Old Jan 12, 2011, 12:53 AM
cannondale1974 is offline
Find More Posts by cannondale1974
cannondale1974's Avatar
Lexington, KY
Joined Oct 2009
Will a Spektrum (air) receiver work on (surface) radios?
For instance, I have a few AR6100 park flyer receivers. Will they bind up with say a Spektrum DX3S car radio?
Thanks!
cannondale1974 is offline Find More Posts by cannondale1974
Old Jan 12, 2011, 09:00 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
No. Surface receivers (SRxxxx) only work with Surface transmitters.
Marine receivers (MRxxxx) work with Marine-compatible surface transmitters (they'll have a boat logo on them), plus they'll work with aircraft transmitters.
Aircraft receivers (ARxxxx) work only with air transmitters.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jan 12, 2011, 09:12 AM
Gregg28 is offline
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Andy
Why?
Gregg28 is offline Find More Posts by Gregg28
Old Jan 12, 2011, 09:25 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Because HH wants you to buy more stuff and it works. Its not just them but other and not just in the hobby.
freechip is offline Find More Posts by freechip
Old Jan 12, 2011, 09:50 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by Gregg28 View Post
Why?
At the lowest level, the communication is done differently for each.
Surface radios need to be able to have a super-low response time - we have surface radios with a 5.5ms refresh rate. The communication was optimized to be able to do that.
The aircraft radios need to be able to support up to 12 channels (JR 12X). You can't have high-channel-count and low-refresh-rate both, so they are optimized appropriately.
Marine is different still. It needs the diversity of the aircraft radios but not a high channel count.
Andy
Site Sponsor
Old Jan 12, 2011, 10:30 AM
Gregg28 is offline
Gregg28's Avatar
Joined Jun 2005
Andy
Makes sense, Thanks.
But there is no real or legal issue with using a Dx6i on a boat, correct?
Old Jan 12, 2011, 01:07 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Correct, that was only with 72/75MHz.
Andy
Site Sponsor
Old Jan 22, 2011, 04:10 PM
Gregg28 is offline
Gregg28's Avatar
Joined Jun 2005
I know that this is off topic, but another Spektrum question:
I have an old Ace radio. I would like to convert it to 2.4mHz. Can I use any Spektrum module and plug it into the Ace encoder board? Is the difference between modules mostly just the plug and case or are there other differences? Probably need a Hitec/Futaba for the correct shift, I am guessing.
Old Jan 22, 2011, 08:13 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
You probably can adapt a module to the Ace encoder, but it's not as simple as plugging it in. First, it depends what Ace radio. Second, you have to find the PPM signal and make sure it has suitable level. You may also need to determine the polarity (shift has nothing to do with this, as it's an FM concept). You also need to determine whether you should use a JR-type of Futaba-type Spektrum module. And, of course, you'll have to do some soldering and adapting. So you need to know what you are doing.
You need to get exact information about your transmitter and ask a specific question. You should start a new thread when you have an unrelated topic like this and give it a clear title that will attract people who might know. Something like "How to adapt an Ace XXXX to Spektrum 2.4?"
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 23, 2011, 04:04 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
The DIY Electronics forum is definitely a better place to ask. There are several who have done similar conversions there.
Andy
Site Sponsor
Sold DSM 3-Ch Pro Series Surface Module/Rx: AIR M8/M11 by Spektrum <Price drop> Treeline Cars - Accessories (FS/W) 4 Nov 18, 2010 08:02 AM
Discussion Will a 5 ch receiver work with a 6ch transmitter? hellsrage619 Radios 3 Nov 06, 2010 08:22 AM
Discussion first 2.4 non spektrum....will this work with spektrum rstein9 Electric Plane Talk 1 Oct 18, 2010 04:08 PM
Question Spektrum air module work in Futaba surface TX? village_idiot Radios 10 Apr 28, 2009 09:20 PM
Will a JR/Air Z hitec receiver work with hitec flash receiver? taekwondo Radios 8 Aug 08, 2005 04:15 AM
