Old May 15, 2011, 03:10 AM
horejsi is offline
Find More Posts by horejsi
Czech Republic, Plzen
Joined May 2005
See please
http://www.horejsi.cz/Images/1551.jpg
... and sorry for the delay
Ivan
horejsi is offline Find More Posts by horejsi
Old May 15, 2011, 08:34 AM
RCMcP is offline
Find More Posts by RCMcP
Bob McPeters
Federal Way, WA
Joined Feb 2008
Q-11
Ivan,
Since the conventional tail version did not include an updated instruction sheet I was wondering if the CG point is the same for the V-Tail and Conventional Tail?
Bob
RCMcP is offline Find More Posts by RCMcP
Old May 15, 2011, 08:53 AM
horejsi is offline
Joined May 2005
Cg
Bob,
The CG position was set up in process. The last recommended initial position is ca 70 mm behind the LE, for both versions. Anyway, make diving tests atc. to setup it to your requirements.
The new instructions are now on the web, same for both versions. The building images are now on the web only.
Ivan
Old May 15, 2011, 10:04 AM
RCMcP is offline
Bob McPeters
Federal Way, WA
Joined Feb 2008
Q-11
Double Post. Sorry
Old May 16, 2011, 05:35 PM
Ed Franz is offline
Find More Posts by Ed Franz
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
Originally Posted by horejsi View Post
Bob,
Ivan
So, is the only way to get one is to go direct? This would make a very nice plane for the US 28mm class.
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old May 17, 2011, 07:03 AM
horejsi is offline
Joined May 2005
28 class
Could you send link showing the 28 class rules pls?
Old May 17, 2011, 04:24 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
I think these are meant:
Out Runner Class
Motors are restricted to out runner type without gearboxes. The maximum size of the flux ring is
28 mm in diameter and 16 mm in length. There are no restrictions on airframe size or planform.
Batteries are restricted to 7 Nicd / Nimh or 2 lithium polymer cells.
http://www.soarabq.org/pdfs/f5j_rules.pdf
there's these as well:
X5J eXtreme SOR rules:
1. Any airframe, battery, ESC, prop, motor with 28mm diameter and 17mm
magnet bell length or less.
2. Flight time has motor run time subtracted from it.
3. 30 point landing tape, in 1 meter increments worth 3 pts/m.
WimH is offline Find More Posts by WimH
Old May 17, 2011, 07:39 PM
RCMcP is offline
Bob McPeters
Federal Way, WA
Joined Feb 2008
Q-11
Ed, Just got some final weights on my build.
With a Hacker A20-20L and a 3C 1350 mah pack, AUW is 19.5 oz.
With a smaller Hacker (A20-26) and a 2C Pack you could be under 18 oz.
Bob
Old May 17, 2011, 07:43 PM
Ed Franz is offline
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
Here is what we fly in the US as 28mm class:
Ed
Old May 18, 2011, 02:08 AM
horejsi is offline
Joined May 2005
Rules
Thanks.
The rules of the Eurocup are here:
http://f5j.eu/w/index.php?title=Euro...ner&oldid=2852
Very similar. It is minimum weight limit (maybe redundant) and minimum prop dia 10". It is to prevent from using hi-revs heli motors. Again, I am not sure if it is necessary.
But it works fine.
Old May 18, 2011, 03:24 PM
WimH is offline
WimH's Avatar
Joined Dec 2001
See please
Ivan
more here..:
http://www.flymodelcomponents.it/sho...8&cat=0&page=1
Old May 27, 2011, 04:30 PM
jofo1 is offline
Find More Posts by jofo1
jofo1's Avatar
United States, CA, San Jose
Joined Nov 2003
I've read a few posts concerned that this plane will not penetrate well. If it flies like any of my AG foiled DLG's, there is no reason why it wont penetrate well when trimmed and flown correctly. I almost never balast my DLGs and I usually fly in wind of 10mph plus and have no issues penetrating or coming home. This model should respond well to camber changes. I just recieved mine in the mail. Going to top drive the flaps and ailerons to clean up the bottom of the wing, and almost 300W of power input. I'll post pics when shes done if anyone is interested.
jofo1 is offline Find More Posts by jofo1
Old Jun 09, 2011, 07:16 PM
jofo1 is offline
jofo1's Avatar
Joined Nov 2003
I decided to top drive mine...photos here.
http://www.rcgroups.com/forums/showthread.php?t=1453176
Old Jan 12, 2012, 01:04 PM
Luis Moya is offline
Find More Posts by Luis Moya
Luis Moya's Avatar
Mexico
Joined May 2004
Flying Report?
I wonder if after 6 - 7 months from the last post (busy building), if there is a flying report on this glider.
It would be good to know about flying performance and how underlying light components, specially wing and tail, are holding out.
All the best,
Luis
Luis Moya is offline Find More Posts by Luis Moya
Old Feb 26, 2012, 04:11 AM
Alex VK2KR is offline
Find More Posts by Alex VK2KR
Albion Park Rail Aus
Joined Nov 2009
Flying Report
Hi
I finally had the opportunity to fly the Q11 in our 2nd F5J contest today.
Conditions overcast, 22C with drizzling rain on and off through the contest
consequently little lift. Rate of sink in the glide was 0.55m/s, with 200m
climb in the 30 seconds allowing 365 seconds of air time. With a little
very light thermal? activity I was able to in a couple of rounds to make the 10 minute mark.
Never exceeded more than 10 meters height gain due to this lift, more
of a neutral glide maintaining height.
Climb rate with the Turnigy KA20-20L (1050Kv) outrunner was 6.7m/s
with a current draw of 11 amps from the 3S 800mah lipo pack
on a 9.5x6 prop. It outclimbed a new 3.7m AVA with a Nue 1112 geared
inrunner and more than matched it in glide ratio.
Despite what appears to be a frail model,I am very pleased with this aircraft and its performance,
and its ability to be able to penetrate into the wind,
Radians were hovering, this was penetrating at will.
My first experience with flaps, I used the trim for 3mm camber for maximum
float after the climb, and did not have to use reflex at this time.
50% flap had it coming down at a steady rate, and full flap allowed me
to dive vertically and flare at the last second for close to spot landings.
IT IS A GREAT MODEL
regards
Alex
Alex VK2KR is offline Find More Posts by Alex VK2KR
Discussion Art Hobby's Zuni-V 1.2M Build Thread edubs2121 Sailplane Talk 47 Apr 06, 2011 11:28 AM
Help! Horejsi Q11, Anybody heard of it before? AndrewBurns Electric Sailplanes 8 Jan 05, 2011 08:43 PM
Build Log DJ Aerotech Chrysalis 2M MkII Build Thread 2008 FrogChief Thermal 141 Aug 24, 2009 06:04 PM
Zuni 1.2M build thread. Botterii Slope 35 Apr 01, 2004 03:37 PM
