provides quick access for battery install or
changes. The design allows for 1 large battery or 2 smaller batteries.
Scale Cockpit / Interior ( sold separately )
The scale cockpit and interior displays all 6 seats including the control panel with gauges.
SPECIFICATIONS
Stock Number: RC AB58
Wingspan: 76.5 in (1905 mm)
Weight: 13.5 lb (6.6 kg)
Fuselage Length: 61 in (1680 mm)
Requires:
Two . 32 cu in (5.2cc) 2-stroke engines & minimum 6-channel radio
w/6 servos. Optional retracts require 1 additional servo.
Ailerons (1 servo ) or traditional 2 servo per control surface
Elevator ( 1 servo )
Rudder ( 1 servo ) or can be combined with steering servo with flexible push rod
Flaps ( 1 servo ) or traditional 2 servo per control surface
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Jan 14, 2011, 11:35 PM
FlyBoyTha1's Avatar
Joined Sep 2008
RC Aerodyne Beechcraft Baron G-58 Composite ARF Intro (Part 1) Whats in the box (11 min 52 sec)
Old Jan 14, 2011, 11:37 PM
FlyBoyTha1's Avatar
Joined Sep 2008
More info can be found here on my blog
http://www.rcgroups.com/forums/showt...0#post17108192
Old Jan 15, 2011, 11:40 AM
Prowler901 is offline
Find More Posts by Prowler901
Prowler901's Avatar
USA, NY, Amsterdam
Joined Jun 2007
That's a sweet lookin' kit! I've always loved the Barons.
Todd
Prowler901 is offline Find More Posts by Prowler901
Old Jan 15, 2011, 11:35 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Todd
Yeah, i dig the twin Cessna's & Baron's myself
Old Jan 17, 2011, 08:59 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Hoping the second box with the wings in it will come in today.
In the meanwhile went to www.scaleflying.com to download and printout the manaul.
Old Jan 17, 2011, 09:29 AM
Prowler901's Avatar
USA, NY, Amsterdam
Joined Jun 2007
This plane has some awesome details. The parts really look spot on. What will you be using for a power system?
Todd
Old Jan 17, 2011, 09:53 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Todd
I'm thinking a pair of E-Flite Power .46's 4-5 cell, i have the Nitroplanes orange cessna 421c and they push it along really well on 25c packs, i have a new set of Hyperion 45c packs i'll be using for this setup
Old Jan 17, 2011, 02:45 PM
FlyBoyTha1's Avatar
Joined Sep 2008
The remainder of the shippment has come in . Wings, lights, props, cockpit etc.
More photo's.
Old Jan 17, 2011, 10:53 PM
800mZero is offline
Find More Posts by 800mZero
3DHS Junkie
800mZero's Avatar
Rhode Island
Joined Jun 2005
will be following this one!
800mZero is offline Find More Posts by 800mZero
Old Jan 18, 2011, 01:03 AM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
I have had mine for over a year now and really like it. You will enjoy yours.
sj3cub is offline Find More Posts by sj3cub
Old Jan 18, 2011, 01:24 AM
Kevin Morris is offline
Find More Posts by Kevin Morris
Kevin Morris's Avatar
USA, CA, San Anselmo
Joined May 2002
B-58g
I have kit 001 based on the stamp on the wing root and have completed the wing section. I am using E-flite 32's with 3 blade props and tru turn spinners. I have installed the MPI strobes and LED nav lights into the wing tips and attached the clear covers with tiny screws. I had to create my own motor mount extensions using thick aluminum tube stock which was a bit of work. This kit is a very true to scale kit with a few deviations. The ailerons, flaps and horizontal stabilizer to be more scale like should have dimples, versus the plastic stock attached to the top of the controls. But, all in all this is a magnificent scale kit and can't wait to complete it. For those who want additional scale details, there were a few publications that recently featured the 50th anniversary B58 baron. Flying Magazine October 2010 issue and Aopa Pilot December 2010.
Kevin Morris is offline Find More Posts by Kevin Morris
Old Jan 18, 2011, 04:55 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Nice guys
Old Jan 18, 2011, 12:28 PM
FlyBoyTha1's Avatar
Joined Sep 2008
In the Beechcraft Baron G58 Composite ARF Intro (Part 2) Box 2-3 Contents,
We have recieved the remainder of parts to start the dry fit test.
Next in video 3 we will start with exoping of some of the parts to make the dry fit test complete.
RC Aerodyne Beechcraft Baron G58 Composite ARF Intro (Part 2) Box 2-3 Contents (11 min 23 sec)
Discussion Beautiful New Beechcraft Baron G58 LNLP Scale ARF/RTF 7 Sep 09, 2010 02:44 PM
Discussion RC Aerodyne Baron 58 learnedinuk Scale ARF/RTF 6 Nov 16, 2009 11:28 AM
Discussion Baron G58 slonlow Scale Kit/Scratch Built 0 Nov 16, 2009 11:27 AM
Discussion RC Aerodyne Baron-58 Build Thread FLYBOY2000 Scale Kit/Scratch Built 1 Sep 26, 2009 05:39 PM
