This thread is privately moderated by pttse, who may elect to delete unwanted replies.
Old Jan 19, 2011, 12:39 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
I like the super duo, but would like to be able to ocasionally use ac.... I have a 30a 12v supply now, but this would be a waste on the sduo. Looking instead at buying two 0720i ad net3 , but what I cannot find anywhere is if you can discharge 8s packs with the two units networked.... anyone know?
la528it is offline Find More Posts by la528it
Old Jan 19, 2011, 12:59 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
I don't get your logic? You have the 12V/30A,360W PS already which isn't enough to run even a single 720i (7S, 250W) charger at full power. So why would having 2 x 720i be better for your needs than an SDUO?
kgfly is offline Find More Posts by kgfly
Old Jan 19, 2011, 09:17 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
The hyperion "ad" units have a built in ac power supply, so I would not need an external source
Old Jan 19, 2011, 09:25 AM
kgfly is offline
Joined May 2006
Ah, I see. They are only 90W when using the internal AC supply and 150W when using a DC supply. If that is enough power for you then that would make sense. For my needs nothing under 250W is any use
Old May 26, 2011, 01:06 AM
pavlo80 is offline
Find More Posts by pavlo80
Joined May 2011
Hi, when I fly I can use only 12V car battery (13V max when is full charge, or 14V when motor is on). What power I can give? How do I know?
I found the answer:
You will get approximately 300W power at 13.8V
This from blog from hyperion site.
pavlo80 is offline Find More Posts by pavlo80
Old Jul 19, 2011, 11:57 AM
Eddy is offline
Find More Posts by Eddy
Malibu Ca
Joined Feb 2000
So will the balance plugs on thunder power batteries work with this charger?
Eddy is offline Find More Posts by Eddy
Old Jul 19, 2011, 12:03 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Yes this will work with TP balance leade; if you use the TP balance boards
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Jul 19, 2011, 12:08 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
so it comes with those boards?
Old Jul 19, 2011, 01:25 PM
USA, GA, Atlanta
Joined Nov 2008
no, it comes with hyperion and jst boards; but you can buy the TP boards for about $5...
Old Jul 19, 2011, 03:08 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
great, thanks
Old Jul 19, 2011, 03:13 PM
USA, GA, Atlanta
Joined Nov 2008
No problem; this is a great charger.
Mine can balance charge the nanotech 2200 3s batteries from hobbyking in about 8mins
Old Jul 19, 2011, 03:15 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
wow, that really makes electric worth while
Old Jul 19, 2011, 03:46 PM
USA, GA, Atlanta
Joined Nov 2008
For me, it simply means that so long as I am flying near my car or another available power source, I can get away with 2 batteries and fly nonstop all day long, as it takes me 8-12 mins to discharge a battery depending on throttle management. Gone are the days where I have to invest in 6-8 batteries per plane; now I just have two batteries for each plane...
also i will note, I have been flying those nano batteries hard and charging at rates of 6-10c. So far, I have hundreds of cycles with no loss of efficiency and the batteries are just as powerful as the day I got them.
Old Jul 19, 2011, 03:57 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
Gezz I just looked at my 4400 tp they can charge at 12 c, yup, gone are the days of having many packs, I guess I am still limited by the charger but how fast do you really need to charge
Old Jul 19, 2011, 07:24 PM
USA, GA, Atlanta
Joined Nov 2008
Originally Posted by Eddy View Post
... but how fast do you really need to charge
Glad you asked!
With my flying style, if I bring only parkflyers to the field that all fly 3s 2200mAh batteries; I fly ALL DAY with 2 batteries.
While my batteries are capable of 8c and 10c charge rates, I usually charge them at 5c or 11amps. This gives me a totally balanced charge pack from approx. 30% full to 100% full in 12-14mins. I usually chat for about 5 mins between flights and it seems I always have a battery ready. Best part is, these nano-tech tunigeys only cost me about $20-$25 per battery.
Two batteries charging at 5c is pleanty for me
Discussion New TP-820CD better then the Hyperion Super Duo!!! MichaelT1960 Batteries and Chargers 83 Mar 11, 2011 09:37 PM
Discussion Hyperion Duo-3 cooling fan problem keithy4129 Batteries and Chargers 13 Jan 31, 2011 09:04 AM
For Sale New 300watt per port Hyperion DUO 3 plus purehobby Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 09, 2010 10:07 AM
For Sale Hyperion DUO 3 Brand New $199.99 purehobby Aircraft - Electric - Batteries & Chargers (FS/W) 4 Sep 04, 2010 02:02 PM
Discussion New Hyperion Super Duo vs TP-820CD MichaelT1960 Batteries and Chargers 0 May 17, 2010 04:37 PM
