Old Mar 01, 2011, 09:19 AM
GReedTFD is offline
Find More Posts by GReedTFD
United States, OK, Tulsa
Joined Sep 2008
X2 for me
GReedTFD is offline Find More Posts by GReedTFD
Old Mar 01, 2011, 12:09 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Steve,
That would be the correct way to wire it, but keep in mind that the power supplies are switching, and because they where not designed to run in series the oscillators are not sync'd up so the peak to peak voltage is effectively doubled. When you add a charger that has it's own switching dc to dc converter it's going to apply the load at it's own oscillator's frequency which given the sliding window affect can cause the power supply to overrun or underrun. When you add a second power supply set and charger you are doubling the oscillators in the system.
Running two in series for a single charger is not perfectly ideal, but has been shown to work very well in the real world because these power supplies are pretty hardy and because the chargers are not at all picky about perfectly clean DC because they have their own switching regulators to filter the output before applying a voltage on the battery.
When you start going down the road to four power supplies and two chargers you will without a doubt have really dirty DC, but that doesn't mean it won't work just fine. Only time and experimentation will tell.
Personally I wouldn't wire them like you have shown, I would dedicate one power supply to each charger.
schu
akschu is offline Find More Posts by akschu
Old Mar 01, 2011, 12:27 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Could this perhaps be an example of out of syn oscillators.
http://www.rcgroups.com/forums/showp...postcount=1774
Old Mar 01, 2011, 12:37 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Yes, exactly.
schu
Old Mar 01, 2011, 03:09 PM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
Originally Posted by akschu View Post
Steve,
schu
Understood; I will just quad them up when I have A123's to charge and just use one charger. I am just worried about the 47 Amps input when I use the PL8 @ 40 amps output, I'm sure the input to the charger is above 47 amps when output is maxed...
I wonder what running two PL8's on TWO quad banks would do when they are in expansion mode... I may get more efficiency if I run them @ 220v
Cheers,
Steve
steve1814 is offline Find More Posts by steve1814
Last edited by steve1814; Mar 01, 2011 at 03:22 PM. Reason: Just finished a thought....
Old Mar 01, 2011, 07:18 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
I don't know what they would do. That would be a question for FMA. I suspect it will work fine since in expansion mode they still act like two chargers, they just share config data with each other.
Also, the PL8 has a dc-dc converter. So it's more like watts in vs watts out minus losses. 3.6v * 8 * 40 = 1152 watts. If you add 10% overhead then you can basically charge at ~1000 watts which is still 35 amps, and that is only when the output voltage is 3.6s so in practice you can probably charge at the max 90% of the time on 8s and all of the time on 7s.
Lipo is different since the output voltage is higher, but you should still be able to charge a 6s pack at 40amps.
Basically the only time you will need more power supply then two 47 amp HP units is when you are above 6s lipo or 7s A123, and even then that is assuming max voltage.
So I wouldn't double the power supplies up when your only going to get a few minutes faster charge and only on the largest packs.
Old Mar 01, 2011, 07:24 PM
Southern Pride
Then there are always 100 Amp. ones if using 220V ACl
http://www.rcgroups.com/forums/showp...97&postcount=1
Old Mar 02, 2011, 11:58 AM
Aralan is offline
Find More Posts by Aralan
Joined Sep 2010
I received the completed power supplies this weekend. I did a few quick tests with 6S 30A charging and they worked perfectly. Thanks schu!
Now all I need is a generator so that I can bring all of this power with me to the field...
Aralan is offline Find More Posts by Aralan
Old Mar 02, 2011, 01:11 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Glad you like it!
Old Mar 02, 2011, 01:53 PM
steve1814's Avatar
Joined Mar 2007
Schu,
you going to do another run? I showed my PS to a few friends and now they want em..
Cheers,
Steve
Old Mar 02, 2011, 01:57 PM
ForceFedDSM is offline
Find More Posts by ForceFedDSM
ForceFedDSM's Avatar
Massachusetts
Joined Jun 2008
Originally Posted by ForceFedDSM View Post
schu,
I'm interested in a full kit with a y-power cable if you decide to do another run. Will any ESP135 series supply work or do I need a certain one? I found some DPS-600PB, are these the correct ones?
Originally Posted by GReedTFD View Post
X2 for me
schu,
Are you planning on another run? Seems like there are a few of us interested. Are all ESP135 power supplies the same on the inside and compatible with your kit?
ForceFedDSM is offline Find More Posts by ForceFedDSM
Old Mar 02, 2011, 02:48 PM
akschu is offline
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Not all ESP135 power supplies will work. You need a DPS-600PB. Yes, I'm going to order more parts today.
schu
Old Mar 02, 2011, 03:42 PM
steve1814's Avatar
Joined Mar 2007
schu
Cool, I'll let them know...
Old Mar 03, 2011, 09:06 AM
Massachusetts
Joined Jun 2008
schu
Cool, Thanks. Put me on the list for one full kit please
Old Mar 03, 2011, 12:10 PM
GReedTFD is offline
Joined Sep 2008
I'd like the full kit too. I'd like the y power cord too!
Question Hp DPS 800gb a power supply Nocept1 Batteries and Chargers 174 Apr 28, 2016 10:16 PM
Discussion COnverting Server Power Supply - EMERSON pluto_26 Power Systems 14 Apr 24, 2016 02:37 PM
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Help! HP Server Power Supply conversion memory Batteries and Chargers 4 Feb 14, 2016 01:47 AM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
