Old May 18, 2011, 07:19 PM
joey1117 is offline
Find More Posts by joey1117
joey1117
Dayton Intl, Ohio, United States
Joined Sep 2004
Rendy
I just bought a "back up" 9z to try this back light on can wait for it to get here just did not want to risk my " flying" radio until i see if i can get the backing off the screen , thanks for the work you are doing on this . do you happen to have anymore of the el panel before i order it ? also where do you mount the inverter inside the radio
thanks
joe
joey1117 is offline Find More Posts by joey1117
Old May 18, 2011, 10:40 PM
Rendy is offline
Find More Posts by Rendy
Rendy's Avatar
Santa Clara, California
Joined Aug 2004
Joe,
I do have the EL panel, but it is not big enough for 9z. I bought an EL panel on *Bay with 4 connection points. It is big enough to make one 9z and two MPX Evo.
I place the inverter at lower left corner when viewing from the rear. No special reason why I did that. I guess you could also place it on the lower right corner. Just remember, the EL panel's wires come out from the left side.
When I modified my Multiplex Evo, I don't have to add the capacitor at all. I don't know why 9z is so sensitive.
rendy
Originally Posted by joey1117 View Post
Rendy
thanks
joe
Rendy is offline Find More Posts by Rendy
Old May 22, 2011, 01:08 PM
joey1117 is offline
joey1117
Joined Sep 2004
ok i started this project , getting this apart is no 5 minute job but not that bad , the screen film comes off pretty easy DO NOT use a razor blade to remove the glue you will scratch the polarized film i started to use one but seen what was going to happen and stopped . just waiting on the el sheet to show up here are some pics
Old May 22, 2011, 02:38 PM
Rendy is offline
Rendy's Avatar
Joined Aug 2004
Hi Joey1117
Once you installed the EL panel and re-installed the LCD metal frame, be sure to test the LCD before you close up TX. Make sure you don't have any missing vertical/horizontal line. If you found one, just add more pressure on the connection. This takes more of my time.
rendy
Old Jun 12, 2011, 09:25 AM
joey1117 is offline
joey1117
Joined Sep 2004
WOW this was a project
ok so after countless drivers and MANY MANY times trying to get this to work here it is please note this is not for those that don't have alot of time to work on this radio you have to take alot of it apart , so I ended up using this driver from Smartieparts.com http://www.smartieparts.com/shop/ind...roducts_id=333
(thanks Steven worked great) the prblem with the driver is it works at a max voltage of 5 volts so how to get 5 volts from the tx pack? easy I took an olfd esc and used the rx side to supply the 5 volts and the part you would plug into you flight battery i hooked up to a switch and went right to my tx 9.6 volt battery this way i can turn the backlight on and off when i want to . it was not a bad job but use this driver I have over 100.00 dollars in drivers trying to find one that will fit in the space and work with the size of panel the 9z takes plaes see the pics for how this all went I have many many hours in this and I hope this will make the next guy's job go smooth , I believe the 9z is now an "up to date " radio it is 2.4 ghz's and with a backlight these were the only things missing from the radio if you have any questions let me know I will try to help
joe
Old Jun 12, 2011, 09:26 AM
joey1117 is offline
joey1117
Joined Sep 2004
more pics
Old Jun 13, 2011, 03:59 AM
cobuser is offline
Find More Posts by cobuser
Germany
Joined May 2005
Hi,
this thread calls my attention because Backlight is all I am missing on my 9z. I wonder if I can use this parts from Hobby King:
China Backlight There is a driver attached to the panel......... but I'm afraid that the panel is to small.
Thomas
cobuser is offline Find More Posts by cobuser
Old Aug 18, 2011, 03:03 PM
Nazdreg is offline
Find More Posts by Nazdreg
Nazdreg's Avatar
Oceanside, CA
Joined Jul 2005
Originally Posted by cobuser View Post
Hi,
Thomas
Did you find out if the panel fits the 9z ? I have one also and I'm itching to install some kind of backlight.
How thick is the LCD display in the 9z, would it be possible to mount small SMD LEDs around the edge of the display ?
Nazdreg is offline Find More Posts by Nazdreg
Old Aug 18, 2011, 03:30 PM
joey1117 is offline
joey1117
Joined Sep 2004
i did try leds and they did not work very well kind of put a shine on the lcd and made it hard to read , the el panel you need is an a-4 and you cut it to fit let me know if you need any more help not a hard job just takes time
Old Aug 18, 2011, 05:32 PM
Nazdreg is offline
Nazdreg's Avatar
Oceanside, CA
Joined Jul 2005
OK I'll scrap the LED thought and go with a panel instead.
I have never seen such a panel, but it sounds like it's thin and can be cut to size, which is great since a large panel could yield enough material to do the 3 radios I have.
Does one panel only have one connector ?
If I cut one panel into three pieces, how do I connect the two other pieces to the 120V drivers ?
Old Aug 18, 2011, 08:11 PM
joey1117 is offline
joey1117
Joined Sep 2004
the panel has i think 6 places you can tap power to here is were i got mine but only one radio per sheet when you cut it but you have extra for small projects...DONT get there driver they will not fit inside the case and dont work well
joe
Old Dec 24, 2012, 09:40 PM
rosnik is offline
Find More Posts by rosnik
1000MIGLIA City - Italy
rosnik's Avatar
Joined Mar 2012
Hi guys,
Are there no news for a safer LED solution ?
rosnik is offline Find More Posts by rosnik
Old Dec 30, 2012, 07:29 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Why not use 9x radio panel ?
renatoa is offline Find More Posts by renatoa
Old Dec 31, 2012, 06:51 AM
rosnik is offline
rosnik's Avatar
Joined Mar 2012
I'm not sure it got some measueres to fit 9Z.
Old Jan 15, 2013, 09:54 AM
satgod is offline
Find More Posts by satgod
satgod's Avatar
United States, KY, Hardin
Joined Jun 2011
the 9x panel is to small
I just ordered a panel for my 9z last night
looks like this year old thread is getting brought back to life for a short time
http://www.ebay.com/itm/330699646929...84.m1439.l2649
almost a perfect fit to the 9z, Very little trimming needed at all
satgod is offline Find More Posts by satgod
Wanted futaba 9z joey1117 Aircraft - General - Radio Equipment (FS/W) 5 Mar 05, 2011 07:10 PM
Question Futaba 9z burned with 3s LiPol, posible fix? Rafit Radios 21 Feb 16, 2011 07:50 PM
Wanted Futaba 9Z WC2 Transmitter Remo180 Aircraft - General - Radio Equipment (FS/W) 3 Dec 21, 2010 12:08 PM
Found Futaba 9C or 9Z Tx techspy Aircraft - General - Radio Equipment (FS/W) 1 Oct 26, 2010 09:18 PM
Discussion Futaba 9Z WCII - Help 9Z owners - LCD Screen chutt Radios 3 Aug 05, 2007 09:18 PM
