Old Jan 14, 2011, 08:41 PM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
New Product
Techone Star 3D Epp Combo With T-2006 Outrunner
Went to pick up some small servos at the local shop. Couldnt pass this plane up for the price(they just got them today).. $59.95 and it comes with a t-2006 outrunner and a prop. The t-2006 ive flown before and it makes really good power in 6-7oz epp planes and the motor alone is $33.00 if purchased separately. Not sure if i'll get it assembled this weekend but i'll add some pics later.
Available online HERE.
Specifications:
* Weight: 6.5-8 oz. (180-220g)
* Wingspan: 31.5 in. (800mm)
* Length: 35 in. (890mm)
Included Accessories:
* Tiger Motor T2006 1900kv Brushless Outrunner Motor
* GWS EP-8040 203x102mm Direct Drive Propeller
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter Mini T Copter Fun
Old Jan 14, 2011, 09:07 PM
corsair214 is offline
Find More Posts by corsair214
corsair214's Avatar
United States, IN, Danville
Joined Mar 2007
techone
hi get real i am amassing a collection of techone planes have the spirit.sukhoi,extra,energy bipe witch haven't flown yet andthe piaget... the spirit flys great haven't tried it outside yet but i like em......
corsair214 is offline Find More Posts by corsair214
Old Jan 15, 2011, 09:52 AM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
Wow, that is a great deal with the T Motor.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Jan 17, 2011, 08:08 AM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Techone Star 3D Out Of The Package!
Looked through the manual and it looks like this should be a pretty rigid epp plane. It uses thicker carbon rods for the trussing then techone planes ive flown before and it also includes a aileron arm to to correct differential for the single aileron servo. Looks like it will be a fun little epp pattern plane that can 3d from the design. All the z-bends are pre done but you still have to cut a 45 degree bevel for the control surfaces. The nose looks very durable and uses four carbon strips to reinforce the motor mount area and are pre cut to length. All the carbon rods appear to be cut to length as well so it should go pretty quick when i have time to get it assembled. The wheel pants look nicer,they use thicker epp so they look fuller and should be pretty durable. Glued them up quick and the motor mount for later,using welders for the entire assembly,its a popular adhesive for many epp planes and ive been using it for about a month or so now and it works great on epp.. only downside is it takes a while to set up and you should let it set up over night to fully cure but its pretty rigid for bonding but can still flex a little during impacts without cracking like ca glues,i wont be using it for hinging though. The techone plastic hinges work very well and have basically zero resistance but they can be difficult to install using ca since it can seep into the hinge itself if you over do it on the glue.. the welders makes it easy to install the hinges though. Im gonna try and have it assembled before the weekend and get some flights in. Will probably maiden in the backyard but really want to get to the park or some where i can really open it up with the t-2006 and get it trimmed out and fly some long lines and big loops etc. Heres some pics for now.
Old Jan 17, 2011, 08:10 AM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
reserved
Old Jan 17, 2011, 08:14 AM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Ive flown the butterfly 3d,piaget,pulama bipe,rainbow,sprit,energy bipe,souka,flew the mini yak 54 once(was someones from the local shop),and now this plane i'll fly soon .
Old Jan 17, 2011, 07:14 PM
tigermoth is offline
Find More Posts by tigermoth
United States, TN, Loretto
Joined Feb 2001
Techone has really got it together. Absolutely first class.
tigermoth is offline Find More Posts by tigermoth
Old Jan 18, 2011, 04:34 AM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Got started on it tonight,weighed everything to get an idea of how much the welders adds to the completed auw for the airframe. Usually i use a half bottle or less of the 10g size regular ca for a plane this size. Will add the carbon and glue the top of the fuse on tomorrow or later in the week. Should have some flying in with it by the weekend hopefully.
Old Jan 18, 2011, 03:18 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
I was wondering when this plane was going to be available here. Maybe a replacement for my Piaget? Not that it's getting worn, but I'm in need of a change.
rmgmag is offline Find More Posts by rmgmag
Old Jan 20, 2011, 07:46 AM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Finished the airframe the other night and put the power system and servos in today. One step not to overlook is the wing spar crosses past where the top half of the fuselage slot and tab join.. need to trim for the spar to fully seat the top half of the fuse or you could trim the tab.. i sliced a slot in the tab(see pics). Auw with 2 futaba 3114's,7g servo for rudder,spektrum ar 6110e,t2006 outrunner,10 amp esc and 500mah 2s 20c pack is 7.1oz. With tp 325mah 2s 45c pack the auw is 6.8,with a hk2403 and the tp 325 pack it should be about 6.2-6.5oz rtf and i'll try that outrunner at some point as well in the plane. The carbon rod trussing is all 1.3mm about 30% thicker than other techone kits use so it adds a slight amount of weight to the build but makes the plane noticeably more rigid. Should be able to get the plane under 6oz with a lighter power set up and leaving the sfg's and wheel pants off etc but 6.5-7oz seems to be a good weight for around here with the wind. I'll probably fly it over the weekend if the weather is decent out here.
Old Jan 20, 2011, 03:43 PM
Joined Feb 2001
Looks great.
Old Jan 24, 2011, 09:51 PM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Video At The Shop
Got one short flight outside in windy conditions so far with it. Flew it a few times inside and someone at the local shop wanted to see how it turned out so i brought it with when i went to pick up some things. Fly's well but i think i'll mount the pack on the upper vertical fuse for easier pack changes and better balance. Looking forward to flying it outside in warmer temps and less wind eventually,happy with it and its a bargain for the price including a nice outrunner and prop.
Techone Star 3D A Quick Flight At The Local Shop (1 min 53 sec)
Old Jan 25, 2011, 03:53 AM
Meez is offline
Find More Posts by Meez
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
GR,
Nice plane. Now how i'm going to get a good sleep tonight after watch that video.................
Meez is offline Find More Posts by Meez
Old Jan 27, 2011, 09:59 AM
adamtc is offline
Find More Posts by adamtc
adamtc's Avatar
Southampton ,England
Joined Oct 2006
Ive just bought this kit in the UK.
Out of interest, which way round did you fit the aileron servo arm? Logic tells me the arm should have the extension arms pointing away from the ailerons not towards them.
Equal movement of ailerons.
Can you help?
adamtc is offline Find More Posts by adamtc
Old Jan 27, 2011, 11:32 AM
wishawhunk is offline
Find More Posts by wishawhunk
scotland uk
Joined Jan 2005
Im placing an order at the weekend
uk also
wishawhunk is offline Find More Posts by wishawhunk
Discussion Techone Rainbow 3D EPP Get Real 3D Foamies 68 Feb 18, 2012 08:22 PM
Sold Techone Gent EPP 3D Foamy The Don Aircraft - Electric - Airplanes (FS/W) 4 Oct 11, 2010 05:18 PM
Discussion EPP 3D need suggestion for alternative to Techone Piaget xraydoc Indoor Pattern/F3P 4 Sep 28, 2009 01:08 PM
Discussion Discussion - EPP 3D need suggestion for alternative to Techone Piaget xraydoc 3D Foamies 6 Sep 15, 2009 06:38 PM
