Old Mar 05, 2011, 04:09 PM
ForceFedDSM is offline
Find More Posts by ForceFedDSM
ForceFedDSM's Avatar
Massachusetts
Joined Jun 2008
Wow, they went fast!
ForceFedDSM is offline Find More Posts by ForceFedDSM
Old Mar 05, 2011, 04:20 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Yea, I should have ordered parts to build 20, but I'm a conservative and don't know how long interest will be around or how long we will still be able to purchase power supplies.
The next product I'm working on building is an aluminum wheel ski. They are very nice because they are 6061t6 cut on a cnc laser, then assembled using aircraft rivets.
I think they will sell well too as lots of people don't know if the field is going to be grass or snow in much of the country this time of year.
I have ideas for other RC products that nobody currently sells, just need to make sure I don't bury myself in work.
schu
akschu is offline Find More Posts by akschu
Old Mar 09, 2011, 10:43 PM
Newman12 is online now
Find More Posts by Newman12
USA, MN, Blaine
Joined Feb 2011
I will subscribe to the thread but I am interested in the full kit if you do make another set.
Newman12 is online now Find More Posts by Newman12
Old Mar 13, 2011, 01:56 AM
MJB9 is offline
Find More Posts by MJB9
ARMY ATC (93C)
MJB9's Avatar
United States, TX, Keller
Joined Jan 2005
Originally Posted by akschu View Post
Ok, I added 10 more to stock since the parts are in route. I think that is the easiest way to deal with this since I should have everything beginning of next week.
3 have already sold, so there are 7 left. Place your order now for delivery for late next week.
If there continues to be more demand I will put together 10 more.
schu
I have FeatherMerchant's 42A supplies, will your full kit work for that? or just the 47A version?
MJB9 is offline Find More Posts by MJB9
Old Mar 13, 2011, 03:51 AM
z3scot is offline
Find More Posts by z3scot
Joined Mar 2011
I am also interested in the short kit
z3scot is offline Find More Posts by z3scot
Old Mar 13, 2011, 05:24 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Only the 47A power supplies work.
Old Mar 16, 2011, 12:16 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Everybody that ordered from the US should have their kits now. Let me know if you have any questions.
schu
Old Mar 16, 2011, 04:47 PM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
Wheee!
Got mine up and running! Thanks again Schu!
Cheers,
Steve
steve1814 is offline Find More Posts by steve1814
Old Mar 16, 2011, 05:06 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I bet you are pretty fast at installing those things now
Old Mar 16, 2011, 05:22 PM
steve1814's Avatar
Joined Mar 2007
Yeah, I did both sets in under 20 minutes. I did cheat though - I prepped the power supplies just after I ordered the second set .
I did drift from the instructions a bit on these - instead of using the nylon nut & washer, I dremeled the copper runs off both sides of the circuit board. I was still reading a short on the neg to chassis on the first one I was doing when using just the nylon parts - I thought there was some solder down in the mounting hole causing the short and got carried away when I picked up the dremel to get rid of the suspect solder burr. Seemed like a good idea after I was done so did the other as well.....
Now I need to sell my unused IBM 235 PS's I have laying around.
Cheers,
Steve
Old Mar 16, 2011, 10:05 PM
MJB9 is offline
ARMY ATC (93C)
MJB9's Avatar
Joined Jan 2005
Cheers,
Steve
Wanna sell one?
Old Mar 16, 2011, 11:55 PM
Jody hodgson is offline
Find More Posts by Jody hodgson
Joined May 2009
Hanging out for mine and look forward to your other inventions :-)
Jody hodgson is offline Find More Posts by Jody hodgson
Old Mar 17, 2011, 01:21 PM
Aralan is offline
Find More Posts by Aralan
Joined Sep 2010
Would be great to see another run of these, I think as more people see this, you'll see more and more potential customers. I think this makes one of the most end user friendly high output power supplies available for hobby use at anywhere near this price. Iota and Meanwell certainly have good products, but I don't think they're quite as end user friendly.
I think the only commercially available supply in this power range I've seen that's really set up nicely for use by an end user is the new ProTek 1000W supply.
Aralan is offline Find More Posts by Aralan
Old Mar 18, 2011, 03:51 PM
Massachusetts
Joined Jun 2008
I also added (2) 1/4 watt 100ohm resistors between the fan and the psu so that the fan turns at a lower speed and isn't so noisy.
schu
Hi schu,
Did you put 2 on each fan, or one on each?
Old Mar 18, 2011, 04:46 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
You need 1/2 watt and 50 ohms. I only had 1/4 watt resistors on hand so I used two on each in parallel. You could use a single 1/2 watt 50 as well.
schu
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 187 Jun 26, 2016 06:34 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 14 Apr 24, 2016 02:37 PM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
