This thread is privately moderated by Jay Burkart, who may elect to delete unwanted replies.
Old Jan 13, 2011, 09:36 PM
Jay Burkart is offline
Find More Posts by Jay Burkart
SAM Elec GrdChmp04,07,10,12,14
Jay Burkart's Avatar
Smithfield, Ky.
Joined Sep 2001
Wing midsection prep for bisection
A bit more progress on the Wings.
The center or midsection of the wing has to be prepared to cut it into two right in the middle
to make two sections that will plug together.
So the wing has to be esentially covering ready through the entire middle section and then
it is cut into two halves on a radial arm saw.
This will mean cutting all of the structure including the joiner tubes.
Also in the middle section the TE is prepped for where the mounting bolts are installed
very near the TE a little bit off the center line.
Also you see the locating holes at the LE for the CF pins.
These go into the ply reinforced ribs on eithes side of the center.
I hope to be cutting the wings in two in a couple of days.
Then the tips will be joined onto their respective half of middlesection.
Doing the joined wing this way allows for quicker build and also the two
sections will exactly mate as they were built as one and then cut down the middle so both sides will match.
Jay Burkart is offline Find More Posts by Jay Burkart
Old Jan 13, 2011, 10:38 PM
kirk0703 is offline
Find More Posts by kirk0703
United States, MS, Hattiesburg
Joined Jan 2011
i need help
i got a blog that has a crap load of questions..one i got for u is what kind of plastic can you use to make the model..and how can you get your design off of paper into a mold???
kirk0703 is offline Find More Posts by kirk0703
Old Jan 14, 2011, 07:47 AM
Smithfield, Ky.
Joined Sep 2001
I am sorry but I do not understand your question.
This is an Old Timer model and it is made entirely from Balsa and Spruce.
There is no plastic or molding process to it.
I do not know of any way to do structural building with plastics
nor do I know if there is any source.
Sorry to not be able to answer with any help there.
Jay
Question How do you prep a molded wing for horn? hbielich High Performance 2 Aug 20, 2004 12:33 AM
