Old Jan 12, 2011, 07:22 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
New Product
Nine Eagles Ultra Micro Spitfire, P-47 Thunderbolt and P-51 Mustang
Seems like Nine Eagles is coming with more WWII planes, besides the P-47 Thunderbolt...
Some details:
Spitfire
Model No: NE R/C 780B
Wing span: 400mm
Overall Length: 355mm
Flying weight: 33-34g
Power System: ∮8 Motor
Battery: 3.7V 150mAh Li-PO
P-51 Mustang
Model No: NE R/C 779B
Wing span: 400mm
Overall Length: 365mm
P-47 Thunderbolt
Model No.:
TX:NE-024G
RX:NE R/C 778B
Wingspan:400mm
Overall Length:355mm
Flying Weight:36-38g
Motor::∮8Motor
Battery:3.7V, 150mAh Li-PO
Btw, the Mustang and Spitfire are listed as 3 channel planes, the P-47 as 4 channel. The receivers are identical though, the extra aileron servo of the P-47 can be plugged into the receiver of the Spitfire and Mustang as well. So with a little modding, these might be converted to 4 channel as well.
SoloProFan is offline Find More Posts by SoloProFan
Old Jan 13, 2011, 01:10 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
sweet
any vids you've come across?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jan 13, 2011, 01:15 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
there is also a P-51 as well as battle coax helis much like Eflite has done
and i see a programmable TX
they've been busy
Old Jan 13, 2011, 01:59 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by Razors edge 29 View Post
sweet
Not yet, there is only one vid on Youtube of the P-47, I think that is what you meant with the P-51 you mentioned?
Btw, I remember you once said that your post count was not right, when someone asked you why you had so many postings in such a short time, recall that? Perhaps the count is right if you don't edit a post but make a new one just after your previous one within 5 minutes apart. That way post count will go skyhigh rapidly...
Old Jan 13, 2011, 02:03 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Look on the website again big mouth
There is a P51 as well.
Old Jan 13, 2011, 02:05 AM
Ultra_Spitfire is offline
Find More Posts by Ultra_Spitfire
Super Man's cousin! No cape!
Ultra_Spitfire's Avatar
Australia, New South Wales, Wangi Wangi
Joined Sep 2010
Ultra Spitfire now has a new spitfire coming! I am so gonna order one, because, I LOVE spitfire's!
Ultra_Spitfire is offline Find More Posts by Ultra_Spitfire
Old Jan 13, 2011, 02:31 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I miss the smilie after mouth, or are you really mad at me?
Missed the P-51, they only listed the Spitfire, P47, battle helis, new TX and the Bravo SX in the banner, which is supposed to advertise for new releases. I guess they don't want publicity for the Mustang then?
After all, a P-51 is not a very popular plane, right?
Well, it's nice to see them so busy, 3 new sweet looking planes, and a new TX. Let's hope it's all compatible with each other, and not like with the helis, that have the same TX, and yet you can't control the planes with it, and same with the plane TX, you can't control the helis with those...
Old Jan 13, 2011, 03:23 AM
Joined Sep 2010
There is also a Yak 54, which it looks like I am going to get all of them, depending on money. I wonder how they will handle outside.
Old Jan 13, 2011, 03:35 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Here's a vid of the P-47:
Nine Eagles P-47 (3 min 23 sec)
And here's the Yak:
yak-55 Nine Eagles New product ! (3 min 50 sec)
Old Jan 17, 2011, 01:33 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Decided to make this a general topic for all Nine Eagles warbirds instead. Perhaps if the individual planes become more available and popular they might need a seperate topic, but for now, this seemed more appropiate.
Old Jan 17, 2011, 01:52 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Any more pictures of ultra micros?
Cheese5 is offline Find More Posts by Cheese5
Old Jan 17, 2011, 04:19 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Certainly.
Old Jan 18, 2011, 02:37 AM
jimjim06 is offline
Find More Posts by jimjim06
jimjim06's Avatar
Sweden, Västra Götaland, Partille
Joined May 2009
There is a similar thread running in "indoor and micro models"
You might find additional info there: http://www.rcgroups.com/forums/showthread.php?t=1337478
Here is a slightly better Video of the Yak 54
ハイテックYAK上空飛行 (2 min 41 sec)
Oh, it also seems there is a new NE Tx coming out soon, see this thread from Micro helis http://www.rcgroups.com/forums/showthread.php?t=1370319
Tommy
jimjim06 is offline Find More Posts by jimjim06
Old Jan 18, 2011, 12:05 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
http://www.youtube.com/watch?v=KkEd8...layer_embedded
Tommy
That's the charm of such a large forum, where some products fall into multiple classifications. The Hobbyzone Champ could also be considered an indoor micro, but is also "micro RTF", just like these planes. And there are even multiple threads for the same heli in the micro heli forum.
Nice vid of the YAK, seems like it has plenty vertical pull power, which can be expected with the motor it uses. Roll rate seems also quite adequate. Wonder if the vid was cut off a few seconds before impact, though...
Old Jan 18, 2011, 12:47 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The picture shows the Spitfire with ailerons.
I wonder how they are going to switch rudder/ailerons channels in the brick or TX?
The P-47 uses a separate aileron servo, but the Spitfire Ailerons would be in the brick, if its a 3 Channel.
Edit: It looks like the Spitfire Ailerons were airbrushed out of the ad as the actual model doesn't appear to have ailerons. The problem of channel switching still remains.
Its why HH has a separate 3 channel brick and a 4+ channel brick.
UNGN is offline Find More Posts by UNGN
Help! Ultra Micro Spitfire (Yes, the troublesome E-RC) Ultra_Spitfire Micro Ready-to-Fly 0 Oct 01, 2010 07:13 AM
For Sale (6) Nine Eagles Micro Heli 2.4GHz jonesjj Aircraft - Electric - Helis (FS/W) 3 May 18, 2009 11:04 AM
Discussion Nine Eagles Micro Helis are 2009 Toledo hit Jim Deck Coaxial Helicopters 8 May 13, 2009 02:51 AM
New Product Nine Eagles Micro Heli SGTalon Coaxial Helicopters 6 May 12, 2009 06:58 PM
Sold Nine Eagles Kestrel 500SX $115 Cash or trade for Blade mCX micro heli Rat57z Aircraft - Electric - Helis (FS/W) 6 Oct 04, 2008 02:33 PM
